ERMB's D-I-Y Rack System Build
Discussion in 'Other Builds' started by ERMB, May 23, 2016.
  1. Jun 30, 2016 at 5:31 PM
    #161
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Beefy is okay, wasn't sure the cost effectiveness to try and do a custom sized rack like this.
    Saw a Load Warrior for $100, which is attractively priced but it's not much room. Trying for a second kid so trying to formulate a plan to add a little storage space for trips.
    ERMB[OP] likes this.
  2. Jun 30, 2016 at 5:43 PM
    #162
    ERMB
    ERMB [OP] Well-Known Member
    2002 Land Cruiser
    Nice trying is half the fun. :D best part of these s you can make them to the size to suit your needs , a little wider or longer than normal or whatever works best. Its like an adult size Erector Set.
  3. Jul 7, 2016 at 2:03 PM
    #163
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Thought I'd share my Unistrut project. Here are my bed bars I fabed up for a RTT. I did not paint because these are just a place holder until my bedrac shows up. Then I will modify them for a shelf inside my bedrac and paint at that time.
  4. Jul 11, 2016 at 1:09 PM
    #164
    PHTaco
    PHTaco Well-Known Member
    Brooks
    TX Panhandle
    '13 Trail Limo
    Kings-Dakars-Dirty Fives RCI Skids Demello front bumper BAMF Sliders HC Rear bumper Snug top 4.56 Nitros Engo 9000# Winch w/ syn rope ARB comp & rear locker Home built roof racks Expo trailer w/ RTT
    I got my rear "Faux Runner" rack mounted up. I used Yakima square nuts and 1" stainless steel spacers to mount it, and extra washers on the ends to account for the curvature of the roof. Front rack is all welded up and ready for paint. I'm waiting to do the side plates so I can cover up my mistake if I don't get them exactly the same height. I may decide to skip the side plates and just do a fairing. Opinions welcome.
    samiam and ERMB[OP] like this.
  5. Jul 11, 2016 at 1:43 PM
    #165
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    very nice. any way you can take a close up pic on your mounts? Also, how did you get a hold of the yakima square nuts?
  6. Jul 11, 2016 at 2:08 PM
    #166
    ERMB
    2002 Land Cruiser
    Looks Great Brooks! Like @vuTron said I'd be interested in seeing how you put together the mounts.
    Also what are your plans for the front rack how are you planning to mount that one. I just realized the other day that I'll need to figure out some sort of a spacer since the middle of the roof is higher than the back. My front rack is only going to the middle anyway, but I'll still need to account for that space.
  7. Jul 11, 2016 at 5:39 PM
    #167
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
    I bought them online. ETtrailer.com or something to that effect. I can look back in my email if you need me to - I only keep 3 days worth on my phone and it is older than that.
    The front rack is a little more challenging. I think I have it figured out, but let me try my idea before I lead anyone down the wrong path. I hit both Lowes stores and one Home Depot in town yesterday and still came up short. I had to do the Amazon prime bailout and should have everything by Wednesday. I'll try to take pics along the way and will post up the details. It may be next week sometime depending on whether or not I head to CO for the weekend.
    Not sure how helpful these pics are. From bottom up, there is: square nut, Yakima track, 1" strap with pre-drilled holes, washer, 3/8" x 1" stainless steel spacer, 1/4" x 1-1/4" thick washer, superstrut, 1/4" x 1-1/4" rubber washer, another thick washer and a M6 x 1.0 x 45mm screw with some blue loctite. Note that I flipped the cross members that are mounting points upside down so that I didn't have to make up as much distance. I drove about 20 miles of washboard over the weekend and nothing moved when I re-torqued.
  8. Jul 12, 2016 at 9:22 AM
    #168
    vuTron
    SF Bay Area
    @PHTaco thanks for posting the detailed pics... yes, very informative. great job! can't wait to see your front rack design.
  9. Jul 12, 2016 at 10:55 AM
    #169
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
  10. Jul 12, 2016 at 11:14 AM
    #170
    vuTron
    SF Bay Area
    @PHTaco
    perfect... I think that's exactly what I need. in fact, that site even sells the whole nut/bolt/washer combo. Question: Do you know the exact width measurement of your square washer? I have a Yakima track, but I am not sure exactly which track. I'm just trying to see if these square nuts will fit my track. website does not list width measurement.
  11. Jul 12, 2016 at 11:46 AM
    #171
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
    I'll measure the nuts and the track tonight.
    vuTron[QUOTED] and ERMB[OP] like this.
  12. Jul 12, 2016 at 4:17 PM
    #172
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
    The nut is 0.74" x 0.89". The short side goes crossways in the track. The track is 1.64" wide. I hope this helps.
    IronPeak, vuTron and ERMB[OP] like this.
  13. Jul 12, 2016 at 8:49 PM
    #173
    vuTron
    SF Bay Area
    Perfect. Thanks for the follow up, I'm gonna do my measurements again.
  14. Jul 13, 2016 at 2:33 PM
    #174
    vuTron
    SF Bay Area
    @PHTaco
    Looks like my track opening (internal) is 13/16", which is 0.8125". I think those nuts will work... winner!
    Thelgord, ERMB[OP] and PHTaco like this.
  15. Jul 18, 2016 at 1:12 PM
    #175
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
    I tested the rack out over the weekend
  16. Jul 18, 2016 at 1:29 PM
    #176
    ERMB
    2002 Land Cruiser
    Looks great Brooks, nice work on the rack and im glad everything is working as it should! :thumbsup:
    ready6delta likes this.
  17. Jul 18, 2016 at 4:23 PM
    #177
    ctsnow13
    ctsnow13 Well-Known Member
    2014 Magnetic Grey TRD DCSB
    What shell is that? Just curious what kind of weight mine will handle. How much weight was up there with the RTT and people?
  18. Jul 18, 2016 at 7:55 PM
    #178
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
    It is a snug top. I was solo last weekend, but have camped in it with my wife and two kids when I had it on Thule bars -- so 450+ lbs of carcasses plus tent weight. From what I have seen in the RTT thread, static weight is not an issue, and all shells have a dynamic weight rating great enough to let you carry a tent. My tent is one of the larger models and probably weighs 150-200#.
    ctsnow13 likes this.
  19. Jul 19, 2016 at 9:36 AM
    #179
    vuTron
    SF Bay Area
    So I was at HD this past wknd, about to buy all the parts and make my rack. I ended up not buying anything once I actually picked up the unistrut. I was really surprised how heavy 3 pieces were. I don't have an exact weight measurement, but it just felt HEAVY. Not sure I want that much weight up there. I plan to leave the rack on semi-permanently and it's my daily driver, fuel efficiency is a concern.
    ack... I'm conflicted. Debating on just going with the 2-bar Yakima system, which is significantly lighter. :annoyed:
    C41n likes this.
  20. Jul 19, 2016 at 9:52 AM
    #180
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
    I was about to put my Yakima bars on Craig's list. Shoot me an offer.
