Error code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GLineman, Aug 2, 2010.
  1. Aug 2, 2010 at 5:08 AM
    GLineman
    GLineman [OP] Well-Known Member
    Kelso,WA
    Tacoma 2.7l
    1.5" lift,front to level 30" mountain cat tires w/mammoth mat blk. w/diamond cut lip, leer conpy.
    Installed L.C. Engeneering header & cai, shortly after got error code for secondary air inj. port closed, anyone else experience similar problems?
  2. Aug 2, 2010 at 6:05 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Aug 2, 2010 at 6:54 AM
    GLineman
    Kelso,WA
    Tacoma 2.7l
    don't know what the accr. are so ? I used the step by step instr. I don't think they mentioned it
  4. Aug 2, 2010 at 7:22 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You may want to try pulling the NEG cable of the battery for a few minutes to see if it just a fluke too.
  5. Aug 2, 2010 at 7:27 AM
    GLineman
    Kelso,WA
    Tacoma 2.7l
    been there done that. even had it cleared by a mech. friend
  6. Aug 2, 2010 at 7:34 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Ah, the only thing I can think of is the ASV didn't get hooked back up or there might be a clogged check valve.
  7. Aug 2, 2010 at 7:49 AM
    GLineman
    Kelso,WA
    Tacoma 2.7l
    where do i find it to check?
  8. Aug 2, 2010 at 7:52 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    If you look at the link I posted above, it should be on the front exhaust side of the motor. The ASV injections shots of air into the exhaust stream.
  9. Aug 2, 2010 at 8:01 AM
    GLineman
    Kelso,WA
    Tacoma 2.7l
    anybody hear the loud pop as i pulled my head out of my a**. found where the little rubber tube on the sec. air inj goes. should have taken picts. before i started. duh!
  10. Aug 2, 2010 at 8:02 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    So no code now?
  11. Aug 2, 2010 at 8:06 AM
    GLineman
    Kelso,WA
    Tacoma 2.7l
    have to reset then i will know for shure???????
  12. Aug 2, 2010 at 8:18 AM
    GLineman
    Kelso,WA
    Tacoma 2.7l
    from the looks of your link/diagram the little rubber tube attaches to the air pressure sensor.
  13. Aug 2, 2010 at 8:38 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I can't find a detailed vacuum diagram. There should be something int the hood area that shows the routing.
