especk's '10 Reg Cab OME 4x4
Discussion in '2nd Gen. Builds (2005-2015)' started by especk, Feb 21, 2011.
  1. Feb 21, 2011 at 7:55 PM
    covefrog08
    covefrog08 swollen member
    Vancouver Island- Canada
    08 w/west coast pin-striping
    devil horns, weather tech floor mats, Camo seat cover, window visors, premier deck w/ 6 speakers and sub, checker plate tool box, diff breather relocate, Mag light & Fire Extinguisher behind seat
    that's super sweet dude! i want to pretty much the same mods for my 08 reg cab. i just can't decided between OME and toytech. where did you order your parts from?
  2. Feb 21, 2011 at 7:57 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Looks good man!!
    Did you have to take-off your fenders to clear your tires?
  3. Feb 21, 2011 at 7:59 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I ordered from Wheelers and they were awesome! They are in the vendor section on here - check em out.
  4. Feb 21, 2011 at 8:01 PM
    especk
    Erik
    Redding, CA
    No I took the fenders off before I put the bigger tires on it. I think it looks better with them off. If they were painted to match that would be different, but they were just black plastic.
  5. Feb 21, 2011 at 8:03 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Nice truck! Those bumpers are badass! What are the openings on the rear bumper near the R cutouts for? Reverse lights?
  6. Feb 21, 2011 at 8:06 PM
    especk
    Erik
    Redding, CA
    They are lift points for a hi-lift jack. They are on the front too.
  7. Feb 21, 2011 at 8:08 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Ummmm...........nothing to say but DAMN!!!!!!!!!!!
    That is all I can think of to say, your truck is that nice.:D
  8. Feb 21, 2011 at 8:10 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    looks bad ass.my new fav reg cab
  9. Feb 21, 2011 at 8:10 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Great looking regular cab, your 885's will settle before to long I know mine did. I ended up going to 886's after adding my bumper and winch.
  10. Feb 21, 2011 at 8:18 PM
    especk
    Erik
    Redding, CA
    Thanks. That's good to hear!
  11. Feb 21, 2011 at 8:21 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Truck looks BADASS Erik! Nice job! The bumpers totally transformed the look of it, and I gotta say they look great on the Reg cab! :)
    One thing.... I see the front bumper mounting brace plates arent installed.... you'll want to get those put on before tugging and winching because the factory mounts bend under the load. Good thing is you dont even have to remove the bumper or move it... just remove the outer 2 nuts (of the 3 on each side facing forward), then slip the braces over the studs, reinstall the nuts, and tighten the 4" grade-8 bolt through the brace/frame rail. :cool:
  12. Feb 21, 2011 at 8:28 PM
    especk
    Erik
    Redding, CA
    I'm glad you said something. Is that supplemental hardware supposed to be supplied with the front bumper? I received some mounting hardware in plastic that was attached to the rear bumper but I havent used it yet because I though it may make more sense once I received the other brackets your sending me for the rear.
    Heres the pic (I painted the bracket) - Is this supposed to go with the front bumper with all those bolts that came with it?????
    edit: and will this also cause the bumper to sit a little lower and more away from the bottom of the body of the truck? because its a little too close right now and I was going to lower it with some washers.
  13. Feb 21, 2011 at 8:46 PM
    especk
    Erik
    Redding, CA
    :notsure:
  14. Feb 21, 2011 at 8:48 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    Awesome, I may have a new favorite truck on TW...really makes me wish I had gotten a reg cab even more than I already do. Wanna trade? :)
  15. Feb 21, 2011 at 8:52 PM
    #35
    especk
    Erik
    Redding, CA
    haha thanks man! Thats a no-go on the trade. This is MINE!
  16. Feb 21, 2011 at 9:04 PM
    #36
    RelentlessFab
    Eric
    Sparks, NV
    Yeah, those are the brackets and there are some 4" bolts that go with them.
    There should have been plenty of washers (5 per side) to adjust the height of the bumper via the bottom bolts. You can use as many as necessary, and also if one side is slightly higher than the other, level the bumper with them too. The brackets doesnt effect mounting height though, just the bottom bolts/washers.
  17. Feb 21, 2011 at 9:07 PM
    #37
    especk
    Erik
    Redding, CA
    You freakin rock!!! I'm about to drive up to OR just to buy you a beer haha. I was kind of confused about the "extra" hardware - apparently its not extra at all. I'll take care of it tomorrow. I'm so glad you noticed that!
  18. Feb 21, 2011 at 9:10 PM
    #38
    RelentlessFab
    Eric
    Sparks, NV
    :laugh:
    Well thanks Erik! Glad I can help. :D
    You should try and make it to the PRS mod day in Sacramento this weekend, there's going to be tons of guys to BS with, and I'll be there delivering bumpers, and helpin out with whatever else guys can use me for. :cool:
  19. Feb 21, 2011 at 9:32 PM
    #39
    especk
    Erik
    Redding, CA
    I just may come. I was going to go to Pismo but it may be raining - and I heard the sand has salt in it and if it rains it may cause rust :eek:
  20. Feb 21, 2011 at 9:36 PM
    #40
    blacktaco21
    blacktaco21 Crunchy Taco
    AR
    05 TRD Sport DC 6" 325/65R18
    Fabtech 6" Baja Tire Carrier Limo Tint 4.88 Gears Detroit Locker Rear ARB Locker up front Train Horns Pioneer DVD Double Din JL Audio 12w3v3 325/65R18 Baja MTZs 18x10 Classic Locks Powder Coated Flat Black
    bumper powder coated or rattle can?
