Estimate of head gasket Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yosh1975, Mar 5, 2021.
  1. Mar 6, 2021 at 9:25 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
  2. Mar 7, 2021 at 4:45 AM
    yosh1975
    yosh1975 [OP] Well-Known Member
    northeast ohio
    2005 std 4x4
    Thanks. Do those testers work ok? Think parts store loans them out?
  3. Mar 7, 2021 at 4:48 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes they work.
    I have never seen them loan them out.
    They are relatively Cheap.
    Harbor Freight sells them, if you have one near by?
  4. Mar 7, 2021 at 4:52 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    many possibilities
    pull plugs ..................do NOt jumble
    keep in order
    while plugs out do compression test
    drain oil .......check filter
    either on both will give U a better diagnosis
    Rick's 2012[QUOTED] likes this.
  5. Mar 7, 2021 at 6:24 AM
    Bashby
    Bashby Active Member
    Yes, they work IF your head gasket is leaking combustion gases into the cooling system. It is possible to have coolant leak into the oil and not have combustion gas going into coolant.
  6. Mar 7, 2021 at 6:30 AM
    Bashby
    With all the frame issues I would think junkyards would have a lot of engines for these trucks. Might be cheaper and easier to swap engines.
  7. Mar 7, 2021 at 7:20 AM
    Waasheem
    Waasheem
    2007 xrunner
    You say it sat 6 months, brown oil changed twice in 2 weeks.
    During the 6 months was it started and brought to operating temperature? Between the 2 oil changes miles driven? Habitatual short trip drives?
    Ive seen oil come out white like mayonnaise due to short trips. Broke the driver of that habit, problem went away. If you’re still uncertain the block test previously mentioned would tell you if exhaust gasses are in the coolant.
  8. Mar 7, 2021 at 7:35 PM
    ROAD DOG
    FEW
    occasional start ups & excessive idling do NOT help an engine ( old wives tale )
    only keeps rings from getting rusty
    oiling the cylinders MORE EFFECTVE
    even tho the temp needle will moves..................total temps dont get hot enuf to burn off moisture in the engine
  9. Mar 8, 2021 at 11:12 PM
    Waasheem
    Waasheem
    2007 xrunner
    Anyhow, let us know what you find. People post an issue, everyone throws their diagnosis guess in. Then we like to hear what it actually was. If it seems like it was something simple, and heck I should have known. Don’t be embarrassed. I’ve been wrenching for years and not a week goes by I don’t learn something new.
  10. Mar 9, 2021 at 5:18 AM
    yosh1975
    northeast ohio
    2005 std 4x4
    Great guys, thanks . I will play around on Sunday and see.
    I do have a harbor freight close, just need to find a coupon now. Never can find coupons when I need them.
    I will definitely report back. Maybe help someone else by doing so.
    Thanks again
  11. Mar 17, 2021 at 12:00 AM
    yosh1975
    northeast ohio
    2005 std 4x4
    Ok here is where I am at now.
    Pulled plugs and inspected. Looked old and white build up on tips.
    Put new oil in.
    Purchased the engine combustion leak tester and did test. Tested numerous times over a 60 minute period. Engine ran the entire time. And even drove a few miles. Temp Guage right around halfway mark. NO YELLOW.
    Checked oil via dip and drain. OIL LOOKS LIKE OIL.
    Tested exhaust with combustion tester and turned yellow, so tester and solution are good?
    Plugs are on order.
    Going to replace plugs, drive and check oil often to see.
    Rick's 2012 likes this.
  12. Mar 17, 2021 at 6:27 AM
    Waasheem
    Waasheem
    2007 xrunner
    If your exhaust gas test didn’t turn yellow testing at the radiator neck and coolant reservoir and did turn yellow at the tail pipe, that’s a good test, negative result for exhaust gas in the coolant.
  13. Mar 17, 2021 at 2:07 PM
    yosh1975
    northeast ohio
    2005 std 4x4
    That's what I am thinking. Gonna run it for a couple hours and recheck oil. Fingers crossed
  14. Mar 17, 2021 at 2:33 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Is there any real damage a head gasket issue can do if it doesn't overheat the engine? I suppose if it contaminated the oil enough to wear on parts but that should take a while. I'm no expert, but I'd personally try to keep driving it for a bit longer and make sure it gets to temp at least and see if any moisture accumulates and especially to see if your coolant drops in level.
  15. Mar 17, 2021 at 4:16 PM
    #35
    Waasheem
    Waasheem
    2007 xrunner
    My guess is it was a condensation issue. It's not easy to see the milky oil on the dip stick unless it's really bad. If it's not overheating, you're probably ok. You've got fresh oil in there now. For peace of mind, you could dump it again in a week. During thst week, drive it making sure to get it up to temperature. If you have a long uphill road you can put it on, take it, towards the end of the hill floor it to get everything good and hot. Drain into a clean pan so you can reuse it if it comes out looking good.
    When I did my first Tacoma oil change, it came out looking bad, dirty bad not milky. So when time for the next oil change I dumped oil, refilled leaving the filter. Then did the oil & filter after driving it hard.
  16. Mar 17, 2021 at 4:24 PM
    #36
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Get out there and drive that thing
  17. Mar 17, 2021 at 7:18 PM
    #37
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Drive it and check under the oil cap a few times a month. Short tips will turn the bottom of the cap milky white. Long trips will remove it or at least get it to temp for a little while.
  18. Mar 17, 2021 at 8:35 PM
    #38
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This is all you need to do ^
