Ever wonder how fast your auto tranny can overheat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AddictedOffroad, Dec 3, 2013.
  1. Apr 20, 2014 at 11:04 PM
    #41
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Do a power brake. Foot on the brake, put the transmission in 1st gear. Bring the rpms to 1500. Thats how I got my fluid temps up to check my fluid level after installing my Tru cool 4454. I also bypassed the factory cooler. It took about a minute to get the temp to operating range.
  2. Apr 21, 2014 at 8:29 AM
    #42
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Wouldn't recommend anything other than Toyota's fluid or Amsoil. Amsoil synthetic will probably lubricate a bit better and handle the heat better (wont break down as fast) but it wont really change any temps noticeably. Better to just get an aux cooler.
  3. Apr 21, 2014 at 8:31 AM
    #43
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    So something like mobile 1 atf isn't a good idea? As far as trans coolers go, the bigger the better or will a larger surface area make no difference?
    About how much is amsoil per quart?
  4. Apr 21, 2014 at 8:40 AM
    #44
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Larger surface area and more capacity is better.
    You need to look into how a standard torque converter works to understand how a locking one works. It's very similar to a viscous clutch but you have one side driving fluid at the other though a 'stator'. They're not fixed together, one side is fixed to the engine and the other the trans and they only move through directing fluid --- when you don't have a lockup clutch.
    The way the fluid moves causes it to heat up a lot when your impeller and your turbine are at vastly different speeds. This is why the lockup lowers the temp.
    http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/information/torque-converter.htm
    Just fyi...
  5. Apr 21, 2014 at 9:14 AM
    #45
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Amsoil can be very expensive. Dont recommend Mobil 1, no (or any other brand for that matter). Toyota's fluid is probably the best you can get (its very good) excluding, maybe, amsoil. I don't think its worth it honestly and would stick with Toyota's fluid. They dont go cheap on these things.
  6. Apr 21, 2014 at 12:04 PM
    #46
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    best thing is OEM or equivalent fluid and frequent oil drain and fill, Better oil cooler, don't punish your vehicle while towing specially on grades.
    torque converter explained here:
    https://www.youtube.com/watch?v=z5G2zQ_3xTc
  7. May 10, 2014 at 1:52 PM
    #47
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Not to bring up an old thread, but I used to tow in OD, because in florida we're mostly all flat, so there's no gear hunting. Is that bad?
  8. May 10, 2014 at 3:09 PM
    #48
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    As long as your clutch stays locked, you're fine.
  9. May 10, 2014 at 3:17 PM
    #49
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    Our trucks don't have OD button!
  10. May 10, 2014 at 3:33 PM
    #50
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    No, but you have a spot to turn off the OD,when you're in d, slide the shifter to the left and it's in 4 (The trans will only shift from 1-4, so OD is off), down to 3 (trans will only shift from 1-3) down to 2 (trans will only shift from 1st to 2nd) and 1 (trans is locked in 1st).
  11. May 10, 2014 at 3:35 PM
    #51
    G8keepr
    Rich
    North central mass
    2017 TRD OR
    Are you saying fifth gear is overdrive? Never heard it called that before.
  12. May 10, 2014 at 3:40 PM
    #52
    95 taco
    95 taco Battle Born
    Yes, the gearing in 5th gear is Higher than 1:1 (I think it's .6x:1, it's .85:1 for the 6 speed)
  13. May 10, 2014 at 3:45 PM
    #53
    G8keepr
    Rich
    North central mass
    2017 TRD OR
    I'm totally confused now.
  14. May 10, 2014 at 3:47 PM
    #54
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    There was a time ppl never heard it called fifth gear before :D
  15. May 10, 2014 at 3:50 PM
    #55
    95 taco
    95 taco Battle Born
    Whoops, meant that 5th gear is higher (numerically lower) than 1:1
    A overdrive gear means that the gear ratio is 1:1 or higher, 5th gear is geared .6x:1 , 6th gear on the 6spd is geared .85:1, hence 5th gear on the auto trans and 6th gear on the manual trans are OD.
  16. May 10, 2014 at 3:53 PM
    #56
    G8keepr
    Rich
    North central mass
    2017 TRD OR
    The jeepers with nine gears must be going crazy!
  17. May 10, 2014 at 3:54 PM
    #57
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Underdrive gears mean the trans is spinning slower than the engine. Good for making torque (multiplies or increases torque output) but bad for MPGs. Any gear smaller than 1:1 is an underdrive gear.
    Overdrive gears mean the trans is spinning faster than the engine. Horrible for making torque (reduces torque output) but good from MPGs. Any gear that is taller than 1:1 is an OD gear.
    Many cars also have a 1:1 gear where the engine and trans are spinning at the same speed. (generally the 4th gear in a 5 sp or 5th gear in a 6 sp).
    Im pretty sure 1:1 isnt an OD gear but we may be splitting hairs :notsure:
  18. May 10, 2014 at 4:50 PM
    #58
    smmarine
    Melbourne FL
    So basically if I tow in overdrive, and my clutch is staying locked I'm ok. But if it's too much weight/a grade and my clutch keeps unlocking I just need to take it out of OD?
  19. May 10, 2014 at 5:11 PM
    #59
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    That's correct.
  20. May 10, 2014 at 5:31 PM
    #60
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    ^ This
    Also would want to consider an aux cooler if you tow a lot. You are still putting more stress/heat in the lower gears.
