Escalator on Hell’s Revenge in a mild Taco?
Discussion in 'Moab' started by TomHGZ, Mar 1, 2025.
  1. Mar 1, 2025 at 11:38 AM
    TomHGZ
    TomHGZ [OP] Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    I’m heading to Moab in couple weeks for maybe the fifth or sixth time. Curious if anyone here has run the Escalator on Hell’s Revenge in a mildly built Taco?
    I’ve done the rest of the trail a few times — everything except the deepest hot tub and the escalator, and I keep eyeballing the escalator. Seen a couple videos of mild 2nd gens (33’s, no long travel) running the escalator — even one without a front locker — but the mild Tacos seem to be the exception to the rule.
    For both scenery and thrills, what other trails should I not miss in southern Utah? 33’s, double locked. Also looking for hiking, camping, backpacking recommendations.
  2. Mar 4, 2025 at 10:17 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    I’ve never done it on anything less than 35s.
  3. Mar 5, 2025 at 11:06 AM
    TomHGZ
    Because you feel like that’s what it requires?
  4. Mar 5, 2025 at 11:11 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Just sitting at the top and eating lunch I watched some Jeep XJs on 31s get up it, a couple mild older pickups, and some random Dodge SUV, lockers and suspension travel are both more important than tire size on the Excalator I think, if you can keep your tires on the surface it isn't a tough obstacle really. Failing that and you want to get froggy I'd make sure you have a low COG at least
    TomHGZ[QUOTED][OP] likes this.
  5. Mar 5, 2025 at 11:42 AM
    TomHGZ
    That’s also my thinking. I’m only on 2” lift with 33’s and keep the spare under the bed, but then I have a Vagabond Drifter camper, which is about 450 lbs. I’ve seen a Taco do it with more lift, a high mounted roof top tent, 35’s, a 35 on the swingout, and I’ve seen plenty of shorter wheelbase wranglers with much more lift, and am (guessing that with a 127” wheelbase I’m) a lot less tippy than the jeeps, but the second “stair step” would be the steepest thing I’ve tried.
  6. Mar 6, 2025 at 11:43 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    BabyBilly and TomHGZ[OP] like this.
  7. Mar 6, 2025 at 1:23 PM
    TomHGZ
  8. Mar 6, 2025 at 3:23 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yep, in my 4runner on 33s and have seen dozens of 2nd gens on 33s do it.
  9. Mar 6, 2025 at 3:27 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  10. Apr 17, 2025 at 8:11 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    One day ill get the b*llz to try something like this. Good stuff
