ETAV8R's build: Gini and some wanderings
Discussion in '2nd Gen. Builds (2005-2015)' started by ETAV8R, Mar 30, 2010.
  1. Dec 2, 2023 at 5:48 PM
    #281
    ETAV8R
    ETAV8R [OP] Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Let there be light!
    Well I went a little crazy during the recent black Friday sale...I want to make a video about the lights next time I go camping.
    The small headlamp Perun is pretty cool but weighs more than my Nitecore. Plus it doesn't have a soft white flood or low setting for the red but it does have a magnetic base and pocket clip which gives it different uses. I have hopes to maybe use it on my telescoping pole up high above camp...but I also don't like a super lit up campsite. If it works though it would prove again to me that all the broverlanding nick-nacks aren't necessary.
    Regarding the Arkfeld Pro Zombie edition, (which started this shopping spree) it is a nice camp/edc light. The multifunction is great. It has white light with strobe, a laser, and UV. But if all one wants is a nice UV light the Nitecore UV Tiki 1000 has the same output for much less money.
    https://www.nitecorestore.com/TIKI-...Cq3wpcHfdCEWs70n7roIR0GJcVqpKsiEaAhNaEALw_wcB
    The Oclip is pretty neat and very small. I tried it out for my truck kitchen and it seems to be a good use. It has a magnet and clip.
    Crom, DVexile, d.shaw and 3 others like this.
  2. Dec 3, 2023 at 5:55 AM
    #282
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Oh - Black Friday, Cyber Week, Turn Wallet Over And Shake It Month has been really bad for me! Not going to even mention some of the stuff. Downright embarrassing “aspirational hobby” purchases.
    But for lights, I was going to need to read a number of actual physical books on an upcoming work trip and so picked up an old school clip on book light:
    https://www.amazon.com/gp/product/B08GG42WXY?ie=UTF8&th=1
    Actually pretty slick with USB chargeable internal battery, dual color temperature and dimmable. The clip base has a flat back and is wide enough to be set on a flat surface like a mini desk lamp. No magnet though.
    I picked up a second one to leave with the truck (sale price was $8.70) as it seemed it could be very handy. For the truck/camping I wish it would go even dimmer and have a red LED as well. I suppose I could make a red filter sleeve for it… hmmm…
    EDIT: Just to add there are a bunch of nearly identical versions on Amazon. Nothing very special about the one I got other than it was on sale and was continuously dimmable. I did just notice some that are switchable between amber and red which might be better for camping. Amber probably to low color temperature for monitoring cooking though (can’t see browning).
    Cwopinger, Crom and ETAV8R[OP] like this.
  3. Dec 5, 2023 at 1:23 AM
    #283
    ETAV8R
    Just the basics
    Well, my experiment worked. I got the Olight bike mount and used it with the Perun 2 Mini to use as a area light/camp light for my setup.
    Total cost for my bougie setup is $70. For that cost I have my light which was $45 during an Olight sale, telescoping pole which is currently $17 at Lowe's, and the Olight universal bike mount on slamazon for $9. I've had the pole for a couple years and it does multiple things in camp from a flagpole to awning room roof pole (prevents water build up), and now as a light pole. Pretty slick multiple use gear. Here's some pics of the light pole in my shop. I do wish there was a diffuser for the light.
    P.s.
    I believe I have a budget diffuser solution. The small white plastic piece that covers the usb attachment for the charger just about covers the lens of the light might suffice. Using a small rubber band and this plastic piece does diffuse the light. A second option may be a thin translucent plastic bag. These are usually included with electronics and it too did the trick. The only worry is if the diffusers used might melt. The light does heat up when in turbo mode but fortunately this isn't used for normal long term use.
    https://www.olightstore.com/perun-2-mini-led-rechargeable-headlamp
    https://www.lowes.com/pd/Blue-Hawk-6-ft-to-12-ft-Telescoping-Threaded-Extension-Pole/50053469
    https://www.amazon.com/dp/B0761RX64G?ref=ppx_yo2ov_dt_b_product_details#customerReviews
    dman100, Cwopinger, Crom and 2 others like this.
  4. Dec 16, 2023 at 7:59 AM
    #284
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Love the light arrangement. :)
    Drainbung and ETAV8R[OP] like this.
  5. Dec 16, 2023 at 9:01 AM
    #285
    ETAV8R
    Just the basics
    Oh I got to try them out in DV recently. Had a lot of fun. Will post pics soon.
    Crom[QUOTED], Cwopinger and Drainbung like this.
  6. Dec 19, 2023 at 3:23 AM
    #286
    ETAV8R
    Just the basics
    Another Saline Valley trip...I took fairly good notes as this was my first trip to the springs in over a year...a quick two nighter
    Left the LA/OC area at 9pm...the cockpit set up...
    Arrived at Big Pine 121am and fueled up.
    Heading out to the springs at 136am
    Temp 40f
    Big Pine /Waucoba aired down at 207 am
    temp 24f
    Coldest temp during my travels on North Pass 19f
    Batrock Road and SVR intersection 317am
    Temp 45f
    Arrived at my camp site near the Wizard Pool at 350 am
    Had a nice soak and saw 2 shooting stars. Watched the seven sisters set below the northern horizon.
    Not much sleep. Up making coffee at 10am. Temp is 61
    Tried this new to me coffee filter set up. Needs fine tuning. My coffee using this method was pretty weak.
    This couple had a Starlink setup. Guess some people always need to be connected to the grid.
    Had a fun evening messing around with my lights.
    Really digging these Olights. The magnetic charging base allows for a multitude of flexibility in using the lights. This is the one from the headlamp, the Perun 2 Mini.
    Another camper had a lit up Christmas wreath so I followed suit for the upcoming holiday best I could...these are the Nite Ize Radiant Micro Lanterns set to red and green.
    Another example/use for the magnetic base.
    Zombies!
    Different uses for different lights.
    The red light setting is a tad too bright for me but I've been spoiled by the 1st gen Nitecore NU25 red light settings. I'm still very happy to have both lights and will continue to use them.
    Saw over 30 shooting stars. The first 27 were during a soak and the following ones were back at my camp. It was a spectacular trip. One of my best to Saline. All that was missing was some bats during my soaks and a great sunset.
    Thursday December 14th
    Up at 630
    Temp 43f
    825 had breakfast and camp is put away
    0900 departure from Palm Spring
    Temp 48f
    0920 stopped to add 5gal fuel at bat pole.
    Mother nature did a lot of rearranging.
    0935 SVR/Batrock Road intersection
    Mother natures hard work. Having been on this road so many times it blows my mind how much rain and energy caused this wash to increase in width and depth. Good times.
    The infamous Willow Creek wash. There used to be a metal culvert here which was placed after a washout several years ago. I looked down the wash for the culvert...it is either buried in sand/rocks or too far out of sight.
    1055 Big Pine Road/Waucoba
    Temp45
    Aired up by 1125. Another air hose failure
    On the road home at 1320 after picking up goodies at Bishop and Big Pine.
    MonkeyProof, Cwopinger, Crom and 4 others like this.
  7. Dec 19, 2023 at 4:58 AM
    #287
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Drainbung likes this.
  8. Dec 19, 2023 at 8:20 AM
    #288
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
  9. Dec 19, 2023 at 9:08 AM
    #289
    Crom
    Nick
    San Diego, CA
    Millions
    Great report, and like perfect quick trip execution. Thanks for sharing pics/ write up. :)
    What are you using for the Electronic Navigation?
  10. Dec 19, 2023 at 10:05 AM
    #290
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Fantastic report, good to see the springs (and park) opening up again. Can't wait to get back in 2024. Appreciated the late/early arrival, and the temperatures along the way. 19°F at North Pass. Brrrrr.
    Love this photo, nice work.
  11. Dec 20, 2023 at 10:39 AM
    #291
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x3
    Looks like a fun trip! I'm not getting out much these days... but today I'm at this place because you recommended it:
    Edit:
    No more clunk!
  12. Dec 20, 2023 at 11:55 AM
    #292
    ETAV8R
    Just the basics
    Good stuff. I was just down in the area this morning.
    mk5[QUOTED] likes this.
  13. Dec 20, 2023 at 6:55 PM
    #293
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Years ago I think in 2011 I had my rear DS retubed by DL Inc. as a result from Trail Damage at Calico, my appointment was on a Thursday in the afternoon. Didn't take no more than two hours from the time I checked in to complete, they are pretty amazing at what they do. Saturday I dinged the DS again this time at The Hammers going up Claw Hammer..my DS didnt last more than 3 days. All in all, It's been re-tubed 3 times (twice by DL Inc.)since owning the Tacoma.
    Drainbung, ETAV8R[OP] and mk5[QUOTED] like this.
  14. Dec 20, 2023 at 7:00 PM
    #294
    mk5
    SoCal
    '05 access cab 4x3
    I'm still aspiring for your level of trauma when it comes to driving... I was just getting fresh u joints and carrier bearing today. U joints may well have been original, almost 19 yrs old and 220k miles!
    That said, I came close to pretzeling the thing at Calico last winter... that road doesn't mess around.
    And my experience this morning was similar... lightning fast!
    ETAV8R[OP] likes this.
  15. Aug 17, 2024 at 3:12 PM
    #295
    ETAV8R
    Just the basics
    Not having been out for a while and hoping to have a 4Runner in the future I've been looking for storage options. Came across the Toughbuilt Stacktech system a few months ago and have picked up a few items. Their potential offerings look great for camping. Last night I messed around with different ways I could use them with the Gini...
    https://stacktech.toughbuilt.com/advantage/
    https://stacktech.toughbuilt.com/catalog/
    Oh and for the future release of the rolling drawer and/or XL drawer this is the perfect height for a cook top if you're around 6'. The big drawback with this system is weight. It's a bit heavy. It is modular and the pieces separate easily.
    Crom, turbodb, d.shaw and 3 others like this.
  16. Oct 9, 2024 at 10:14 AM
    #296
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra 2016 4Runner
    Out of all the camper setups you've had, which one has been your favorite and why?
    I had a FWC, tow a 30' travel trailer, now looking into building a canopy camper or rtt. So just curious haha
  17. Oct 11, 2024 at 12:51 AM
    #297
    ETAV8R
    Just the basics
    My current setup is my favorite thus far. The FWC is great but too heavy for the Tacoma (imho). If I ever get a full-size truck I'd look at FWC, Alaskan, or hardside slide-in.
  18. Oct 14, 2024 at 6:22 AM
    #298
    captrussia253
    PNW
    Light and simplicity of your current setup is what I really like. I agree with the FWC being too big for a mid size truck (mine was on my Frontier).
    ETAV8R[QUOTED][OP] and Drainbung like this.
  19. Nov 26, 2024 at 4:52 AM
    #299
    ETAV8R
    Just the basics
    Quick two night trip to JT and Providence Mountains a couple weeks ago.
  20. Jan 8, 2025 at 8:51 PM
    #300
    ETAV8R
    Just the basics
    I recently moved and no longer keep my truck on a trickle charger. This, and only using the truck for trips, led to my AGM battery finally giving up the ghost. It lasted about ten years, maybe more.
    A coworker who was an electrician in his prior career has a nice tacoma setup. He suggested a lifpo battery on slamazon. It arrived for Christmas and I had ordered a new CTEK controller since my old one doesn't charge lifpo batteries. Had to rig up a way to secure the new battery since it wouldn't fit in my old tray.
    Got everything installed and did a short drive around the neighborhood but the new CTEK didn't wake up to charge the new battery. Talked with the coworker and he took a look at it. On the way to see him the CTEK got to doing it's job and I could finally see the battery charging due to the internal Bluetooth function. Very happy with the new setup.
    Old CTEK
    New CTEK
    New battery
    Ngneer, Cwopinger, d.shaw and 4 others like this.
