ETC Button
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rehabber, Oct 24, 2015.
  1. Oct 15, 2016 at 4:47 PM
    #41
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    Thanks. :thumbsup:
  2. Oct 15, 2016 at 4:48 PM
    #42
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I did a Goggle search, and most of the posts I found said the same thing about the ECT switch, and the ECT switch is explained on page 198 of the owners manual.
    What does the ECT button in my Toyota do?
    Here at New Rochelle Toyota, we get a lot of questions on the workings and functions of Toyota vehicles. We thought that it would be helpful for our customers if we addressed one of our commonly asked questions here on our blog
    If you’re the owner of a Toyota Tacoma, 4Runner or one of Toyota’s other performance-oriented vehicles, you might notice a button on your console that reads “ECT” on it. Here we’ll be addressing what the Toyota ECT button means as well as its function.
    Electronic Controlled Transmission
    The ECT button in your Toyota toggles the electronic controlled transmission on and off. This transmission system uses hydraulics to actuate the clutches and bands, which are controlled by electronic solenoid, which simplifies the vehicle’s transmission while providing more advanced control.
    With ECT, vehicles offer more elaborate control schemes. Not only does it monitor the vehicle speed and throttle position, the transmission controller can also monitor the engine speed when the brake pedal is pressed but the anti-lock braking system as well.
  3. Oct 15, 2016 at 4:59 PM
    #43
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    HAHA. I thought about the same thing actually.
    Only 1 problem I found: I tried applying +12V directly to the tan wire, and It would not activate. somehow pin 4 and pin 2 must touch.
    I am thinking about running a micro relay---tapping off the start signal wire(purple under dash)
    which will activate a momentary relay making pin 2 & 4 touch. Only think is, I am not sure if the signal is too quick(before the truck has fully started)
  4. Oct 15, 2016 at 5:05 PM
    #44
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    push the ECT button quick at the exact same time you turn the key or push the start button which ever you have. if the ECT indicator is on when the engine starts then might be your answer.
  5. Oct 15, 2016 at 5:11 PM
    #45
    kahanabob
    Maui
    16 TRD 2WD 4DR
    sounds like your idea would keep it always in ECT mode and you would never have the option of not being in ECT.
    i would like to use the folder switch on the right side of the steering wheel to control the ECT. you seen to be knowledgeable about that stuff any idea how to tap into that switch? i never use that switch and do not know what it even does.
  6. Oct 15, 2016 at 5:11 PM
    #46
    MESO
    State of Jefferson
    ^ I just did, hitting ECT WHILE starting works.
    So..this is what I am going to do: just need to go get a micro relay now
  7. Oct 15, 2016 at 10:42 PM
    #47
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I assume the bottom picture is the back side of the ECT switch, and it would be great to find a connector that would plug onto the wiring harness white connector which would make it really easy to run the wiring back to the center console for a relocating a new switch there. I would think that it is some industry standard type of connector.
    AliExpress.com shows some Toyota connectors that looks to be the same style as these. I'm going to do some more searhing and see what I can come up with
    https://www.aliexpress.com/popular/toyota-socket.html
    https://www.google.com/#q=OEM+style+aftermarket+Toyota+electrical+connectors
  8. Oct 16, 2016 at 6:09 AM
    #48
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Subscribed. One of you all finds a plug and play solution to always on ECT, I'm on board to buying it.
    Aussiek2000 likes this.
  9. Oct 16, 2016 at 6:20 AM
    #49
    Sensiman12
    Sensiman12 Well-Known Member
    Nate
    Castle Rock, CO
    2016 Tacoma SR5 4x4 DCSB
    TRD rims Nitto Terra Grappler G2
    Try wiring it as a closed set of contacts instead. Meaning it'll be on every time you start the truck. Then you can hit the button to turn it off. Which would then be an open set of contacts
  10. Oct 16, 2016 at 6:32 AM
    #50
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    One thing to keep in mind is that the signal needs to be a single pulse. If you use a relay and hold it high the ecu will turn ECT off after 30 seconds. Not sure why they engineered that way.
    A simple "one shot" will work.
  11. Oct 16, 2016 at 12:59 PM
    #51
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Can you confirm you have tested this?
  12. Oct 17, 2016 at 4:55 AM
    #52
    scornwel
    Fort Worth
    None
    Yes. I wedge a small piece of paper at startup and it initially came on, but then went off after about 30 seconds.
    I did a second test where I simply held the button in while driving and it did the same thing.
    That's why I'm thinking we need a one shot that produces a single pulse.
  13. Oct 17, 2016 at 5:24 AM
    #53
    Taco16LB
    Taco16LB Well-Known Member
    Would something like this help ?
    https://www.delcity.net/store/Time-....t_1.r_IF3003&mkwid=8TgfXoca&crid=11472933143
  14. Oct 17, 2016 at 10:42 AM
    #54
    scornwel
    Fort Worth
    None
  15. Oct 17, 2016 at 11:20 AM
    #55
    Taco16LB
  16. Oct 17, 2016 at 12:04 PM
    #56
    scornwel
    Fort Worth
    None
    Just ordered one. I'll install this weekend.
  17. Oct 17, 2016 at 12:13 PM
    #57
    scornwel
    Fort Worth
    None
    Not really. This method would toggle ECT whenever the shifter passed through N or the ECT button is pressed. No extra parts are required.
  18. Oct 17, 2016 at 1:04 PM
    #58
    Taco16LB
    Post pics and such ! I hope it goes very easily for you. I bet you could even add an inline toggle switch after ward to choose how you want it to work . IE auto ECT or Not.
  19. Oct 17, 2016 at 1:52 PM
    #59
    scornwel
    Fort Worth
    None
    I'm thinking this will.work. The TD relay can be adjusted 1 to 10seconds.
    MetrickMetal likes this.
  20. Oct 18, 2016 at 5:18 AM
    #60
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    If this does indeed work, it looks like all I'll have to do to relocate another NO momentary ECT switch to the center console in series with the ECT switch in the dash is tap into the 12v+ and ECU wires and run them back to my new switch on the center console.
