Ethanol-free gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BRUCEB, Apr 29, 2013.
  1. Apr 29, 2013 at 7:30 AM
    BRUCEB
    BRUCEB [OP] Well-Known Member
    CENTRAL MISSOURI
    2012 CREW CAB TRD
    Has any body used ethanol-free gas in there Tacoma's;and if you have,any better fuel milage?Going to do alot of travling this summer,and was wondering about this.I have a 2012,dbl cab.
  2. Apr 29, 2013 at 7:38 AM
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    I use ethanol free gas. I haven't noticed a difference in mpg, but it calms the "toyota tick".
  3. Apr 29, 2013 at 7:41 AM
    bl78
    bl78 Member
    KC
    2013 Tacoma DC Sport
    I use non-ethanol gas and get around 20mpg. When I revert back to ethanol, I get arount the 18 mpg
  4. Apr 29, 2013 at 7:42 AM
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    I use it when I'm close to a station that sells it. On average I probably get 1mpg more with E0 and my truck runs much smoother.
  5. Apr 29, 2013 at 7:53 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    Just got my Tacoma, so I haven't had a chance to really put it through tests, but I know my Mazda 3 Hatchback gets right at 300 miles to a tank (or less) on ethanol gas and close to 350 miles with no-ethanol. I stick with no ethanol if possible. I'll put ethanol in it when I'm not able to find a place with pure. I definitely notice a difference.
  6. Apr 29, 2013 at 8:31 AM
    BRUCEB
    CENTRAL MISSOURI
    2012 CREW CAB TRD
    I'm hoping that I'll pick up 2-3 mpg.Last trip I took,3 weeks ago,I got 16.4,16.6,18.4,on the road.got 15.5 in the city the tank before those.I'll take any help I can get,as long it don't cost more.
  7. Apr 29, 2013 at 8:33 AM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Where do u get non ethanol?
  8. Apr 29, 2013 at 8:35 AM
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
  9. Apr 29, 2013 at 8:49 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Ethanol gas costs more. Its usually 10-20 cents more per gallon where I live.
    Just look around. Where I live, stations put up big banners or have it on their sign "No Ethanol" or "100% pure gasoline" or something like that. Some stations even have some pumps where you can choose if you want "100% gas" or "up to 10% ethanol". Its random, but in my area there are plenty of no ethanol stations. I know which ones have "good gas" compared to ones that don't.
  10. Apr 29, 2013 at 8:49 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Always get better mileage when in Mexico, no ethanol added there.
  11. Apr 29, 2013 at 8:58 AM
    BRUCEB
    CENTRAL MISSOURI
    2012 CREW CAB TRD
    There's a couple of stations here that has it.Hy-vee has it,30 cents/gal more.Probley won't fill with it unless going out of town,unless it's makes a big difference in my town mpg.Thought I'd give it a try for a couple of trips.
  12. Apr 29, 2013 at 9:19 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I'll add this tidbit. My '86 SR5 4x4 manual absolutely HATES ethanol, to the point that it will nearly die while shifting gears because it runs so rough with it. It doesn't idle well and for some reason it is worse when its super hot outside (100+ degrees). I couldn't figure out what was causing it until I switched to no ethanol. It cleared the problem right up.
    I've read that older cars run worse with ethanol because it burns hotter than pure gasoline. More tolerance in the engine coupled with hotter temperatures can make the valves rattle a bit more, it runs rougher, and has less power/efficiency. I avoid ethanol when possible, ESPECIALLY in older vehicles. My wife's VW Passat doesn't seem to mind ethanol, though. It gets about the same mileage with ethanol or non-ethanol gas.
  13. Apr 29, 2013 at 9:26 AM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    Only places I see it are close to water - boats and ethanol don't mix well. I was in Tallahassee last year and a lot of stations down there were advertising it - they're only about 45 minutes from the Gulf.
    Ethanol leans out the mixture, so you need to richen up the A/F to get it to run "right" - hence the better MPG when on the pure stuff. Modern cars can handle the 10% (or E85 for some), but older cars don't like it.
  14. Apr 29, 2013 at 9:48 AM
    iliketurtles
    iliketurtles Well-Known Member
    I don't know exactly how much better it was, but my mileage did improve while using pure gas with no ethanol.
  15. Apr 29, 2013 at 9:52 AM
    fou
    fou Member
    TN
    '13 MGM DCLB 4x4 TRD Sport
    I have been wondering about which is better, using ethanol-free gas that is a no-name brand or using a "top-tier" branded gas that is supposed to be better with extra additives and whatnot.
    There are a several ethanol-free stations around where I am, but only one or two are from a known brand of gas. Oh the dilema...
  16. Apr 29, 2013 at 9:56 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I've heard that a lot of gas comes from the same refineries, and that some places basically "guarantee" the gas when the slap their name to it. I could be wrong about that, though.
  17. Apr 29, 2013 at 10:05 AM
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    Find non ethanol fuel. Use it. Enjoy the 3-5MPG gain from using it.
    Workman
  18. Apr 29, 2013 at 10:19 AM
    TSmalls89
    TSmalls89 Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    Plan on using non-ethanol based from now on.
  19. Apr 29, 2013 at 4:36 PM
    bubba353z
    Columbus, Oh
    I think E85 cars have yellow gas caps.
    Definitely don't want to make that mistake....
  20. Apr 29, 2013 at 4:43 PM
    bubba353z
    Columbus, Oh
    I think you might be a little optimistic there.... I can see 1-2, but not that much more.
