Evans Creek
Discussion in 'North West' started by krzfastest2010, Sep 24, 2010.
  1. Sep 24, 2010 at 4:16 PM
    krzfastest2010
    krzfastest2010 [OP] Active Member
    Tyler
    Seattle
    01 sr5 v6 lifted
    Hey guys does any one know much about evans creek if so what are some good easyer trails i am thinking about heading up there sunday?
  2. Sep 24, 2010 at 5:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Its been several years since I was there but as I recall most of the trails there are better suited for shorter wheelbase vehicles. Not sayin you can't make it through.
    Hell, I used to take my old truck ('98 XC) on many of them. But I was young and foolish back then. :D
  3. Sep 24, 2010 at 7:03 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Unless somethings changed in the last 10 or more years, Evans creek and jeep is fine. In your Taco you can definitely expect some sheet metal dents. I used to ride my Quad there. Great place but lots of deep ruts, roots, trees, and rocks.
    If you were looking for some place close and just a bit easier, Elbe Hills would probably be just a bit better. More wet, but the trails are a bit wider.
    good luck. Ken
