ETC Button
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rehabber, Oct 24, 2015.
  1. Oct 13, 2016 at 6:27 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    thinking about crazy gluing my button in the on position.........
    Ducman4x4 likes this.
  2. Oct 13, 2016 at 7:55 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    I use it in hilly conditions, otherwise leave it alone, unless it's needed for passing during high traffic conditions. Alters shift points and keeps you in higher rpm's for added response.
  3. Oct 13, 2016 at 7:58 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Ya... that won't work. I'm trying to source the factory male/female connectors on the back to wire up a plug n play relay that always turns the ETC ON after starting the truck. Then you can alway push it off if desired
  4. Oct 14, 2016 at 9:22 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Please...keep me in the loop on that....
  5. Oct 14, 2016 at 9:30 AM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    +1
    :cheers:
  6. Oct 14, 2016 at 10:59 AM
    particleman
    particleman Well-Known Member
    2016 2wd SR5
    I can tell immediately when I'm towing and forgot to press ect. Other than that i never use it.
  7. Oct 14, 2016 at 11:14 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Use mine all the time on the back curvy country roads, and in traffic. Works great.
    G.
  8. Oct 14, 2016 at 11:24 AM
    Humboldt_Homie
    Humboldt_Homie If you're not first, you're last.
    16 TRD OR DCLB
    Bilstein 6112 front, 5100's rear with blocks, camburg UCA, 17" XD's with 285/70/17 AT 3's and a blackout front grille.
    It's the racing mode button for Tacoma's.
    gargamel05 likes this.
  9. Oct 14, 2016 at 12:08 PM
    TacoMan2017
    TacoMan2017 Well-Known Member
    Puts your Tacoma on steroids...
    69TACO16 likes this.
  10. Oct 14, 2016 at 12:18 PM
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    I use the ECT mode quite a bit in with both drive and sport shift, and I'm thinking about installing a new ECT rocker switch to the center console so that I can easily activate it whenever I want with my right hand instead of having to reach down to the bottom of the dash. Turning the ECT switch on raises the rpms slightly in each gear, and with the truck running at a constant speed when you turn the ECT on and off you can see a change in the RPM, as well as the fuel mileage indicator decrease, and with the ECT turned on the engine feels much peppier and alive.
    I have a feeling that it also effects the fuel mapping and maybe even the valve timing also.
    HalfWayThere likes this.
  11. Oct 14, 2016 at 12:28 PM
    jgr81
    jgr81 Well-Known Member
    Jen
    Summit County CO
    16 Tacoma TRD OR Access Cab, 03 4runner v8
    bwahahah that is what the salesman told me when I picked mine up and they were "showing me how the truck worked." I laughed and told him he should do a little more research. I think I made him mad
  12. Oct 14, 2016 at 12:33 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    3rYODA and Rambeaux like this.
  13. Oct 15, 2016 at 1:56 PM
    MESO
    State of Jefferson
    Okay,
    little more digging into this;
    4 pin connector
    from LEFT to RIGHT:
    Pin1(white w/ black stripe):Ground -
    Pin2(tan):ETC activation out to ECU
    Pin3(green): Illumination +
    Pin4(pink): +12v Switched.
    When the button is pressed... pin 2 and pin 4 make contact.(momentary) thus turning ON/OFF ETC. I am trying to source the factory 4 pin connector(both male and female) so I can wire in my relay and make it plug and play. Anyone know where to source these?
  14. Oct 15, 2016 at 2:07 PM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    How hard was it to access and unhook the connector.
  15. Oct 15, 2016 at 2:44 PM
    #35
    MESO
    State of Jefferson
    1) remove the 10mm at the bottom right of the steering column panel..then pop it back.
    2) Carefully snap silver trim bezel off(the one that goes around the A/C)
    3) Reach down in the hole and pop ETC button out from the front.
  16. Oct 15, 2016 at 3:14 PM
    #36
    hakabotaco
    hakabotaco Well-Known Member
    Jacob
    Landis, NC
    2016 Double Cab Sport
    Sub'd for learning how to have it come on everytime I get in the truck. Prefer to not have to manually engage everytime.
  17. Oct 15, 2016 at 3:17 PM
    #37
    Cnd-GB
    Cnd-GB Well-Known Member
    2016 Nissan Frontier King Cab Pro-4X 6sp
    "Etc stands for et cetera which is latin expression meaning 'and so forth'. It s used to denote logical continuation of some sort of series of descriptions. Refer. . et cetera"
  18. Oct 15, 2016 at 4:24 PM
    #38
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    2016 Blk TRD Sport 4X4 DCSB
    Cracked W/S
    Actually, (clears throat) ECT is the acronym for "Extra Crispy Taco". I spoke to my service manager and he confirmed it.
    HotTaco78, 69TACO16 and RHelton10 like this.
  19. Oct 15, 2016 at 4:28 PM
    #39
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    I too have been thinking of the simplest thing that could possibly work.
    You only need to send a 12v pulse after startup. You could run a wire from pin2 to the gear shift and tap it onto any of the gear select position indicator wires.
    If you tapped N......
    So, after you start the vehicle, you would shift from P to D , passing through N. If you tapped N the pulse would be sent to the ecu activating ECT.
    Placing the vehicle back in park would cycle it off.
    So each time you run the shifter past N it would activate or deactivate ECT.
  20. Oct 15, 2016 at 4:46 PM
    #40
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
