'Estimated miles till empty' feature is incorrect
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ultravista, Dec 21, 2023.
  1. Dec 22, 2023 at 9:45 AM
    #61
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It really is about either habit or money i think. I've been filling my tank when it hits half empty for years now. I got tons of money and I just like the feeling of having plenty of gas in my tank. But I do remember the lean days of my youth when I surived on Campbell Chunky Soup and the $2.00 "fill up" was the norm.
    musicisevil likes this.
  2. Dec 22, 2023 at 9:55 AM
    #62
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    He makes more money now, so puts $6 in each time. So he gets three times the amount of gas these days.... right? Right??:bananadead:
  3. Dec 22, 2023 at 9:56 AM
    #63
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    good thing he’s not an aircraft pilot.
  4. Dec 22, 2023 at 9:57 AM
    #64
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Glider pilot at that point technically. lol
  5. Dec 23, 2023 at 9:47 AM
    #65
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Won't do much good if it doesn't stay pressurized though for the injectors. Without the fuel pump feeding fresh fuel past the check valve, the remaining pressure will drop off quickly, and not enough fuel will be delivered giving a lean burn, though arguable for a very few cycles. In tank fuel pumps are often cooled by the fuel running thru then, and the pump materials themselves are lubricated by the fuel. Running a fuel pump dry risks ruining it in short order.
  6. Dec 23, 2023 at 8:57 PM
    #66
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    You are right, so the OP could not have been under power when reaching the fuel station if the tank is only 21 gallons. Maybe it's 21.5 or something but they were cutting it close for sure.
  7. Dec 31, 2023 at 10:26 AM
    #67
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Former brother-in-law used to try to completely empty the tank so he had all “fresh” gas for his car. Ran dry in the night in the middle of the Everglades bringing nephew home from soccer. Tried having the 9-year old steer while he pushed, but eventually gave up and called his wife for help.
    She brought him a couple of gallons, but took the kid with her when she departed. Alligators were spotted, but remained otherwise uninvolved.
    That wasn’t what ended the marriage, but it sure helped.
    Just saying, that warning light is there for a reason…..
  8. Jan 2, 2024 at 8:28 AM
    #68
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    oh i miss the cheaper days. heck I remember my first car. putting $25 in and having almost a whole tank. but a 21 gallon tank in my first car was cool. think my first fill was like $1.30 something a gallon
    Thatbassguy likes this.
  9. Jan 2, 2024 at 8:45 AM
    #69
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    LOL, you must be young, I remember paying $0.25 per gallon for Premium. :p
  10. Jan 2, 2024 at 3:45 PM
    #70
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    99 cents a gallon for about 2 months in Buckley, Wa when I got my license at 16. Never saw it below a dollar again
    20$ a week in my little 1991 Honda Civic SI and I could drive to any skatepark I wanted after school. Good times
