Evaporator Core Replacement... 2000 PreRunner...
Discussion in '1st Gen. Tacomas (1995-2004)' started by rzgkane, May 20, 2015.
  1. May 20, 2015 at 8:55 AM
    rzgkane
    rzgkane [OP] Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Almost anyone could do this job. Took me less than an hour, not including the recharge process. Disconnect high and low pressure lines in engine compartment, remove glove box and inner glove box housing, disconnect obvious wire connectors, remove 5 10mm bolts/screws and the thing just falls out in your lap.
