Evap Leak Check Engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by bourdlay, Jul 25, 2011.
  1. Jul 25, 2011 at 9:20 AM
    bourdlay
    bourdlay [OP] Member
    Dave
    Michigan
    4x4 2.7 manual reg cab
    Hello everyone. My checked engine light is on, I had it check by Auto Zone and 3 codes came up p0442 p0441 p0446. This means Evap leak, I noticed many common issues on the internet with these codes. I was wondering if anyone had any suggestions on what to start with. I checked the gas cap for pressure, and under the hood for unattached hoses. Any suggestions were to go next without going to the dealer or a mechanic?
  2. Jul 25, 2011 at 9:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Start with the cap. Make sure it's tight. (sounds you already did this)
    Looking at the chart attached in the PDF below and if the gas cap is ok, it is probably one of the three VSV (vacuum switching valve) that controls the venting in the system.
    Here are the locations of the valves.
