Ever run out of fuel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3Sons, Nov 2, 2017.
  1. Nov 2, 2017 at 6:48 PM
    3Sons
    3Sons [OP] Member
    OHIO
    '17 DCSB TRD Sport 6Speed BBP
    On my way to work tonight and I knew how far the Marathon station was and with what my miles til empty was showing, it was going to be close:goingcrazy:.
    Just curious if anyone has ever run the tank completely dry? If so, how accurate is the miles til empty counter?
    tacom08 likes this.
  2. Nov 2, 2017 at 6:53 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I've gone 10+ miles after that hits 0. At zero, you get about 18gal in the tank with a 21.1 gal tank capacity, so ~3 gal left after 0. So a very safe 30miles left once it states 0 miles left.
    GillyLink, Skydvrr, Hank Heel and 3 others like this.
  3. Nov 2, 2017 at 6:55 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Why risk it? Always good to have fuel in the tank considering how things are nowadays
    *never lets gas go below 1/4 tank crew*
  4. Nov 2, 2017 at 7:03 PM
    3Sons
    3Sons [OP] Member
    OHIO
    Yea I've heard that its bad for the fuel pump.
    tcjacado likes this.
  5. Nov 2, 2017 at 7:06 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Always fill up at 1/2 tank whenever possible.
    GillyLink, FishnTx, Greg617 and 2 others like this.
  6. Nov 2, 2017 at 7:21 PM
    mutely
    Old wives tale on anything even remotely modern. As you can see with 0 left on that gauge there is still 3 gals in the tank, which is more than enough to cool the pump. If you run to 0 on that gauge then fill up each and every time, then you will do absolutely no damage, or excessive ware. The damage comes from constantly being on E, ie run to almost out of gas, then only putting a few gals in the tank, and repeating that all the time.
    Skydvrr likes this.
  7. Nov 2, 2017 at 7:26 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    False. I use to run my Evo on low fuel A LOT. (I could always feel the extra weight of a full tank) First pump went out, thought it was a fluke.. but after the 2nd Walbro fuel pump smoked, I put 2 and 2 together. Pumps rely on the gas surrounding it to keep it cool and increase longevity. Albeit those were high performance pumps so factory might be a little better... but still the same logic applies.
    But on topic, I've went ~20miles after it hit zero. Wasn't by choice but there is always some gas left in there even when the light is on.
  8. Nov 2, 2017 at 7:28 PM
    doorsidedown
    doorsidedown Well-Known Member
    haha when you said that all I heard was...
    MaTaco_4x4, RocTaco, synaps3 and 2 others like this.
  9. Nov 2, 2017 at 7:31 PM
    tcjacado
    tcjacado Well-Known Member
    The tank, gauge and counter are very accurate. I have run mine down to around .5 gallons left ( well past 0 on the gauge cluster). Wasn't intentional, just the area I was in had really high gas prices 30 to 50 cents higher than across town where I had to go anyway. I thought I had enough to do my day, I ended up stopping and putting a couple of bucks in.
    9TRDTCO likes this.
  10. Nov 2, 2017 at 7:35 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    If you really want to know, it's pretty easy to figure out. Put a gas can in the bed and drive till you can't. Fill it up and drive to the gas station.
    Skydvrr likes this.
  11. Nov 2, 2017 at 7:38 PM
    tcjacado
    No way o_O
    That's the easy way cheater. Us new owners have Toyota care with road side assistance. Make them come to you :rofl:
    Heepspo and kodiakisland[QUOTED] like this.
  12. Nov 2, 2017 at 7:41 PM
    mutely
    By those assumptions, I could call your statement false. I've got 160k on my Tundra and it's never seen gas before the light came on, still origional pump & filters. Similar situation for every 4 wheeled vehicle I've owned, and I've never had to replace a fuel pump. I can't say the same for 2 wheeled vehicles, im always replacing pumps on my bikes, and they rarely see empty.
    But, your personal experience and mine, is irreverent as there are too many other factors in play.
  13. Nov 2, 2017 at 9:19 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    *wistfully staring at OP gas price of $2.69*
    Man, gas is $3.60/gallon here in SoCal.
    T6A1C9O and tcjacado like this.
  14. Nov 2, 2017 at 9:58 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The lowest I have ever had my tank was when it said 25 Miles till empty but I do not recall seeing the low fuel light at the time.
  15. Nov 2, 2017 at 10:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I filled up at 2.17 the other day, recent transplant from Wa so I am still in awe of how cheap fuel is in AZ.
  16. Nov 2, 2017 at 10:13 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Everything is cheap in AZ
  17. Nov 2, 2017 at 10:13 PM
    Speedytech7
    It is not, if the vehicle is still running then the pump is fine. The fuel going through the pump is its lubricant and coolant (not that they build much heat on something as low power as these trucks) the high pressure pump under the hood for your direct injection is also fine as long as the vehicle can still run. You just don't ever want to run a pump dry, that is no bueno.
  18. Nov 2, 2017 at 10:14 PM
    Speedytech7
    A/C bill is not cheap haha
    Skydvrr and PROseur[QUOTED] like this.
  19. Nov 2, 2017 at 10:16 PM
    PROseur
    Pussy
    My sister is in paradise valley
    Housing dirt cheap
    Gas dirt cheap
    She makes more in her medical practice than she did in ca - thus her take home is a lot higher
    Yup she pays $650 a month for electric
    But given she has a new Ferrari 488 daily driver there and was slumming it in Los Angeles in a base 911, she ok With the ac bill :)
    I have lived in WA. Women in AZ Way more attractive
  20. Nov 2, 2017 at 10:20 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Lets be real here though. Everything breaks on a DSM/Mitsu. Former GS-T owner here back in the day. Also since you were running a walbro it could need more fuel for cooling than an OEM pump. I used to run low all the time when I was a teen and never broke a fuel pump.
    Speedytech7 likes this.
