Ethanol-free gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BRUCEB, Apr 29, 2013.
  1. Apr 29, 2013 at 5:04 PM
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    Negative.
    Workman checks his mileage with every fillup, and tries to only use NON ethanol gas, 91oct which he can purchase at his local gas station.
    When Workman could not find non ethanol gas, he got from 17-19mpg. Using non ethanol gas, Workman gets 21-23.5MPG. Thus 3-5MPG more.
    Workman loves the MPG he gets on his Taco using non ethanol fuel.
  2. Apr 29, 2013 at 5:15 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I only use it on my small engines. Motorcycles, lawn mower, weed eater, pressure washer, etc.
  3. Apr 29, 2013 at 5:23 PM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    :confused:
    Uh - OK
  4. Apr 29, 2013 at 7:11 PM
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    I've used both, pure gas and 10% Blend, and the key to getting better MPG with Ethanol blended fuel is buying from a station the sells a lot of gas so their supply is fresh. The longer anything with alcohol sits the more moisture it draws to it.
    I try and use pure gas as often as I can in my 2013 TRD Supercharger equipped dbl cab but I've actually got my best over the road fuel mileage, 22.7MPG, with Chevron 10% Ethanol Super Unleaded.
    More important than which fuel you use, with regard to fuel economy, is keeping the RPM under 2000. If you can keep it at a constant 65mph you should get 20-22 pretty easy and if you can handle only driving 60 for the duration of a freeway trip I'm sure I could get 22-24. The hard part isn't deciding which fuel to burn, it's the painfully slow driving one must endure if you want to get into the 20's for MPG...:rolleyes:
  5. Apr 30, 2013 at 4:07 AM
    bubba353z
    Columbus, Oh
    Perhaps, but I can't take anyone seriously when they want to refer to themselves exclusively in the third person.
    I wouldn't consider his results typical.
  6. Apr 30, 2013 at 5:30 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If there is 10% ethanol in the fuel and if the ethanol had no energy value at all the best case would be 2MPG if you got 20 MPG normally. You would be lucky to gain .5 MPG Ever wonder why they run alcohol in race cars? If you are using a super charger or turbo you are better off with some ethanol in the blend.
  7. Apr 30, 2013 at 5:35 AM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    Yeah well, would you believe that in the greater Houston area there's not ONE damned ethanol-free service station? WTF?????
  8. Apr 30, 2013 at 5:51 AM
    Turdburglar
    Turdburglar Well-Known Member
    Enola, PA
    '10 DCSB SR5
    Trifecta, AVS Bugflector, TRD skid plate, 45% tint front windows, Gerber carseat lol
    The way I figure, if I pay ~10% more for ethanol-free gas, and get 10%+ better fuel economy, then its worth it. The added power is the icing on top.
    Also, my lawn mower and string trimmer greatly prefer the ethanol-free stuff FWIW.
  9. Apr 30, 2013 at 5:55 AM
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    Seat-of-the-pants fuel testing is a waste of time. There is too much variation in the chemical makeup of pump gasoline to provide statistically significant results. Even with identical fuel (no such thing outside the lab, even at the same fuel station) there is too much variation in driving conditions to provide statistically significant results.
    A study with sufficiently rigorous scientific methods showed (with 95% accuracy) that gasoline containing 10% ethanol (E10) reduced fuel economy by 3.68 ± 0.44 %, or 3.24-4.12%. Using 20 MPG as the baseline on 100% gasoline, the expected fuel economy on E10 would be 19.176-19.352 MPG.
    http://feerc.ornl.gov/pdfs/pub_int_blends_rpt1_updated.pdf
    Unsurprisingly, this is just about what the BTUs per gallon of fuel would lead you to believe.
    http://en.wikipedia.org/wiki/Gasoli...ine_Gallon_Equivalent_.28US_Gallons.29_tables
    The difference between the theoretical calculation and actual performance can probably be explained by the fact that we have fixed-compression-ratio engines that cannot be adjusted to wring the best performance from ethanol blends, which can be used safely at higher compression ratios (for better efficiency) than pure gasoline.
    Calculating miles per dollar is a simple task. As a general rule, at $3.50/gallon for pure gasoline, E10 would have to be about $0.13 less, or $3.37/gallon to reach the same miles/dollar cost.
    When I lived in Arizona both 100% gasoline and E10 were widely available. The miles/dollar ratio was not always in favor of pure gasoline. Here in NH, there is virtually zero pure gasoline available for motor vehicles, and precious little for boats, so there is no opportunity to decide in favor of either.
  10. Apr 30, 2013 at 7:09 AM
    Workman
    Thanks, Workman only wants to provide the TW community with the information he has gathered from 6 years of Taco ownership. Workman does not think it should matter if he responds in 1st or 3rd person as long as the info is helpful and relevant to the OP's thread.
    If Workman's posts are too hard for you to read, comprehend, or believe then put him on your ignore list or dont read the post. Nobody is forcing you to read/respond to anything on the interweb, it is your own choice to do so. Workman does not talk in third person in real life FYI.
    Back on topic, Workman has done many real life experiments using ethanol based fuel and non ethanol based fuel in different makes of cars and trucks. Gas that contains ethanol ALWAYS yields lower MPG.
    Workman also does not switch from one to the other expecting the gains to show immediately. If you are running fuel with ethanol in it, empty the tank almost completely, and fill up with non ethanol fuel, you might not see the benefits immediately on that first tank. Workman believes the computer on your truck/car has to adjust to the changes in fuel which could take a tank. Though in every occasion a gain in MPG will be noticed, big or small.
    If you run non ethanol fuel in your Tacoma tank after tank, you WILL see your MPG go up, maybe up to 4-5mpg more. 2 other Taco owners Workman knows have tried this experiment and have noticed the same gains as Workman.
    Workman goes out of his way on trips out of town to buy fuel from stations that sell straight gas in order to keep his Taco happy and to save money on road trips. PUREGAS.ORG is a great way to locate these stations and map out a road trip. In Workman's case, the difference is as substantial as getting 320 miles to a tank to 400+ to a tank. Workman got 436 miles out of 19.2gallons once, and can always get 400 miles per tank when consistently using straight gas. No bouncing back and forth between straight gas and ethanol gas is KEY.
    Hate all you want, Workman is only providing real world experience using straight gas. 21-23.5MPG constantly for a 4.0 4x4 auto pickup is pretty kick ass IWO. Workman's average though the years in 22MPG, and he has only seen 17-19 when he is forced to use ethanol gas.
    Oh, and Workman only uses 91 oct.
  11. Apr 30, 2013 at 7:24 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Ethanol is bull shit! Those stupid corn farmers have us by the balls!
  12. Apr 30, 2013 at 10:54 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I call it Corn Grease, and I avoid putting it in any car that I love. Luckily, living in Oklahoma allows me to choose which variety to put in my car.
    I see about a 5 mpg difference in my Mazda 3 hatchback. I haven't done enough testing in my new (to me) Tacoma.
  13. Apr 30, 2013 at 12:27 PM
    B11
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    B11 didn't know these Tacoma's were equipped with a "Self Learning" ECU/ECM. :rolleyes:
    B11 hasn't noticed much difference in MPG between using pure gas and ethanol blended premium but when B11 can't get pure gas B11 tries to always buy ethanol blended fuel at a high volume station. B11 likes his gas to be "fresh". See, I can do it too... ;)
    Anybody remember the "Jimmy" Seinfeld episode??? Watch Jimmy run! Watch Jimmy jump! LOL
  14. Apr 30, 2013 at 1:11 PM
    Drakivnsf
    Drakivnsf Dance Party Guru
    Socal
    '12 White Tacoma DCLB 4x4
    TRD Supercharger, URD CAI, BRP pre-axle catback, Anytime Rearview Camera mod, Power Sliding rear window, Glassworks Unlimited Front Fenders, ScS Stealth 6 wheels, Nitto Terra Grapplers 285/70/17, 3" All-Pro Std Leafs, 2.0 Fox adj. res. shocks, 2.5 Fox res. Coilovers, All-Pro +2" LT kit, Timbren Bumpstops front and rear, All-Pro U-Bolt flip kit, Pelfreybilt Hybrid front bumper, RCI IFS Skid, RCI Sliders, more to come.....
    Lame, so-cal has none......
  15. Apr 30, 2013 at 2:24 PM
    #35
    Larry
    Larry CARL
    CARL
    Incorrect
    The farmers are only taking advantage of an opportunity provided by the federal government.
  16. Apr 30, 2013 at 2:29 PM
    #36
    Larry
    Larry CARL
    CARL
    Florida is moving to repeal the state law requiring ethanol fuel.
  17. Apr 30, 2013 at 4:27 PM
    #37
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    it sucks.. I rather have reg base gas with 89 octane.. runs better and burns less. I use this more offen in winter due to "winter grade gas". I also use fuel treatment to keep the engine clean during the winter.
  18. Apr 30, 2013 at 4:33 PM
    #38
    Larry
    Larry CARL
    CARL
    there is a reason why Florida is trying to make this happen and California is not...but we are not allowed to have that conversation on this forum. :D
  19. May 1, 2013 at 4:30 AM
    #39
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Won't happen.
  20. May 1, 2013 at 4:35 AM
    #40
    Larry
    Larry CARL
    CARL
