Evap side of throttle body filthy
Discussion in '1st Gen. Tacomas (1995-2004)' started by Suq, May 31, 2022.
  1. May 31, 2022 at 9:35 AM
    Suq
    Suq [OP] Member
    Bob
    2002 lifted Tacoma
    Hello so I took apart the throttle body to get it cleaned and I noticed a lot of filthy gunk coming from the evap vacuum port that I believe to be excessive, maybe it was never cleaned and it’s normal or there could be a different problem causing it.
    I linked the routing map and it’s port P
    2002 4 cylinder 2.7L
    California emissions
    134,000 miles
    No CEL, none pending either
    I believe it could be the hose that goes into the air filter box was busted for awhile but it shouldn’t be sucking in air since the valve should be closed when the vehicle is on, from what I understand. The hose on the diagram that says “From Air Cleaner”
  2. May 31, 2022 at 10:04 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    The hose to throttle body carries accumulated EVAP gasses from the charcoal cannister. This happens when the cannister Purge valve opens.
    Although the air going to the cannister is filtered through the air filter the EVAP Purge can be contaminated by over filling the fuel tank repeatedly allowing raw fuel to flood the cannister and degrade the normally dry charcoal.
  3. Jun 2, 2022 at 4:21 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Hi! Same engine here, had the same dirty throttle body. If I remember correctly, in my case the pcv valve had been stuck open for some time and needed replacement. It was shooting crankcase gunk into the throttle body post throttle plate.
