Ever since mudding I hear my truck squeak
Discussion in 'Detailing' started by bowhunter95, Sep 17, 2012.
  1. Sep 17, 2012 at 6:54 PM
    bowhunter95
    bowhunter95 [OP] Member
    TJ
    Illinois
    Black Lifted tacoma
    Went mudding and cleaned the whole thing with a pressure washer yet the truck still squeaks. What would be the cause or how could I fix it? Thanks
  2. Sep 17, 2012 at 6:55 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Yep, mud will definitely do that. Ball joints, bushings, leafs. You're going to have to deal with the squeaking now, it's all part of getting in the mud.
  3. Sep 17, 2012 at 6:56 PM
    Large
    Large Red
    Leaf pack probably.
  4. Sep 17, 2012 at 6:56 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Leafs? Where are you hearing the squeaks. I'm guessing dirt/mud in the leafs
  5. Sep 17, 2012 at 6:57 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I usually just pressure wash the crap out of the suspension components and that seemed to do the trick.
  6. Sep 17, 2012 at 6:59 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Clean your leaf packs and then spray WD-40 or something similar, this will at least let you know if they are the culprits.
  7. Sep 17, 2012 at 7:43 PM
    bowhunter95
    TJ
    Illinois
    Black Lifted tacoma
    When I hit a bump or a hole in the road she"ll squeak.
  8. Sep 17, 2012 at 7:47 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Let me guess. Also when you accelerate?
    It's most likely the leaf pack. Pressure wash it and if still isn't gone use wd-40
  9. Sep 19, 2012 at 1:56 PM
    SoFlaTacoma
    SoFlaTacoma New Member
    Steven
    FL
    '07 Black on Black Sport w/ 3" Toytec lift
    HID's, LED's inside and out, GrillCraft grill, stubbie antenna, custom FL TRD badge, Flowmaster American Thunder dual exhaust, 3" ToyTec Ultimate lift, Avid Offroad Hitchstep
    Just went mudding a couple of weeks ago and came back with a squeak too. I only heard the squeak in reverse though ... turned out to be a U-Joint issue
    Try spraying and cleaning your leafs and suspension first, if that doesn't work next I'd check the U-Joints
  10. Dec 23, 2012 at 9:42 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    had the same issue. when u wonna wash your truck next time, go to a wash it yourself place with those pressure washers. I shot that in between each leaf on both sides and seemed to clear it all up. it worried me at first too but, simple fix! Good luck
