Evap Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrkelly5697, Sep 9, 2019.
  1. Sep 9, 2019 at 4:20 PM
    jrkelly5697
    jrkelly5697 [OP] Member
    Joe
    2003 Tacoma Quad Cab 4x4 V6
    Looking for help here to diagnose an issue. 2003 Tacoma Quad Cab V6 4x4.
    When I fill the gas tank the truck won’t start. It’ll crank until I stop, then if I go again it’ll start after maybe 5 seconds then idle rough. I rev it up for maybe 10-15 seconds to maybe 3000 rpm, then all is back to normal. Also, I can smell fuel near the filler neck/ between the cab and the bed. Lastly, the CEL comes on and reads the Evap small leak code. However, when I clear the code, it stays off for maybe 2-3 weeks before coming back on.
    I’m thinking it’s the charcoal canister or maybe the purge valve, but wanted to check here before getting into that since it appears they’re buried on top of the gas tank.
  2. Sep 9, 2019 at 7:20 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Check the o ring on gas cap for wear and cracks and hoses to filler neck. Give the purge valve a couple good wacks(they stick sometimes).
    cruxofthebisquit likes this.
  3. Sep 9, 2019 at 7:22 PM
    jrkelly5697
    Joe
    Yup, forgot to mention that, already replaced the gas cap. I’ll try giving the valve a tap though
  4. Sep 9, 2019 at 8:54 PM
    ToyotaHunter
    ToyotaHunter Well-Known Member
    2003 Toyota Tacoma TRD
    is there any gas leaking or just the smell?
  5. Sep 9, 2019 at 8:55 PM
    Bishop84
    Bishop84 Well-Known Member
    If the purge valve is stuck open it will constantly dump fuel vapour into the intake.
    Try plugging it off.
  6. Sep 9, 2019 at 9:10 PM
    jrkelly5697
    Joe
    No gas leaking as far as I can tell. I park in the same spot and no marks on the ground. It sounds like the purge valve may be the culprit. Would the easiest way to replace be to take the bed off? Then I could replace anything on top of the fuel tank while I’m at it.
  7. Sep 9, 2019 at 9:11 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Build a smoke machine. Or buy one, they are handy for all kinds of leaks. I've found leaky sewer/water lines with them.
  8. Sep 9, 2019 at 9:17 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The purge valve is under the hood. The charcoal canister is under the bed. You say you smell gas between the bed and cab? I'd fallow down the purge line from the canister to the purge valve. I bet you got a breach in that line.
  9. Sep 9, 2019 at 9:22 PM
    jrkelly5697
    Joe
    Yeah, I can smell it between the bed and cab. I’ll check that line and also give the purge valve a tap since it’s easier to get to. I’m still not convinced that the hose leaking is all of it though. When filling up not starting makes me want to think that the charcoal is getting full of vapor and it takes me trying to start it to clear it out. Is that what the purge valve does is get rid of that vapor that I’m now getting rid of by trying to start?
  10. Sep 9, 2019 at 9:22 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’ve had bad sending unit seals cause gas smell from that area before. Usually caused by rust on the tank. As for the not wanting to start that can be a million things. May be related or not. Likely is. Smoke machine is your friend in this case.
  11. Sep 9, 2019 at 9:25 PM
    koditten
    Kirk
    Central Michigan
    Black DOG Lila likes this.
  12. Sep 10, 2019 at 7:26 AM
    Black DOG Lila
    Virginia
    I would diagnose the problem before removing the bed or dropping the fuel tank. Try add fuel before the fuel light comes on. Full tanks generate less vapor. Going from two gallons in tank at fill up to full tank displaces a lot of vapor and if the valve is stuck open it will seem like the engine is flooded at start up. Try filling up at 3/4 full tank. Purge valve is on cannister above gas tank. If vehicle is not overhead on a lift dropping the spare will give you more room. Tundras have a purge selnoid under the hood, your Tacoma does not. Your tacoma does have a VSV (vacuum switching valve) under the hood but it would not cause the problem you have.
  13. Sep 10, 2019 at 10:20 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    As an experiment, try driving it, then shut off, remove gas cap, wait a minute, put gas cap back, then try to restart. See if the pressure or vacuum in the tank is related to the problem or if it's actually related to filling the tank.
    The purge valve shouldn't open when starting or idling. If it's stuck open it could cause starting problems.
    Black DOG Lila and koditten like this.
  14. Sep 13, 2019 at 1:20 PM
    jrkelly5697
    Joe
    UPDATE! I ordered and replaced the purge valve (under the hood) and refueled from about 1/4 tank. Started right up, which is great and resolved that issue. I'll have to wait and see if my CEL comes back on in the next couple weeks, but I appreciate everyone's advice! Great fix for a few bucks.
  15. Sep 13, 2019 at 1:47 PM
    Black DOG Lila
    Virginia
    Good job joe. Does your V6 have the charcoal cannister and purge valve under the hood or did you replace the purge selnoid oem#25860-75160 also known in the aftermarket as VSV or vacuum switching valve ??
  16. Sep 13, 2019 at 3:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What CEL did you get? Was it PO0446?
  17. Sep 13, 2019 at 3:51 PM
    Black DOG Lila
    Virginia
    P0446 indicates voltage drop in EVAP sensors. OP never mentioned code # but I bet it was P0441 indicated by symptoms presented,
  18. Sep 13, 2019 at 5:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That is something Ive no read before. I get that one intermittently. Clear it and it stays away for a while.
  19. Sep 13, 2019 at 5:12 PM
    Empty_Lord
    Dan
    check the hose going from the the air box to the evap stuff... ive seen them routed wrong and act like that.
    Digiratus[QUOTED] likes this.
  20. Sep 13, 2019 at 10:45 PM
    Glamisman
    Glamisman Well-Known Member
    evap codes and their respective monitors are 2 trip codes with a specific set of test parameters. Fuel tank must be between 1/4 and 3/4 full. IAT (intake air temp) must be within 20 ish degrees of water temp and there must be a minimum of 8 hrs between starts. This has to be done twice... in english this means the truck has to have gas in the tank, sit for 8hrs until it is cool and do this 2 times.
