Error codes, mass air flow, o2 sensor, exaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TTess103, Apr 19, 2020.
  1. Apr 19, 2020 at 11:20 AM
    TTess103
    TTess103 [OP] New Member
    Troy
    2008 blue Tacoma
    So I got an 08 2.7 Tacoma 5 speed and my exaust fell off and I had to cut the wires for one of my o2 sensors and it now won’t go above 3100 rpms even tho I got it all put back on and rewired, it’s throwing off the codes p1613, and p0102, any idea how to go about fixing it?!? Can’t afford to bring it to shop!!!
  2. Apr 19, 2020 at 2:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you cut the wires with power applied ( truck still running )?
    Did the wires get shorted together or to ground after you cut them?
    If so you could have damaged the ECU Computer...
    P1613 indicates an issue with the secondary air injection system driver circuit.
    P0102 indicates an issue with the Mass Air Flow Sensor ( MAF ). Search and find how to clean it with MAF Cleaner. Warning do not touch the sensor with your fingers or anything else. Very easy to damage it.
    Sorry I don't have my detailed references available right now.
  3. Apr 19, 2020 at 5:14 PM
    c212
    c212 Well-Known Member
    In light of that mishap, if it were my truck I'd suspect those codes are sending me down a rabbit trail and away from the real problem. You said the exhaust fell off. If that's really what happened, the cat might have gotten damaged internally -- the honeycomb specifically -- causing excessive back pressure. Did you check for rattles before you put the exhaust back on the truck? Can you at least afford to get the cat flow-tested?
  4. Apr 19, 2020 at 5:15 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That sounds gnarly!
    If you have fixed everything already and the codes are still stored, just go ahead and replace your blown 10amp "EFI 2" fuse and call it a day.
    c212 and TTess103[OP] like this.
  5. Apr 23, 2020 at 9:37 AM
    TTess103
    Troy
    2008 blue Tacoma
    I reattached and wired the o2 and went thru the engine bay fuse box and found a blown multi port fuel fuse and she’s been running great since!
    12TRDTacoma, Steves104x4 and Jimmyh like this.
  6. Apr 24, 2020 at 4:18 AM
    c212
    Wow, 12TRD, that was a great call. My hat's off to you.
    12TRDTacoma likes this.
