Error code P2441 Taco 2012 2TR 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fish Killer, May 16, 2013.
  1. May 16, 2013 at 8:48 PM
    Fish Killer
    Fish Killer [OP] Active Member
    kai
    ventura
    base 2003, base 2012
    2003 Tacoma Injen Cold Air Intake. Bosch x4 Spark Plugs. Manual 5 speed 2012. Tacoma Stock, Manual 5 speed. Soon not to be. (Planned Headers, CAI, Muff)
    Folks,
    After I installed AFE CAI with my mechanic, Doug Thorley Headers, and Aero 2525 muffler I drove the truck hard, and late yesterday, I started getting the dreaded Check Engine Light :mad:.
    I'm going over the truck Sat with my mechanic, hoping its just something loose. Looked it up, and seems to be a vacuum leak some where. I do see one area that might cause that I'm going to work on, and another area was to check to see if the headers got loose.
    Anyways the error code I'm getting is P2241. The truck is still under warranty with less than 2500 miles on it. LAst checkup was good!
    Any suggestions? I did research and found that tundras had aftermarket header issues poping the same code. Turned out to be the air injection pipe was to small?
    Thanks.
    Kai
  2. May 16, 2013 at 8:52 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Don't expect the dealer to cover that code under warranty with the aftermarket intake and exhaust installed.
  3. May 16, 2013 at 8:57 PM
    Fish Killer
    kai
    ventura
    uh not looking to the dealer for that!
    I know my rights when it comes what is covered. If the aftermarket part is defective, yes it is my reponsibility there. The burden of proof lies with the dealer if the aftermarket part damaged the vehicle regarding other parts.
  4. May 16, 2013 at 9:02 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    But the dealer is not obligated to cover repairs pertaining to the aftermarket parts and systems.
    Modification of the intake and exhaust is a direct impact on the emissions system.
    It will definitely not be covered, even if the aftermarket parts are not actually defective.
  5. May 16, 2013 at 9:25 PM
    Fish Killer
    kai
    ventura
    I KNOW THAT!!!!!
  6. May 16, 2013 at 10:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Touchy...
  7. May 17, 2013 at 2:18 AM
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    12' reg cab 4x4 2.7L auto
    I think I might have just bought a V-6 Tacoma instead of doing this bullshit to a 4banger and then getting my panties in a bunch when it doesn't go right.
  8. May 17, 2013 at 3:05 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Put oem air intake back on, reset code, drive it, see if code comes back. If it does then you will know that the issue is related to the header. If code does not come back then you will know it is intake related. Then go from there. I don't see any way possible for the muffler to have anything to do with this.
  9. May 17, 2013 at 3:21 AM
    Tacoma Mike
    Southern Maine
    ^^^^^^^^^^^^^^^this^^^^^^^^^^^
    Put it back to stock and leave it alone. These systems are very precise and all your doing is screwing shit up. THEN u expect the dealer tech to play with this thing you screwed for free and Toyota to pay for it?
    U got some balls.
  10. May 17, 2013 at 3:34 AM
    Buck717
    Buck717 Well-Known Member
    Middletown, P.A.
    2011 TRD off road DC
    BDS 6" lift 33x12.5 Mickey mtz 18" XD monster rims White knuckle rock sliders Boztec rear diff plate Rear diff vent mod Compustar alarm/remote start with two way remote.
    Hahahaha
    X2
  11. May 17, 2013 at 5:13 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
  12. May 17, 2013 at 5:42 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Something to do with DT header? I have LC header also with different intake and have had no air injection codes.....or any other kind.
  13. May 19, 2013 at 10:50 AM
    Fish Killer
    kai
    ventura
    Don't be an idiot. Never said anything about the dealer to repair it. I only wanted to state that the truck was at dealership before modification to show the truck was in good shape.
  14. May 19, 2013 at 11:40 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Everyone needs to unknot their knickers and read what the guy said instead of posting didactic BS that isn't even on point.
    So everyone just chill...
  15. May 19, 2013 at 12:58 PM
    Tacoma Mike
    Southern Maine
    You are correct. I re read the entire thread and I missed one sentence.
    I apologise.
    Mark, I had to go to the dictionary to find didact......
  16. May 19, 2013 at 11:18 PM
    Fish Killer
    kai
    ventura
    Found out that the vacuum pump was shutting closed, because the truck is running too lean on the air to fuel mixture. He suggested lower octane gas to change the air to fuel mixture.
    Currently running 89, and will try 87?
    It makes sense cause the error only occurred when more of my gas tank was lowered from full.
    Also, the petroleum disalliated used in fuel stsblizer may be contribute to this.
    10.9 something air to fuel ratio.. .air to fuel mixture was compensated for by the ecu about 5% richer fuel trim. I ended up unplugging the battery, both negative and ground pulled the ecu fuse for 20 min.
    No more cel for now. Although I did find interesting that the same cel code I had appear now in my diagnostic tool said that the error is.pending? I wonder it means it will kick on when it falls to that level again?
    Also, this error only occurs after 2nd to 3rd engine start up within 1 hr of drive time...
  17. May 20, 2013 at 1:29 AM
    batmobile
    batmobile Well-Known Member
    Honolulu, HI
    '13 PreRunner
    so i may be completely wrong, but typically of youre running lean your MAF sensor is being thrown off. also sometimes with headers the O2 sensor is not reading properly so the ecu tries to compensate. since i am new to a tacoma im not 100%. but with the last couple of vehicles I've had that was the case. needed a tune to the ecu
  18. May 20, 2013 at 3:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    87 if nothing but I/H/E.........
  19. May 20, 2013 at 4:53 AM
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    This is one 2.7L I hope not to run into on the resale market in the future.
  20. May 20, 2013 at 10:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Because an I/H/E is so much worse than all the stuff being done like chopping cab mounts, LT rr susp mods, jumping at dunes, runnin them thru muddy swampy shit, climbin and scrapin on rocks and having frames rot out from or ridin thru salt baths every winter? Why wouldn't you hate to see any modded trucks on the resale market? Not seeing much difference, issues with one thing or another with used stuff either way. Replacing a header & intake with oem might take what, coupla hours? Not sayin you don't have right to your opinion or nothin like that but there hasn't been much if anything done to OP's truck at this point to be scared of some hacked up rigged nonsense....that has been posted here anyway.
