ETC Button
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rehabber, Oct 24, 2015.
  1. Oct 18, 2016 at 6:29 AM
    #61
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    I have not pulled the switch. I'm assuming the Illuminate and ground just light the button.
    Or, is pin1 connected to pin2 when the switch is not depressed? This would hold pin2 low until it is depressed.
  2. Oct 18, 2016 at 6:33 AM
    #62
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    I was also thinking that the ground and the illuminate are just for the switch light, and you should be able to send a 12v signal to the tan wire on the wiring harness side and to see if that turns the ECT mode off and on.
    I just went out and turned the ignition on but didn't start the engine and actuating the ECT switch turns the ECT mode on and off, so sending a 12v signal to the tan wire should confirm that this will work.
  3. Oct 18, 2016 at 6:47 AM
    #63
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    ^ already tried that. 12v applied to the tan wire did not work.
  4. Oct 18, 2016 at 6:50 AM
    #64
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Would love to see what you guys end up coming up with for This
  5. Oct 18, 2016 at 7:43 AM
    #65
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I just went back and found that I missed that you had already tried that and that it didn't work.
    I guess for what I want to do of relocating the ECT switch to the center console, if I can't find the same style connectors that would allow me to make up a plug in play wiring extension harness. I'll have to either remove the ECT switch from the dash, cut the male connector that plugs into the switch along with 3 or 4 inches of the wires and solder the connector and wires to extension leads long enough to reach the new switch location on the center console.
  6. Oct 18, 2016 at 7:48 AM
    #66
    scornwel
    Fort Worth
    None
    Ok, so simply connecting pin 2 and pin 4 momentarily doesn't work?
  7. Oct 18, 2016 at 8:03 AM
    #67
    MESO
    State of Jefferson
    I took a jumper wire and touched pin 2-->4, ETC activated. Touched again and it deactivated. But the weird thing is I try and apply regular 12v to that wire(jumped power of the cig lighter for testing) and it didn't do anything.
    It's pretty simple, like my diagram previously... micro relay tapped off the start signal for a monetary pulse, which closes the contacts and jumps the connection between the 2 ETC wires. I just haven't had time to dig into it further
  8. Oct 18, 2016 at 8:13 AM
    #68
    scornwel
    Fort Worth
    None
    Ok so pin4 is also coming from the ecu, not just battery 12v. The ecu must be sensing that two of its I/Os are connected at the same potential.
    So you have to tap the pink wire and run it through the relay per the diagram.
    When the switch is not depressed, are pin1and 2 connected?
  9. Oct 18, 2016 at 8:14 AM
    #69
    scornwel
    Fort Worth
    None
    Anyone find a set of.compatible connectors?
  10. Oct 18, 2016 at 10:35 AM
    #70
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    as i stated in this thread and do not mean to butt in but since you mention relocate how difficult would it be to identify the wire from the folder button in the steering wheel and disable it and make it the ECT button. seems it would be the easiest and clean way and would be right at your finger tips. could always re use the ECT button as the folder button if you can not live without that function. i find this thread very interesting even though it is way over my head......
  11. Oct 18, 2016 at 2:06 PM
    #71
    MESO
    State of Jefferson
  12. Oct 18, 2016 at 3:33 PM
    #72
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I haven't looked that switch on the steering wheel, but I doubt its has the same function as the ECT switch, and I don't know if I want to go to the trouble to find out, and having the ECT located on the center console where I can easily reach it will work for me.
  13. Oct 18, 2016 at 4:37 PM
    #73
    scornwel
    Fort Worth
    None
  14. Oct 18, 2016 at 5:52 PM
    #74
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    I just push the button when I know I'll be climbing a slope.
  15. Oct 18, 2016 at 6:13 PM
    #75
    MESO
    State of Jefferson
    Okay UPDATE*****
    Weirdest thing,
    Started/drove fine after I ran a few errands. On the ~3rd start cycle I put it in gear and got a check engine/trac control light on.:frusty:
    Truck still drives normal.. so I unhooked battery and did a quick reset, All clear.
    I have unhooked it from the purple "start signal" wire until I can re-evaluate it.
    Not sure if ECT is turning on too soon before the truck fully starts, or if there is some data in that start wire(shouldn't)
    I am going to try to activate it a different way.maybe tag off nuetral light so every time I put it in gear ECT turns on.
    Back to the drawing board... SOO close!
  16. Oct 18, 2016 at 6:16 PM
    #76
    scornwel
    Fort Worth
    None
    Dude that blows. Thanks for posting up. I was going to mod this weekend, but maybe on the N or R tap.
  17. Oct 18, 2016 at 6:18 PM
    #77
    MESO
    State of Jefferson
    I left everything connected just pulled the tap off START wire. Truck is fine. I'm thinking the ECT is turning on way too soon before anything has a chance to boot up. I am going to go off R or N, so the truck has time to "start up" before activating ECT mode
  18. Oct 18, 2016 at 6:20 PM
    #78
    Aussiek2000
    2016 Offroad AC
    Just need a timed relay and use any ignition 12v feed.
  19. Oct 18, 2016 at 6:21 PM
    #79
    scornwel
    Fort Worth
    None
    I won't have time until this weekend. Keep pathfinding for us man!
    I'll try the TD relay approach this weekend.
  20. Oct 18, 2016 at 6:22 PM
    #80
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    If that's the case maybe you'll have to try the adjustable timer
