ever broken a bolt off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zombie Runner, Aug 3, 2010.
  1. Aug 3, 2010 at 8:27 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Well last night I took my K&N intake off and while i was installing my stock airbox I was tightening down one of the bolts that hold it onto the (intake manifold?) well how do I get that shitty broken bolt out now? drill a hole into the old one and tap it out somehow? :goingcrazy:
  2. Aug 3, 2010 at 8:31 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Left handed drill bit. It might back right out.
  3. Aug 3, 2010 at 8:31 AM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    they make bolt extraction kits. its like this little cone thing and you put it on a drill. they kind of suck. try a pair of pliers if there is anything for them to grip. good luck with it.
  4. Aug 3, 2010 at 8:43 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Drill out and extract. If not, drill oversize and use a "keen-sert" it's a sleeve that lock into a new threaded hole. It's 10x better than helicoils.
  5. Aug 3, 2010 at 8:43 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Drill out and extract. If not, drill oversize and use a "keen-sert" it's a threaded sleeve that locks into a new threaded hole. It's 10x better than helicoils.
  6. Aug 3, 2010 at 8:45 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    I've never seen a double post here on TW. How in the world did you manage that?
  7. Aug 3, 2010 at 8:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    :goingcrazy: so do i have to do the same thing twice while standing in a tub of mashed potatoes while singing the star spangled banner?
  8. Aug 3, 2010 at 8:51 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    Riverside, IL
    09 TRD O/R AT
    Yeah, I broke a stud on the head of my motorcycle once. I was pulling the exhaust. Sucked.
    Buy an easy out kit and a few strong drill bits. Drill a small hole in the bolt and the easy outs have reverse threads. So they dig in as you turn the bolt out. Just don't break the easy out! They are much harder to remove when broken inside a broken bolt.
  9. Aug 3, 2010 at 9:02 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Martie needs to let you out more...........
  10. Aug 3, 2010 at 9:03 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    keason,, is there anything poking out? if so, go to sears and get a bolt extractor. they are designed to take out stripped nuts,,but i used the smaller one to take out an exhaust stud, that sheared. i had about 1/4" poking out..i heated it cherry red, said a prayer and used that "bolt out"..it came out!! i almost cried. tears of joy.
  11. Aug 3, 2010 at 9:05 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Is the broken part recessed a lot, or right at the surface? You could try using a dremel to grind a slot across the top and use a slotted screwdiver. Also wouln't hurt to use some PB blaster on it to minimize thread friction no matter what approach you use.
    Alternatively, sell the truck.
  12. Aug 3, 2010 at 9:07 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i once broke a bolt off in an intake manifold when trying to take off the thermostat cover. had to hit a junkyard for a new intake.
  13. Aug 3, 2010 at 9:18 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    that what the first thing I thought when it happend...haha
    but I called a budy and he has the kit to remove it so im gonna give it a shot tonight. its broken clean off, nothing sticking out.
  14. Aug 3, 2010 at 9:24 AM
    Dark_Taco
    Dark_Taco ΜΟΛΩΝ ΛΑΒΕ
    08' TRD Rugged Trail Edition
    I have used the easy out kit myself a few times with success. I'm sure you will get it just go slow and don't force anything.
  15. Aug 3, 2010 at 9:36 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    thats what she said
  16. Aug 3, 2010 at 9:37 AM
    aficianado
    back to bone stock.
    broken flush? ouch.
    easy out. drill it with the recommended sized bit. buy several quality bits (they break), and buy some drill lube. i had some that came in a tube..worked GREAT! without lube, you run the risk of breaking a drillbit IN THE BOLT, which complicates things (DRASTICALLY). i used the easy out, in one of those handles similar to a tap handle. and twisted slowly..it backed out.
    good luck.
    i have seen a friend put the easy out - in drill and turned the chuck my hand to twist it out..he had the drill unplugged..the chuck gave him grip and leverage.
  17. Aug 3, 2010 at 9:40 AM
    Dark_Taco
    yeah right after she made this face :eek:
  18. Aug 3, 2010 at 9:41 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    :jerkoff:
  19. Aug 3, 2010 at 9:45 AM
    Dark_Taco
    :D
    Seriously, though that bolt shouldn't be too difficult.
  20. Aug 3, 2010 at 9:52 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    thanks for all the help yall
