Evap purge valve ticking
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoLover719, Dec 17, 2024.
  1. Dec 17, 2024 at 4:00 PM
    TacoLover719
    TacoLover719 [OP] Tacoma whisperer
    Drake
    Blacked out ‘03 Tacoma 2.7l
    LCENGINEERING low boost SC LCENGINEERING long tube headers + EGR delete + MBRP muffler and custom made side dump 170k miles Puck lift Short throw shifter kit K02 tires on American Racing Baja wheels 220whp
    I’ve been chasing this noise for so long, and have been fighting it as it sounds like lifter tick but isn’t. It’s the little tiny valve on the drivers side that controls the evap purging. I just recently bought a new valve and it still sits and clicks, anywhere above 15inhg it’ll start ticking rapidly and on road trips it gets unbearable. 3rz with headers intake and read to SC but I don’t know what to do. I know it wasn’t there when I got the truck and I can’t seem to shake the noise, if I unplug it it stops but I don’t want to drive with it unplugged. Help? Just did a new gas tank with all new seals and got rid of all my evap leaks. New hoses as well
  2. Dec 17, 2024 at 4:53 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    They click.
    TACOTU3 likes this.
  3. Dec 17, 2024 at 5:08 PM
    TacoLover719
    Drake
    no, they aren’t supposed to. It didn’t do it when I got it, and they sure as hell didn’t out of the factory as no one would put up with it.
    MadNachos[QUOTED] likes this.
  4. Dec 17, 2024 at 5:23 PM
    TacoLover719
    Drake
    I just watched a video and now I’m starting to overthink a bit and it might be pinging? It’s been doing it for almost 10k miles tho I wouldn’t think my motor would be alive anymore if it was… also the spark plugs are all healthy and no ghost white at all. Also AFRs stay at 14.7 until
    MadNachos likes this.
  5. Dec 17, 2024 at 5:27 PM
    MadNachos
    My OE unit doesn't but I hear (ha!) that it's not uncommon with OEM/aftermarket units. How loud and how often is it clicking?
  6. Dec 17, 2024 at 5:32 PM
    TacoLover719
    Drake
    at any point under load and I can put my ear up to the valve and hear ticking noises. But now I’m slightly scared that it could be pinging…. My AFRs have been perfect tho even since I did my headers. Wouldn’t pinging have killed my motor by now?
  7. Dec 17, 2024 at 5:36 PM
    MadNachos
    You running a supercharger?
    ETA: If so, put some "real" gas in it and see if it goes away.
  8. Dec 17, 2024 at 5:45 PM
    TacoLover719
    Drake
    I’m going to be running a SC LCEngineering has them on order but still about 10 weeks out. And I currently run 91 no ethanol anyways as I have a higher flow fuel pump long tubes catless and intake. Figured it wouldn’t hurt and 91 is cheap around my area.
  9. Dec 17, 2024 at 5:51 PM
    MadNachos
    Ahh, yeah, I am considering their new SC when it's available. I hear they are finishing up testing.
    Anyway, I have LCE headers and LCE exhaust on my 2.7 and I it changed nothing from a fuel standpoint. I doubt you have pinging.
  10. Dec 17, 2024 at 5:52 PM
    TacoLover719
    Drake
    Well that’s good to hear, and I’ll be running the low boost kit and making a thread on instal and how it goes. 4 bands is pricey I hope it’s worth it.
  11. Dec 17, 2024 at 5:54 PM
    MadNachos
    Do you have an exhaust leak? These motors are not silent, you may just be overthinking it. If you have no issues under power, rock on.
  12. Dec 17, 2024 at 6:49 PM
    TacoLover719
    Drake
    No I don’t belive it’s an exhaust leak but maybe. Ima retorque the exhaust studs maybe one is loose or something
  13. Dec 17, 2024 at 7:05 PM
    MadNachos
    Post a video or recording.
  14. Dec 17, 2024 at 7:11 PM
    TacoLover719
    Drake
    I shall try tommorow when I go to drive
  15. Dec 17, 2024 at 7:23 PM
    MadNachos
    Sounds good. I am sure someone here can pick out the noise.
  16. Dec 18, 2024 at 5:19 AM
    TacoLover719
    Drake
    Not entirely sure how to put a video in here
