ethanol free gas vs ethanol mix gas??? for tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sethhawaii, Sep 30, 2016.
  1. Sep 30, 2016 at 4:17 PM
    #61
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I tend to chart mileage. Next ethanol free fill up, I'll compare it to an e10 run from last September. I run the same route every week.
  2. Sep 30, 2016 at 6:26 PM
    #62
    sethhawaii
    sethhawaii [OP] Well-Known Member
    2016 TRD offroad 4x4
    nice post what you get. my tank is empty im gonna go fill it up with EF too
  3. Sep 30, 2016 at 8:21 PM
    #63
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Promise to up road from kam center off like like.
  4. Oct 17, 2016 at 5:30 AM
    #64
    MadDaddy
    Many & varied
    Okay update: I've run two tanks ethanol-free. 21.1 gallon tank. 2013 Dcsb taco. 37,500 miles. Haven't swapped plugs yet. Regular, not synthetic oil. 3" lift, 265/75/16 AT tires, 100lbs est. bolt-ons. Volant CAI, Magnaflow single exhaust. 75% highway, 25% city driving. Mostly between 35-65mph. I observe posted speed limit.
    Tank 1: 18.9mpg, 399 mile range
    Tank 2: 19.6mpg, 413 mile range
    I just filled up with ethanol-free. Will post those results when I get them. What I've done is recovered my lost mileage after the 3" lift, 100lbs of armor & baskets, and swap to 265/75/16 AT tires over stock Dunlops. I never posted mpg data post-lift because it was so embarrassingly blatant what I'd done to myself. I lost 25% of my mpg and range overnight. Now I'm back to ethanol-blended stock mpgs. If I hadn't modded my truck, my numbers would look GREAT. Still, coming from an '04 F150, 19+mpg is very appreciated.
    While I won't be in the market for a new vehicle for another 10 years, I look forward to seeing what the 2018 Ranger and Bronco look like and what numbers they produce. Gas is starting to climb again and I doubt we'll ever see it dip like it did last year. Our next family vehicle will be a Subaru Outback to replace our 160,000 mile '04 turbo VW Passat wagon.
  5. Oct 17, 2016 at 6:21 AM
    #65
    FLYH2O
    FLYH2O Well-Known Member
    2016 Tacoma TRD Sport Blue
    The only reason we are all force fed this crap in our fuel is because of a heavily Gov subsidized farm industry. The farmers pump an over abundance of corn in to the market so the Gov must find ways to make the product viable for the farmer. Burn it in cars, put it in all the food we eat. Its bad for both human consumption and an engines fuel system.
    The reason the E10 or 10% Corn Alcohol destroys fuel systems is it adsorbs water from the atmospher of a short period of time. The seals and surfaces in the fuel system corrode and rot when all that water mixes with the fuel. Pull your lawn mower or brush cutter carb off and you will see pink gum and white paste all through it I bet. I don't care what magic rubber and metals the cars use now to help us run E10. The systems and gasoline don't like water.
    In a car thats run every week its not a big deal but if you own a classic car or and carb fed seldom used motor don't run E10 fuel.
    sethhawaii[OP] and Taco16LB like this.
  6. Oct 17, 2016 at 7:40 AM
    #66
    Threerun
    Threerun Well-Known Member
    Lost in Montana *recalculating*
    2016 Silverado LTZ
    6.2L 8spd stock
    Recently I tried ethanol free gas in my rig. 3 tankfulls. However the only EF gas available is 91 super, so it's spendy. Lowest price was $2.90 p/gal. However- I am seeing almost 2mpg increase in efficiency. Financially not worth it.
    If they had EF in lower grades I'm sure I would run it.
  7. Oct 17, 2016 at 7:53 AM
    #67
    MadDaddy
    Many & varied
    Some stations around here have ethanol free mid-grade. With my Kroger "savings" card, I get an additional .10 off, which makes it comparable to buying high grade fuel.
  8. Oct 17, 2016 at 7:58 AM
    #68
    Threerun
    2016 Silverado LTZ
    6.2L 8spd stock
    I wish. There are 6 stations with EF gas in my town- all of them are premium only.
  9. Oct 17, 2016 at 8:00 AM
    #69
    ChasVS
    ChasVS Well-Known Member
    2017 Tacoma ACLB TRD Off Road
    Minor point here. All these fuels are unleaded. So I assume you meant you just filled up with Ethanol blended unleaded? Also assume it's the normal 10% blend at 87 Octane?
  10. Oct 17, 2016 at 8:19 AM
    #70
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    What another fucking joke of nowadays - paying extra to have something left out. Stupid bullshit.
    Hattr1ck and sethhawaii[OP] like this.
  11. Oct 17, 2016 at 8:22 AM
    #71
    Threerun
    2016 Silverado LTZ
    6.2L 8spd stock
    Well E-10/e-15 has become a 'standard', so not using it requires more work at the refinery.
    Bullshit I know. But that's the way it is.
  12. Oct 17, 2016 at 8:32 AM
    #72
    maypearl
    maypearl Well-Known Member
    Joe
    Maypearl, TX
    17 Taco DCSB 4X4, 16 Canyon Diesel 4X4 SLT
    Ed Wallace at www.insideautomotive.com has been on Ethanol from the beginning. He is a very smart guy, that doesn't have a dog in the hunt, and actually researches issues to death, before speaking about them. He claims the fuel economy is much less with Ethanol and it ruins lawn equipment. I'm sure he has some great info on his website.
  13. Oct 17, 2016 at 8:41 AM
    #73
    Taco16LB
    Taco16LB Well-Known Member
    Ethanol is added via the tank delivery truck , not at the refinery
    robssol likes this.
  14. Oct 17, 2016 at 8:49 AM
    #74
    MadDaddy
    Many & varied
    Both documented tanks are ethanol free, purchased at the same station found using http://www.pure-gas.org/
    I've just filled up with E10 87 octane. I've previously charted 3-tank averages using base, mid-level and premium unleaded e10, finding premium to be a waste of $, giving me 1.5 more mpg on average.
  15. Oct 17, 2016 at 10:26 AM
    #75
    Threerun
    2016 Silverado LTZ
    6.2L 8spd stock
    Yup- my bad- fuel blenders add it. However I think the fact that EF is 'non-standard' creates the premium cost spread seen at the pump.
  16. Oct 17, 2016 at 11:33 PM
    #76
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Ethanol free is usually higher octane which is more expensive to manufacture. And ethanol is government subsidized, so they will tell you they are passing the savings on to the consumer.
  17. Oct 18, 2016 at 3:08 AM
    #77
    Tampa Scott
    Tampa Scott Active Member
    2016 Tacoma TRD sport
    In a boat, lawn enjoyment, older cars always use non ethanol. In new cars no unless they're going to sit for an extended amount of time.!
  18. Oct 18, 2016 at 3:13 AM
    #78
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Octane is octane and then it's watered down with some bullshit we don't need that does no good and then have to pay more for it to be left out. Short bus logic.
  19. Oct 18, 2016 at 4:27 AM
    #79
    robssol
    Rob
    S. Wisconsin
    Nothing is "left out" it's still there, they just add the ethanol (remembering gasahol?) they sell 10% less gasoline (replaced by ethanol) that's why the lower octanes cost less.
    And yes ethanol is shit we don't need!
  20. Oct 18, 2016 at 7:35 AM
    #80
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    ethanol is "left out" of ethanol free gas and it costs more to buy.....that is the bullshit I am referencing. Leaving something out should cost less not more no matter what the topic is. It'd be like paying fully loaded price for a base model truck because they left out more features.
