Everything goes in 2nd g forum
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BryanCO, Oct 10, 2014.
  1. Oct 10, 2014 at 8:56 PM
    BryanCO
    BryanCO [OP] Well-Known Member
    Bryan
    Pinedale WY
    06 TRD OR DCSB
    Battery post in fuse box
    Does anyone use this? I have not seen mention of it on the forum, although I am somewhat new. I have an led light bar and under-hood lights hooked to this post. Is there a reason I should or shouldn't do this? I think it looks cleaner. Thanks
    Attached Thumbnails [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  2. Oct 10, 2014 at 9:09 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    You have fuses on said lights, right?
  3. Oct 10, 2014 at 9:29 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    There are tons of great howto posts on TW covering this topic. Here is one if you want an install guide for non-OEM lights:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/3990-non-oem-fog-light-install-anytime.html
    Electrical problems can be costly and to avoid them be sure to do a proper install. If you are not confident with electricity and electrical systems better pay a local shop to do it for you. Some basics: you'll want good heavy gauge wiring, an automotive relay, an in-line fuse, a switch, and an add-a-circuit connector.
    I usually tap into the battery leads for my add-on wiring needs and avoid the factory fuse box.
  4. Oct 11, 2014 at 9:49 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    too late
  5. Oct 11, 2014 at 10:08 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Wow OZ.....you're like a wizard or something. :rolleyes:
    Just one question though: Are you a good witch or a bad witch?
    :rofl::rofl::rofl::rofl::rofl::rofl:
  6. Oct 13, 2014 at 8:15 AM
    BryanCO
    Bryan
    Pinedale WY
    06 TRD OR DCSB
    Sorry for the duplicate posts. A few beers and patience isn't my virtue. I had tried a search but probably wasn't using the right terminology. All the electrical components I installed on that battery post came preassembled with fuses/relays so I figure I should be good. Was just curious why most of the posts I see installing aux lights and such connected to the battery instead. Maybe this will help someone else.
  7. Oct 13, 2014 at 8:44 AM
    OZ-T
    Peter North
    British Columbia
    No big deal , I was just having some fun
