evap code plz help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 69blackwhss, Sep 22, 2010.
  1. Sep 22, 2010 at 7:27 AM
    69blackwhss
    69blackwhss [OP] Well-Known Member
    jason
    georgetown ky
    03 v6 5speed step side trd
    push bar
    hey guys i am gettin the code po466 r po446 one of thoes i know its the evap code i have changed the gas cap an it still came back on has anyone had this problem also an mite know what i need to look at so i dont waste alot of time an money. thanks jason
  2. Sep 22, 2010 at 7:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Asuming you cleared the code after you tried the gas cap, it could be a few things.
    Bad gas.
    Bad purge flow sensor
    bad (leaking) Evap canistor
    kinked hose
    unplugged sensor
    Check the fule system, and make sure there are no broken wires, kinked evap lines/fuel lines
  3. Sep 22, 2010 at 8:06 AM
    69blackwhss
    jason
    georgetown ky
    push bar
    ya i cleared the code an it came back on in a week are so an i did look on down on the scaner that it said performane sensor? have u heard of this one? i belive i saw it rite.
  4. Sep 22, 2010 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IO have heard of the code, but not the "Performance Sensor"...
  5. Sep 22, 2010 at 8:42 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    what code did you get 1st????/
  6. Sep 22, 2010 at 10:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    It could be a laundry list of things...
  7. Sep 22, 2010 at 12:18 PM
    David Tarantino
    N.J.
    08 tacoma
    most of the time its the 1st code
    and i said MOST of the time :D
  8. Sep 22, 2010 at 12:54 PM
    69blackwhss
    jason
    georgetown ky
    push bar
    It's been the same code ever time
  9. Sep 22, 2010 at 1:13 PM
    David Tarantino
    N.J.
    08 tacoma
    you have two codes in your 1st post po466 and po446:D
  10. Sep 23, 2010 at 2:23 AM
    69blackwhss
    jason
    georgetown ky
    push bar
    am sorry i couldnt remeber which one it was i knew it was the one for the evap one tho
  11. Sep 23, 2010 at 2:43 AM
    David Tarantino
    N.J.
    08 tacoma
    ok i have some info from alldata it may help may not but its long
    not sure hows its going to turn out if i try to post its like 5/6 pages
    if you have a fax id be happy to fax it to you if so pm it to me
    if you like
  12. Sep 24, 2010 at 12:14 PM
    69blackwhss
    jason
    georgetown ky
    push bar
    hey i dont have a fax sorry what bot an email? camaross1969blackwh@yahoo.com
  13. Sep 24, 2010 at 12:32 PM
    David Tarantino
    N.J.
    08 tacoma
    no sorry it wont let me alldata must have a code that well not ley me
    copy and paste it to a e-mail
  14. Sep 25, 2010 at 6:24 AM
    69blackwhss
    jason
    georgetown ky
    push bar
    Man that sucks the only fax machine I can get to is at the library an that can work if we can get a time so I know to be up there to get it. An it would be Monday befor I can get
    The number if u
    Can do it just let me know an thanks for the help
  15. Sep 25, 2010 at 7:30 AM
    David Tarantino
    N.J.
    08 tacoma
    Monday weds thur fri i am here from 6am to 5pm
    sat 6am to 4pm let know
  16. Sep 25, 2010 at 7:45 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :anonymous: how bad is it for a vehicle to drive with that code?
  17. Sep 25, 2010 at 7:53 AM
    David Tarantino
    N.J.
    08 tacoma
    your going to use more gas
    its not that your going to brake down or anything
  18. Sep 25, 2010 at 7:54 AM
    ImpulseRed008
    Susan
    SC
    Thanks, David
  19. Sep 26, 2010 at 9:07 AM
    69blackwhss
    jason
    georgetown ky
    push bar
    Ok I'll get the number money man an quote u back on here
  20. Sep 30, 2010 at 1:08 PM
    69blackwhss
    jason
    georgetown ky
    push bar
    Hey man could u fax that to me this wensday coming? If so let me know the best time I'll be there from 930-4pm thanks sorry took so long to get back to you been busy
