Erratic Cruise Control
Discussion in 'Technical Chat' started by Ratpakr, Sep 18, 2024.
  1. Sep 18, 2024 at 3:48 PM
    Ratpakr
    Ratpakr [OP] Member
    Gene
    So. East Tex.
    2012 TRD Off-Road DCSB 4.0 Auto.
    Running Boards, Viper 5606 w/Remote Start, Anytime Fog-Light Mod..
    2012 TRD Off Road 4.0L Auto. 4x4.
    Cruise Control does not always come on & may or may not engage once on.
    Sometimes works perfectly as expected.
    Please Advise.
    T.I.A.
  2. Sep 18, 2024 at 3:50 PM
    Bishop84
    Bishop84 Well-Known Member
    Spiral cable/clock spring is the typical point of failure with intermittent cruise controller operations.
    TnShooter and joeyv141 like this.
  3. Sep 20, 2024 at 8:15 AM
    MR5X5
    MR5X5 Well-Known Member
    Plunger switch behind the brake pedal is another place to inspect. Make sure you have correct clearance.
  4. Oct 1, 2024 at 5:15 PM
    Ratpakr
    Ratpakr [OP] Member
    Gene
    So. East Tex.
    I've heard, Clock Spring, Brake Light Switch, & Speed Sensor(s).
    I believe I've eliminated Brake Light Switch, Where now ?
  5. Oct 1, 2024 at 5:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Post 2
    That's a Toyota tech answering.
    Road_Warrior likes this.
  6. Oct 1, 2024 at 5:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Turn the steering wheel to different spots.
    Press the CC button and if it comes on. Keep turning the wheel and trying.
    If it comes on in certain spots, and not others, it the clock spring.
  7. Oct 4, 2024 at 4:57 AM
    Ratpakr
    Ratpakr [OP] Member
    Gene
    So. East Tex.
    So yesterday, CC would not come on. I tried 12-15 different positions w/ steering wheel, all the way left & right & several places in-between, still nothing. After @ 15mi down the road, CC decided to come on but would not engage after about another 10mi or so it engaged. Then other time it works as it should or not at all..
  8. Oct 4, 2024 at 9:43 AM
    MR5X5
    Have you tried removing the plunger from behind the break pedal? Takes 2 minutes. This is the plunger that turns CC off when you use your break. The clearance between the plunger and pedal is pretty tight. If for some reason those bits are in contact, out of adjustment, not snugged down all the way, CC will not work properly.
