Evaporative Pressure Sensor needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrfish27, Jul 8, 2014.
  1. Jul 8, 2014 at 9:36 AM
    mrfish27
    mrfish27 [OP] MrFish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Air lockers, RTT, aluminum armor, lithium 2nd battery
    Looking for part number 89460-04020 for a 2001 2.4L. Toyota no longer supports this part and I have not been able to find it (yet) on the 'net. Doing a search gives results but then I hear back from the vendor saying that they can't get it.
    I'm open to suggestions.
    Thanks!
    Mancave Dweller likes this.
  2. Jul 8, 2014 at 2:33 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
  3. Jul 8, 2014 at 4:15 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Thank you for that. How did you find the compatible part?
  4. Jul 8, 2014 at 7:07 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    why do you need it? weird a dealership cant get it
  5. Jul 8, 2014 at 8:10 PM
    zenn1102
    zenn1102 Well-Known Member
    Iowa
    97 taco 4x4
    det107 likes this.
  6. Jul 9, 2014 at 5:59 AM
    wcp0611
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    I sell parts for a living so I have all kinds of interchange lists.
    I'd definitely go OEM on emissions sensors, but if you can't find it, then the one I posted up will do the job, just might not live as long.
  7. Jul 9, 2014 at 6:05 AM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Need it because of code P0450. Further inquiry shows the sensor malfunctioning.
    The good news is that my mechanic was able to locate a used sensor from a junkyard in Redding, CA. It's supposed to arrive today.
    If that does not come through, I'll look into the MAP sensors available at Summit Racing.
    With so many Tacomas on the road, it does seem odd that the part is not supported in some way.
  8. Jul 15, 2014 at 7:11 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    The junkyard part has a different number (89460-04010 92613) than the original (89460-04020 12061) but we installed in anyway because we had it in hand and there was no downside that we could think of. Even though we swapped the part in close to a week ago, I have not driven more than 10 miles (3 or 4 short trips) since, so the fact that there is no CEL yet does not mean much.
    The code/sensor issue is in my 2001 2.4 2wd Tacoma. I have another truck, my desert rig, which is a 1999 3.4 4x4 Tacoma. It has a very similar part (89460-0410 91463) that appears to be identical except for the numbers. It's possible that it could be interchangeable.
    I'll add a note that the third set of numbers in the parts I've listed is something called a PCN (or something similar), used as a code to locate parts more quickly. I learned this today at the dealer.
  9. Jul 20, 2016 at 9:46 PM
    TrumpetMan
    TrumpetMan San Diego Chargers Fan
    Tony
    Lake Elsinore California
    2000 White Tacoma TRD Extended Cab 2WD Automatic 3.4L V6
    None.
    I know this is an older thread but I just went through this same thing.
    However, I have a 2000 Tacoma 3.4L V6 and the vapor pressure sensor was bad (Toyota Part Number 89460-04010). The bad vapor pressure sensor was throwing the P0450 code. The dealership discontinued the vapor pressure sensor and there is no aftermarket part available as I was told as well. My vapor pressure sensor is located on the drivers side firewall with one bolt and bracket to fasten to the firewall, one vacuum line and one wire harness which snaps on the vapor pressure sensor.
    There is a workaround part. I am using a new vapor pressure sensor off of a 2000 Tundra (Part Number 89460-0C010). No more P0450 code. I also understand the Camry and Lexus LS300 use the same vapor pressure sensor as the Tacomas (Same 89460 Part number but different last set of numbers) and different brackets which can be removed. I used my bracket and slid off the old bracket and installed the new vapor pressure sensor and done deal. So heads up all. The vapor pressure sensors are for the most part interchangeable for the Tacoma with the Tundra, Lexus LS300 or Camry. Do not let a discontinued part get you down.
    Emaiz, Tacomaqueen, aramuad and 2 others like this.
  10. Feb 4, 2018 at 10:47 AM
    macaflea
    macaflea New Member
    2001 3.4L Tacoma PreRunner
    Thanks for the information. This worked for my 3.4L V6 Tacoma Prerunner. CEL on...Diagnostic code P0450. I put on a
    1992-96 Toyota Camry Vapor Fuel Tank Pressure Sensor 89460-33020 OEM 3.0l ES300 and the issue was fixed. Bought on Ebay. The CEL is off and no more P0450 code. Truck Passed NC state inspection two weeks after putting on the 89460-33020 vapor pressure sensor.
  11. Mar 22, 2019 at 7:46 AM
    paane12
    paane12 Member
    Anyone have a picture of it mounted anywhere on there truck. I can’t find it for my 95 Tacoma 3.4 engine
  12. Aug 4, 2019 at 7:23 PM
    Reareahar
    Reareahar Member
    Md
    Tacoma 03 prerunner
    V6 3.4
    Mine is coding P0451 I replaced all my vacuum lines and installed new evap canister. I also replace purge valve under hood. I also need to locate this fuel tank pressure sensor please share if u find It or let me know if u resolved it any other way..
  13. Oct 4, 2019 at 3:36 PM
    American Grit
    American Grit Member
    2000 Tacoma PreRunner
    6" Suspension Lift 315/70R17
    Anyone find a pic of where this is located on our trucks? My 2000 PreRunner 3.4 just started showing this code.
  14. Oct 4, 2019 at 7:57 PM
    Reareahar
    Reareahar Member
    Md
    Tacoma 03 prerunner
    V6 3.4
    I haven't sorry!!! My lights still on too..How can u replace a part that doesn't exist..
  15. Oct 5, 2019 at 8:59 AM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Try replacing the fuel filler cap. Fixed a family members 98 Tacoma V6 that has an unobtainable evap sensor.
  16. Oct 5, 2019 at 1:44 PM
    American Grit
    Thanks btu44, I'll give that a try.
    btu44 likes this.
  17. Oct 6, 2019 at 7:06 AM
    Reareahar
    Reareahar Member
    Md
    Tacoma 03 prerunner
    V6 3.4
    Good luck we bought brand new one from Toyota and didnt fix our issue. We're going for a smoke test at witts end!!!!!
  18. Oct 6, 2019 at 9:11 AM
    btu44
    Long Beach area, Ca
    If the fuel cap doesn't work maybe following these troubleshoot procedures will help.
  19. Oct 11, 2019 at 1:35 PM
    American Grit
    The new fuel cap did the trick... at least for now. No more code.
  20. Oct 11, 2019 at 3:53 PM
    btu44
    Long Beach area, Ca
    Good to hear. Hope it turns out to be a long term fix :)
