Evac before heater core replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by genuine, Nov 11, 2014.
  1. Nov 11, 2014 at 1:55 PM
    genuine
    genuine [OP] Active Member
    Calgary, Alberta, Canada
    Bilstein 5100, AAL, Deckplate Mod, Magnaflow Cat-Back
    Hey there,
    Does anybody know if an a/c evac is 100% necessary before changing heater core (not saying I wanna vent it - just work around)? This thread ( ) seems to indicate that it can be done without messing with the a/c...
    Thoughts?
    Thanks
  2. Nov 11, 2014 at 2:33 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    only if the evaporator must be removed to do it and I highly doubt it.
    the heater core is strictly a water hose operated system and the a/c is not connected to it at all so unless its in the way or something you don't have to touch it. once you start disconnecting and reconnecting the a/.c system you can never seam to stop the slow leaks needing Freon every year afterwards
