Error Code..at a loss
Discussion in '1st Gen. Tacomas (1995-2004)' started by heshdog, Jun 15, 2015.
  1. Jun 15, 2015 at 7:57 PM
    heshdog
    heshdog [OP] skating, music
    VA
    01 Tacoma Pre-runner TRD 2x4
    The code pulled doesn't have anything to with sensor 2 down the shaft. I'm at a loss as the what it could. I've searched the net through and changed all the parts that are said cause this code to show.
  2. Jun 15, 2015 at 7:59 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    ^^^^^^^^^^^^ this
  3. Jun 15, 2015 at 8:13 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    check your fuel pressure. As a fuel pump goes out, the pressure will drop. I am not certain of the fuel pressure but I think I remember 40psig, as it drops, intermittent lean conditions will happen.
    There are two possible causes. The worst is the fuel pump, which is not cheap. The second is the fuel pump relay. I've chased down a couple of these problems where the relay contacts have higher-than-normal resistance. That lowers current, which lowers the pump motor power output. I'd always start with the pressure. I don't know if Toyota included a schrader valve on the fuel rail or not. Most manufacturers do, but some require a t-fitting. Whatever, this is a good first step.
    Based on what you have done so far, this would be my most likely candidate.
  4. Jun 27, 2015 at 8:30 PM
    F.I.G.
    F.I.G. Active Member
    Sam
    Tulsa, OK.
    2000 Tacoma Xtra cab 4x4 SR5
    Wheels, cold air intake
    P0171 is a lean reading on bank one. This is the side of the engine with cylinder #1. It is possible you have a vacuum leak (before the oxygen sensor)on that side possibly the intake gasket or even an exhaust leak at the manifold. A rare occurrence would be the fuel rail on that side getting clogged. The key is that you only have the one code. If you have both a 171 and a 174 then you would look at anything that affects both banks (MAF, vacuum hose, cracked intake boot, etc.). If it were an injector leaning out then you would be getting misfire codes for that cylinder. A little involved I know but I hope this keeps someone from just throwing parts at a problem.
  5. Oct 5, 2015 at 1:45 PM
    Paradigm
    Paradigm Well-Known Member
    Erik
    Charlotte, NC
    2010 FJ TTE
    Any updates on this? I have same issue.
  6. Oct 5, 2015 at 2:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Gas cap..... just throwing it out there...
  7. Oct 5, 2015 at 6:37 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    so toyota code p0171 means that the right side (passenger side) O2 sensor is reporting too lean of a situation. and i do mean ONLY the passenger side exhaust. driver side works just fine. so air is getting in, not between the air filter and the engine, but where the air splits off to each head at the intake manifold. so here's a small list of issues that could pass air into the passenger side head and cause this fault code, IF it isn't a bad O2 sensor!
    crack in the intake manifold at the passenger side head.
    loose intake manifold.
    bad intake manifold gasket
    cracked intake port of the head
    cracked intake valve(s).
    bad cracked spark plug
    lose spark plug
    bad or cracked injector
    lose injector
    Now, aside from all of these, keep an eye on your coolant levels and engine oil levels. if your losing either, you may have some internal head or gasket issues though VERY unlikely.
