everyday towing with 2.7
Discussion in 'Towing' started by roycameron, Apr 1, 2012.
  1. Apr 1, 2012 at 6:00 AM
    roycameron
    roycameron [OP] Member
    11 tacoma 4X4 2.7 5 speed
    I am a carpenter, and currently use my ac 2.7 4X4 man, as my work truck. i am thinking about getting an alum enclosed. curb weight of 800 empty and tongue 80 pound. probably have 800 pound in it roughly every day. would it be stressing the 2.7 and clutch to much to pull 1600 every day? i am in Canada so the rear end end tsb has been done in factory.
  2. Apr 2, 2012 at 6:11 AM
    nhtundra
    nhtundra Well-Known Member
    NH
    2015 Dcab Sport Barcelona Red
    The 4cyl, 5spd, 4x4 is rated for 3500lbs, so you should be fine to tow 1600. I have towed a 2500-3000lb boat, without a problem.
  3. Apr 2, 2012 at 6:34 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I would consider a tanden axle trailer if possible. This lowers your tounge weight a bit and I think you will prefer it in the long run. I feel that the 4X4 truck and trailer will be a good combination for your work. You may consider a rear anti-sway bar for the truck, about $125 from Addco, for windy days.
