Ever turn on 4-high while going 60mph?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris Miles, Apr 3, 2017.
Thread Status:
Not open for further replies.
  1. Apr 3, 2017 at 1:34 PM
    Chris Miles
    Chris Miles [OP] Well-Known Member
    2016 Toyota Tacoma
    Trailer Hitch Cover - Star Wars Pulp Fiction Boba Fett & Stormtrooper
    Hi TW,
    I was reading the owners manual (because I'm a nerd) of my 2016 and it stated that 4-high could be switched on while going ~60 mph. I was going to try that this morning while driving to work, but chickened out. I'm sure it's safe, otherwise they wouldn't have put it in the manual. I'm not sure what real-world solutions would call for this, but I'm sure many have done it.
    Have you done this, why, and did anything unexpected happen?
    Thanks,
  2. Apr 3, 2017 at 1:36 PM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    60 mph is the max you want to be going while switching into 4-high. I'm guessing it might be useful when encountering slippery road conditions while going highway speeds.
    I have not done this going that fast, but I have done it around 40-45 mph.
    FirstTacoma!! likes this.
  3. Apr 3, 2017 at 1:37 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    i have, just make sure you are cruising or coasting and it will be fine.
    cruxofthebisquit and Firebird like this.
  4. Apr 3, 2017 at 1:38 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Yes, it just beeps and blinks at you.
    NickleCityTaco likes this.
  5. Apr 3, 2017 at 1:39 PM
    su.b.rat
    su.b.rat broken truck
    i do all the time as you describe. it's seamless, no problem at all. you don't even feel it if you're off the throttle, which of course you should be.
    cruxofthebisquit likes this.
  6. Apr 3, 2017 at 1:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you have to wonder if you need four high, you already should be going slower than normal. If you have to wonder if you need four high, switch to four high.
  7. Apr 3, 2017 at 1:42 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    The manual states that you have to be below 62mph when engaging 4HI. You can go as fast as you like when in it though. I've had mine up to 80MPH. Your not going to break it, just don't do any crazy maneuvers or sharp turns
  8. Apr 3, 2017 at 1:44 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    this.
    I haven't tried it, because I haven't been in the situation to need 4hi while doing those speeds. To me, if you need 4hi to keep traction you shouldn't be going those speeds anyways.
    Think the fastest I was going and turned it on was around 40km/h. Too much snow, so just switched over to 4x4.
    musher likes this.
  9. Apr 3, 2017 at 1:45 PM
    Joe23
    what's the point of being in 4x4 at those speeds? Unless this was desert racing I don't see the point.
    BThorson, At The Helm and aceiswar like this.
  10. Apr 3, 2017 at 1:47 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    To exercise the front diff, manual says to go at least 10 miles per month just to keep the 4HI lubricated. Well I don't go off roading often enough to fill that quota so whenever the streets are wet here I put it in 4HI on my drive home from work just to exercise it.
  11. Apr 3, 2017 at 1:50 PM
    su.b.rat
    because it gets you your requisite 50 (or however many) miles/month of 4x4 real quick like! lol
  12. Apr 3, 2017 at 1:52 PM
    Joe23
    I'd be worried about causing damage though doing that.
    But to each their own.
  13. Apr 3, 2017 at 1:54 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I don't see why. It's a 8" diff just like the rear (for 3rd gen sport models anyway). You'd think if in anyway it could cause damage Toyota would put some sort of safety to auto disengage at a certain speed. But to each their own, if you don't feel comfortable doing that by all means don't do it. You shouldn't ever do anything to your truck that you don't feel comfortable with.
  14. Apr 3, 2017 at 1:56 PM
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    Has anyone noticed any difference in gas mileage when you are in 4x4 HI ? If yes, how much of a delta is it?
    (Also, isn't there a thread here from a while back who broke his front diff doing normal 4x4-ing, and when contacted Toyota and they responded basically 'no mas' to him. Got told that he shouldn't be doing 4x4-ing. He had pictures and everything, there was some piece made in plastic that broke off. I can't find that post)
  15. Apr 3, 2017 at 1:56 PM
    su.b.rat
    I'm neurotic about damage and that kind of thing. when i do that it's on a very wet road and only in a straight line. if there's a bend in the road i turn off the 4x before it.
  16. Apr 3, 2017 at 1:57 PM
    dc2truck
    dc2truck Well-Known Member
    It just makes the steering stiffer. Did it on the freeway.
  17. Apr 3, 2017 at 1:57 PM
    Joe23
    its not the speeds I'm concerned with its too much grip and causing damage lol.
    Rain isn't usually enough unless its really pouring to allow the wheels to slip.
  18. Apr 3, 2017 at 1:57 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    YES! I'll get about 15 - 16 miles to the gallon depending on how hard you push it. But again the 4HI shouldn't be driven engaged all the time, just when traction is an issue or for exercising the system
  19. Apr 3, 2017 at 1:58 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I would agree with you on city streets, rain isn't enough to allow slippage, but on Highways I've never felt any kind of binding
  20. Apr 3, 2017 at 2:00 PM
    koditten
    Kirk
    Central Michigan
    I actually get better mileage in 4high. Speeds are generally less than 55mph. At 80mph the truck is using more fuel in 2 wd.
    I've noticed this with my 2nd gen Tundra as well.
Thread Status:
