Entune upgrade swap
Discussion in 'Technical Chat' started by ProForce, Sep 5, 2012.
  1. Sep 5, 2012 at 11:51 PM
    ProForce
    ProForce [OP] IG @proforce1
    Anthony
    SoCal-Ontario
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    I am looking to trade my 09 for a 2013 Tacoma, and my goal is to keep the stock head unit, and change everything else (please no comments about 'why, aftermarkets better' etc... I know what Im doing). I want the Entune head unit, but I cant justify $2000 for a system I am going to rip out anyways.
    My question:
    I know it is way cheaper to buy the entune head unit alone, but the problem is if I get a standard model the DOES HAVE the display audio with touchscreen, but no entune, and I buy and entune unit, can I make it work WITH AN AFTERMARKET SYSTEM? I already know I cant get it to power the stock non-jbl setup... but thats ok. All I need to know is if the harness that supplies power is the same and most importantly **is the XM tuner and HD module built into the head unit or are they seperate modules that probably wont be in the non-entune model?** I ll probably be missing the XM antenna but I can fix that.
    ANyone have access to 2012/2013 FSM and can post diagrams of standard display audio vs entune wiring diagrams, and maybe pictures of their actual wiring harness' would help alot!
    Thanks
  2. Sep 6, 2012 at 12:10 AM
    WARR4NT
    WARR4NT Well-Known Member
    I've read your post about 5 time now. My dyslexia is kicking in hardcore right now which might make my reply to you not the greatest. If I've got this right, you want to purchase a truck with the standard non entune touchscreen, with standard speakers, and then buy after the fact a entune touchscreen. It should be plug and play. All the vehicles from the factory get wired the same. If there is a feature your truck doesn't have, it's wired for it. And it's got a fuse position in the fuse box for it. I learned all this from my 2010 Tundra I installed a bunch of parts on and found wire everywhere that was hot when I tested it and not connected to anything. If I've got you all wrong and you plan to keep the non entune touchscreen and are changing out the speakers, be aware, I just read on here someone took delivery of a '13 with that head unit and it was not satellite ready or a hd radio. My personal opinion is at least checkout the entune JBL before you commit to something. Sounds bad ass.
  3. Sep 6, 2012 at 12:20 AM
    ProForce
    Anthony
    SoCal-Ontario
    You have me exactly right. The HD and XM... or lack thereof, is exactly why I want the entune screen, but I don't need the speakers ans sub. I'm just afraid the plug will be different, or something pertinent is missing like the xm or GPS antenna wires.
  4. Sep 6, 2012 at 12:48 AM
    WARR4NT
    Do they offer a entune system that is non JBL? I do know that if you buy the JBL system and want to replace the speakers with non JBL aftermarkets, you have to run all new wire, it's not compatible.
  5. Sep 6, 2012 at 12:50 AM
    ProForce
    Anthony
    SoCal-Ontario
    No they dont. Entune and JBL are one in the same now. And yeah I know the speaker setup is entirely different, but thats ok cause it will all be changed. Only thing I need to be compatible it the head unit with the truck, not the speakers and sub and stuff. Ill figure all that part out
  6. Sep 6, 2012 at 1:00 AM
    WARR4NT
    So the end result you want is a better then factory JBL system with entune? And you want to buy the truck with a barebones system in the truck and swap everything out and have it all work without having to wire more then just the speakers. I got it now...I closed 1 eye and stuck my tongue out when I read it this last time and understood it.
    I would just be paranoid about the shark fin. If you don't have the fin it's not gonna work. If I remeber correct the guy that bought the truck that wasn't satellite ready, it was a '13 TRD O/R.
  7. Sep 6, 2012 at 1:20 AM
    ProForce
    Anthony
    SoCal-Ontario
    yeah the 13's without entune jbl have no sat radio or HD capabilites. and yeah its the sharkfin I think will be missing.
    basically i want to buy a struck with basic radio, take the entire system out and build my own, but use the oem entune head unit to power my new system. sorry its hard to explain. This should be simple enough though
  8. Sep 6, 2012 at 1:53 AM
    ProForce
    Anthony
    SoCal-Ontario
    For reference:
    EDIT: one of the bottom 2 gray plugs that is labeled "unk" is the BT mic, and one of the yellowish plugs labeled "unk" is probably steering wheel controls, and I bet the last open plug is not used. Will be for other aux devices aftermarket or factory programming
  9. Sep 6, 2012 at 2:05 AM
    dibble9012
    dibble9012 Well-Known Member
  10. Sep 6, 2012 at 2:09 AM
    ProForce
    Anthony
    SoCal-Ontario
  11. Sep 6, 2012 at 2:15 AM
    dibble9012
    Here's the one for non-navigation. From what I've researched so far, it looks like non-navigation models require a "Multimedia Interface ECU" that connects to the USB port and the radio receiver. Navigation models... so far... look like they have this built in.
    2012 TACOMA RADIO CONNECTORS (NON-NAV)
  12. Sep 6, 2012 at 2:28 AM
    ProForce
    Anthony
    SoCal-Ontario
    2012 or 2013... they are different radios completely
  13. Sep 6, 2012 at 2:57 AM
    ProForce
    Anthony
    SoCal-Ontario
    This isnt gonna work. The harness' are not even close. Even if the non-entune model has a a prewired gps antenna and sat antenna, it would still need the main harness completely rewired. Its possible, but it will take WAY more work than Im willing to do. Couldnt pay me enough to figure this out. Just doesnt seem worth it to me anymore
  14. Sep 7, 2012 at 6:51 PM
    dibble9012
    ProForce, not sure if this would help you. It's information on installing an Entune unit in a pre-2012 JBL equipped Tacoma. It'll at least show you how the system is set up (i.e. amplifier and receiver). Maybe you could hook your own amplifier up to the "Sound Signal out" on the receiver?
    From looking at the wiring diagrams, an Entune unit should be able to swap over to a pre-2012 JBL Tacoma. See the PDF below. The multi-colored lines show which pins from the PRE 2012 connectors need to be moved, and where they need to go on the 2012 connector. Toyota combined two connectors from the old model on the 2012.
    Entune in pre-2012 Tacoma
  15. Oct 23, 2012 at 6:00 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    I have asked this question in many threads, and still havnt got a definate answer yet.
    I have the "mid grade" head unit thats got XM and steering wheel controls and all, but I want to change it to ENTUNE, would this be a direct plug and play swap? I would rather keep everything looking stock......
  16. Oct 24, 2012 at 7:43 AM
    dibble9012
    If you have JBL yes for the most part it would be plug and play. If not, you have to run wiring but still possible.
  17. Jul 23, 2013 at 9:35 AM
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
    • Cat Back Borla Exhaust System • Volant Cold Air Intake with Ram Air Scoop • Black FJ TRD TT 16” Wheels 285/75R16 BF Goodrich All Terrain T/A KO • Icon Extended Travel Front Coil-over Shocks • Icon Monotube 2.0 Aluminum Rear Shocks • Icon Tubular UCAs • OME Dakar Leaf Springs • Front Differential Drop Kit • OME Carrier Bearing Spacer Kit • Hardwired Cobra Radar Detector • Max Liner Floor Mats • Undercover Tonneau Cover • Black Powder coat Devil Horns, Made By Andres • TRD Low profile Carbon Fiber Radio Antenna • LED Map & Dome lights • LED front corner lights • LED Reverse lights • LED License Plate lights • Tailgate Hose Clamp Mod
  18. Aug 24, 2013 at 12:11 PM
    Delliam15
    Delliam15 Well-Known Member
    Irmo, SC
    2012 DCB PreRunner V6
    Led Interior Lights, HID Headlights and Fogs, Bed Lights, Bak Roll-X Tonneau, 2 10" Subwoofers, Electronic Pop-n-Lock Tailgate lock
    Where would you buy the entune head unit?
  19. Aug 24, 2013 at 12:29 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    . . Sub'd
  20. Aug 24, 2013 at 12:39 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
