EVAP Check Engine Codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Nov 3, 2019.
  1. Nov 3, 2019 at 7:06 AM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    So I went to pull some ABS and Brake codes this morning and was reminded of some Check Engine codes that I had been ignoring because they were just emissions codes that didn't appear to be causing any immediate issues.
    CODES:
    P0452 Evaporative Emissions Systems Pressure Sensor/Switch Low Input
    P043E Evaporative Emissions Systems Leak Detection Reference Orifice Low Flow
    P043F Evaporative Emissions Systems Leak Detection Reference Orifice High Flow
    P02401 Evaporative Emissions Leak Detection Pump Stuck OFF
    P02402 Evaporative Emissions Leak Detection Pump Stuck ON
    P24129 Evaporative Emissions Systems Pressure Switching Valve Stuck ON
    What's the likely remedy(s)?
  2. Nov 14, 2019 at 10:25 PM
    silver2010
    silver2010 New Member
    2010 silver tacoma TRD
    3" lift
    I have the same issue...when I purchased the truck 4 years ago from Toyota dealer, check engine showed up a few days after.
    Went back and was told Its a filter that cost 710$. Needless to say they came up with some fine print saying it wasn't covered on my warranty.
    I got a OBD to clear to bogus code as even the dealer doesn't know how to fix it.
    lately, I've had some issues when I start the truck. Changed my Battery, Just changed spark plugs. 143K and still original.
    Always get same codes last 4 years. Gravel roads or off-road seems to piss off something.
    Humidity and rain is when I have the most issues. I have all the same codes as you. But this week I got a new one P2419
    Curious to see if you get info on this...sorry I cant help
    Freeheelbillie[OP] likes this.
  3. Nov 14, 2019 at 10:31 PM
    Bishop84
    Bishop84 Well-Known Member
    When you see 6 codes with the E and F, its a canister. 99.9% of the time.
    They are tricky to do due to the connectors but not impossible.
    They can sometimes come on due to weather and not return for awhile. I'd start by simply clearing the codes and seeing if it even comes back.
  4. Nov 14, 2019 at 10:42 PM
    silver2010
    3" lift
  5. Nov 16, 2019 at 9:07 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I have cleared mine a few times, light comes back almost immediately.
