Ever run tank dry? 22 gallons top off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amocat21, Jan 19, 2015.
  1. Jan 19, 2015 at 1:53 PM
    amocat21
    amocat21 [OP] Active Member
    2012 6 cylinder 4x4
    Anyone ever let their tank go dry on them? If so, where does the needle point to? in the middle of "E"? When I ran it down 19.75 gallons to get my 500 mile tank the needle pointed in between the last bold black hash and the "E".
    Also, Is the tank officially 21 gallons when the gas pump clicks off or does one need to squeeze more in after click off? Once I got about a full gallon in after click off to the point of seeing fuel at the top of the filler tube. I do not normally do that. I usually only put 1/2 gallon over the click when pumping my own. Oregon doesn't allow citizens to pump their own gas so that only happens when traveling. So are the V6 tanks capable of 22 gallons topped off?:confused:
  2. Jan 19, 2015 at 2:01 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Both of these things you're doing could get expensive.
  3. Jan 19, 2015 at 2:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    You should never need to know these answers.
    Running a dry tank is a good way to toast a fuel pump. They get their cooling from being submerged in fuel. Not to mention the possibility of sucking up sediment that could create some premature system clogging.
    Overfilling your tank is a great way to flood the emissions system and create some pricy repairs.
  4. Jan 19, 2015 at 3:55 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Burn up fuel pump, clog up fuel lines, run out of gas somewhere. Just to see how much you can "really" put in there?
    345 miles with 18.9 gallons. Good enough for me.
  5. Jan 19, 2015 at 5:17 PM
    Pigeon
    Pigeon Well-Known Member
    PJ
    Eria, PA
    05 Double Cab Long Bed
    That's a really good question, I have pushed mine way below e and it seems like it just keeps going. Wow 21 gallons, I've almost gotten 20 never that close. Usually a car will start chugging when your almost out, I've never had that happen.
  6. Jan 19, 2015 at 5:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's actually 80 litres
  7. Jan 19, 2015 at 5:53 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    This is the most I've put in at once. The needle will go pretty far into the E. About four gallons in the tank when the light comes on
    Truck never sputtered, got to filling station just fine
  8. Jan 19, 2015 at 7:47 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I rarely ever let the gauge get below 1/4. Just my 2 cents.
  9. Jan 19, 2015 at 7:52 PM
    ptwob311
    ptwob311 Curios Noob
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    ^ what he said.
    I rarely let any of my vehicles go too far below 1/4 tank for all the reasons stated by others.
  10. Jan 19, 2015 at 7:53 PM
    302 I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
    Running dry is bad news, agreed. But, it's good to know how far you can go with what's left, in case of a real life zombie apocalypse. Or, in case you have a spastic colon and refuse to use public restrooms, like myself. That last gallon has saved my ass more than a few times.
    True story
    3
  11. Jan 19, 2015 at 7:59 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Pump is cooled and lubricated by fuel running through it, not by being submerged.
    There isn't some hidden sediment that will only get sucked up if the tank is run low, the draw is always off the bottom.
  12. Jan 19, 2015 at 8:03 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Damn, I'm sweating bullets if the light comes on and I don't see a sign within 2 minutes. By the time it makes it to the top of the E I'm dropping speed and am damn near dehydrated. Don't even want to imagine what would happen if it got lower then that.
  13. Jan 19, 2015 at 8:07 PM
    TOY33
    TOY33 Well-Known Member
    Silver 14 DCSB PreRunner
    No gas = no lube
  14. Jan 19, 2015 at 8:11 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Closest I ever came was with Betty, my redhead 2008 that didn't survive the trip from Florida to Oklahoma in August last.
    434 miles on 18.45 gals, for a tank-average of 23.53mpg.
    That was her last tank, loaded to the balls and draggin low as I limped across the southern US while moving. I went around 65-70 MPH, no trailer but all highway with a steady foot.
    That tank, IIRC, got me from the Sarasota area up through Alabama and into Mis'ippi, where I filled one last time.
    Loosey-anna took her from me. I finished the trip in a rental Dodge Caliber and felt dirtier for it.
  15. Jan 19, 2015 at 8:12 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I usually always fill up at 1/2 tank, and never let it go below 1/4 tank, that shit's hard on your fuel pump bro, don't make a habit of doing that or you're gonna kick yourself later.
  16. Jan 19, 2015 at 8:17 PM
    302
    Lawrence
    302
    Bedside decal
    I had an old 92 Camry sport with a busted fuel gauge, and we ran that thing completely out of gas 3 or 4 times a month for several years. I got 260,000 miles on that car before I sold it to my brother in law and he still drives it around. We experienced none of these issues that you guys are talking about. Toyota devolution perhaps?
    3
  17. Jan 19, 2015 at 8:20 PM
    Xaks
    Xaks
    Oklahoma City area
    In case you hadn't noticed, the technologies and hardware used in modern EFI fuel pumps are...shall we say...slightly different today than they were .... 23 years ago?
  18. Jan 19, 2015 at 8:22 PM
    worthywads
    Not hard on fuel pump bro.
  19. Jan 19, 2015 at 8:22 PM
    302
    Lawrence
    302
    Bedside decal
    That was precisely my point. Why would fuel system devolve and not evolve after 23 years?
  20. Jan 19, 2015 at 8:24 PM
    SpeedoJosh
    Florida
    Ran my 1st gen out of fuel once. Weeks later a code popped. Determined to be weak fuel pressure. Now, the truck still ran fine most of the time, and I ran it like that for 6 months. Swapped out the pump and code went away. Coincidence, maybe or maybe not. I know I don't want to chance it with my 2nd gen though.
