Ethanol free gas hurts?!?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lwszabo, Oct 24, 2016.
  1. Oct 24, 2016 at 5:38 PM
    lwszabo
    lwszabo [OP] Well-Known Member
    Concord NC
    2018 SR double cab
    toyota dark satin alloy wheel Tint OEM bed mat
    I have a 2008 2.7 regular cab automatic. It has 60,000 miles and runs great! Today I decided to put ethanol free 87 octane gas from QT in it. (I use it in all my small engine yard equipment)
    I had a guy next to me say I'm hurting my engine by using ethanol free since my truck was designed to run with ethanol. I searched here and on google but can't figure out what I could be hurting!
    Any advice?!
  2. Oct 24, 2016 at 5:40 PM
    Pigpen
    Dan
    Northwest Montana
    Bullshit.
    /thread
  3. Oct 24, 2016 at 5:44 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    They guy is incorrect, ethanol isn't that great for your engine and fuel lines. If it was why wouldnt there be higher percentages in fuel.
  4. Oct 24, 2016 at 6:48 PM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    100% Gas is GOOD!!
  5. Oct 24, 2016 at 7:11 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That guy is insane, you need new car guys to talk to.
    scottalot likes this.
  6. Oct 24, 2016 at 7:57 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Would be odd that if the gas is worse then why is it more expensive? Tell him to add some sugar to his gas tank it really helps out the MPGS
  7. Oct 24, 2016 at 8:15 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Simply put, he's confused.
    Beyond E10-15, fuel systems and drivetrains have to be specially modified or calibrated for the higher EtOH content of the gasoline. Although having a higher octane number, EtOH has less energy per gallon than naphtha/gasoline and is hygroscopic, hence the requirement for special modifications and calibration. This is where your FFV come in: they can use up to E85.
    Ethanol was initially used as an immediate alternative to MTBE when MTBE was phased out.
    TL;DR
    Your engine can use E10 gasoline without issue as it requires the ethanol for the correct octane* and the ethanol percentage is low enough as not to cause issues with your vehicle.
    *the gasoline was blended this way at the refinery. There are other ways to obtain the needed octane number using other refinery blendstocks, which is the type of gasoline you bought from QT.
    But there are. Case in point: most gasoline is considered E10, but we as consumers can purchase up to E85 (50-83% EtOH).
  8. Oct 24, 2016 at 8:35 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Not all vehicles were set up for E85, and yes I agree the fuel systems have to be set up to accept higher ethanol percentages. I know Ford has E85 vehicles, but does Toyota offer any yet?
  9. Oct 24, 2016 at 8:54 PM
    Biscuits
    Several manufacturers offer FFV, but to be honest I'm not sure if Toyota does or not. If they did, they're probably Tundras and the like. I'm certain Tacomas aren't, which is what I think you were alluding to in your original post. :)
  10. Oct 24, 2016 at 9:12 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    No just general a question.
  11. Oct 24, 2016 at 9:19 PM
    Biscuits
    Just googled it. Looks like the 5.7L offered in the Tundra and Sequoia can be Flex Fuel.
  12. Oct 24, 2016 at 9:35 PM
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    That is correct there is flex fuel option for 5.7. Im glad mine is not.
  13. Oct 25, 2016 at 8:54 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Not hurting anything but your wallet. I'd might be concerned about a steady diet of E85 in a truck even if designed for it. But we've been using gas with 10% ethanol for quite some time now. I can't see that it helps or hurts, lots of high mileage vehicles that have run it. My truck runs just fine with regular gas and it is a lot cheaper. Never had any issues with it in my lawn equipment, generator or ATV either.
  14. Oct 25, 2016 at 9:06 AM
    badmonkey
    badmonkey Active Member
    Bryan
    NW NC
    2015 Taco
    None, yet.
    Ethanol is actually good for your engine. It will help prevent or even clean carbon deposits. It isn't great for older lines as they were not manufactured using materials designed for ethanol. Clearly that is no longer an issue. The biggest problem switching from one to another, and this is where people complain, is tuning. Eth or eth free may perform differently depending on said tuning which leads some to conclude one or the other is bad. The cause is the tuning not the fuel. Actually, more power can be made by ethanol. Ask any alcohol drag car guy about it. There are numbers across the net claiming there is less available chemical energy in alcohol. That is true on the surface. But it isn't the whole story. Alcohol has a superior mechanical energy output under combustion. Gasoline has higher losses to heat energy.
    So why not go to higher alcohol content and tune accordingly? Supply and demand. Gasoline is readily and quickly available. More so than ethanol. Current eth content is a happy medium of the availabilities vs supply and costs.
    Nateclimb likes this.
  15. Oct 25, 2016 at 9:08 AM
    dedmouse
    dedmouse Well-Known Member
    Dammit
    South Central Missouri
    2010 Black Tacoma Base, 6 spd manual tranny, V6.
    He's probably a corn farmer
  16. Oct 25, 2016 at 9:47 AM
    Biscuits
    Wat.
  17. Oct 25, 2016 at 9:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Would you take advice from 'a guy' at the pump next to you regarding your next stock purchase?
    For goobers like that one, I'd just smile and say thanks for the tip man!
    Just like I would the stock advisor.
    Like most political speeches, there are just a couple of nuggets of truth mixed in here which could make the rest of the misinformation seem plausible. However, my glasses are fogging from the steam off the pile.
    Says the guy that's familiar with the E85 race boys. Which has absolutely 0 to do with a factory street vehicle, like our untunable, unboosted trucks.
    PzTank, nv529, Norton and 2 others like this.
  18. Oct 25, 2016 at 9:58 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    No, no it isn't.
    No.
    They use methanol.
    At the end of the day gasoline has more energy per volume then ethanol, no two ways around it.
    TacomaArto, llibrm and Biscuits like this.
  19. Oct 25, 2016 at 10:08 AM
    badmonkey
    Bryan
    NW NC
    2015 Taco
    None, yet.
    Ok gentlemen. Post numbers to prove mw wrong.
  20. Oct 25, 2016 at 10:16 AM
    Biscuits
    How about this:
    I am a consultant to refiners, and specialize in crude units and finished fuels, which includes gasoline.
    You can't break chemistry and physics, bro.
