Ethical Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, Mar 13, 2022.
  1. Mar 13, 2022 at 6:28 PM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    So let's pretend your truck has intermittent instances when it plain won't start. Turn the key and nothing, no sound at all. Maybe once a month or every 100 or so starts. No rhyme or reason in terms of engine temp/distance travelled but if you wait a bit (insert random time) it will start up as normal.
    You take the truck to the dealer and they check all the usual suspects; battery, starter etc and they hook it up and nothing. The service guy shrugs says it was probably a freak thing or maybe a bad ECU. So you continue living your life and it continues to happen rarely.
    You don't like the uncertainty of turning the key and not knowing. It's like living a bad game show. You take it to an independent mechanic and they basically say maybe the ECU is bad but they don't know.
    Do you sell this and not disclose the issue.....asking for a friend
  2. Mar 13, 2022 at 6:36 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    You already know the answer to this.
    WOODY2, Naveronski, eddyizm and 20 others like this.
  3. Mar 13, 2022 at 6:37 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Sounds like the contacts in the starter.
    $20 fix, minus the pain in the ass of starter removal.
  4. Mar 13, 2022 at 6:40 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Maybe I'm "old school", but, YES - disclose the issue in detail (just as you posted) and disclose that the dealer has been unable to diagnose the problem, it's intermittent and let the buyer decide.
  5. Mar 13, 2022 at 6:40 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    What year and miles?
    Just curious
  6. Mar 13, 2022 at 6:52 PM
    MikeDeason
    2015. Under 50k. TRD Sport DBL LB 4X4
    Slashaar likes this.
  7. Mar 13, 2022 at 6:55 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Sell it to a dealer.
  8. Mar 13, 2022 at 6:57 PM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Is it an automatic? If so move shift lever to neutral and try again.
    Gunshot-6A and Nickinmd like this.
  9. Mar 13, 2022 at 6:59 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I’d just keep rolling the dice every day
    Kyle14Taco and Travlr like this.
  10. Mar 13, 2022 at 7:04 PM
    MikeDeason
    this is my friends thinking. Still poses an ethical question but it’s one step removed so perhaps a less severe level of hell would await in the afterlife.
    it’s an automatic and yes the starter is good and was cleaned.
    Blue_Steel_Taco likes this.
  11. Mar 13, 2022 at 7:10 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Gotta admit, if the dealer was sending it to auction (aka shitbox heaven) I might be tempted to think differently.
    At 50k, most dealers will keep it, detail it and flip it to an unsuspecting sucker. And that doesn't sit as well with me for some irrational reason.
    I'd fix it or private sale with full disclosure.
  12. Mar 13, 2022 at 7:17 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Intermittents can be a pain but if you catch it acting up and have a test light handy it shouldn't be hard to diagnose.
    The starting circuit is relatively simple, ignition switch, neutral safety switch, starter relay, wiring, and starter is all there is, no modules involved.
  13. Mar 13, 2022 at 7:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The answer is “Can you live with the choice you make?”
    Some times, the choices we make can affect others.
    It’s in your hands my man.
    I am with @Rock Lobster
    That truck isn’t likely to end up at a place where problems can be expected, such as at an auction.
    It will end up on a lot with a price tag in the mid-$20k or more. No Bueno for the new owner.
  14. Mar 13, 2022 at 7:21 PM
    szidls
    szidls Well-Known Member
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    Key switch assembly?
    b_r_o and Toyko Joe like this.
  15. Mar 13, 2022 at 7:25 PM
    SaratogaTaco
    SaratogaTaco Well-Known Member
    If you decide to sell, disclose the intermittent start issue and sell at a fair price with this in mind. Some people would like to take on a minor issue like this and feel like they got a good deal once the problem is solved.
    wi_taco, michael roberts and Dm93 like this.
  16. Mar 13, 2022 at 7:31 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    1st choice, just find the issue and fix it. It's a good truck. Fixing one issue will be better than buying another truck with new ones.
    2nd choice, sell it to a scumbag dealer offering high prices right now. Say as much as they would say.
    3rd choice, absolutely disclose it to a private buyer. Of course. No debate.
    That said, the first choice would be the only way to go, in my humble opinion.
    Squirt and Dm93 like this.
  17. Mar 13, 2022 at 7:38 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    2015 is the last production year. What’s the date of mfg on? Could it be they used subpar wiring harness parts in the last trucks manufactured?
    how many keys on your keychain?
  18. Mar 13, 2022 at 7:49 PM
    MikeDeason
    Believe there were 3 but only 2 exist now
    not sure how it’s “simple fix” since a dealer and independent mechanics only diagnosis is faulty ECU after checking everything else.
  19. Mar 13, 2022 at 7:51 PM
    TnShooter
    Deogee
    STOCK
    Did the truck NOT start when it was at the dealer or Independent shop?
    If the truck was fine and started all the time when the dealer had it, they couldn’t fix it.
    Diagnostics take time, time is money.
    That’s the unfortunate truth.
    I needs to be “broke” before you can fix it.
    Gunshot-6A and Dm93 like this.
  20. Mar 13, 2022 at 7:55 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not sure how they came to that conclusion since there's no electronic modules involved in engaging the starter, only 2 switches, 2 relays, and wiring.
    Sounds like they are just guessing at it if they can't duplicate the problem.
    Toyko Joe, blu92in99 and TnShooter like this.
