Everything is still not enough!
Discussion in 'Wheels & Tires' started by mattcombs, Jan 23, 2011.
  1. Jan 23, 2011 at 5:08 PM
    mattcombs
    mattcombs [OP] Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    Got 4:88 gearing 6 inch stage 1 procmop lift and 35 inch mudd grapplers. i wana runmy 16 inch dc2 wheels with the 4 inch backspacing. the lift calls for a 17 inch wheel so what size wheelspacers will i need to clear my 16s? would spidertrax 1.25 work?
  2. Jan 23, 2011 at 5:31 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
  3. Jan 23, 2011 at 5:37 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    not sure too many people have tried to do that...sounds like it'll be killer on the wheel bearings though
  4. Jan 23, 2011 at 5:38 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    lol id say. theres a few around i beleve, i just like the look of big rubber and medium wheel. Looks like its gona be a hard one for some of the experts ho lol. just hope i can get a little help
  5. Jan 23, 2011 at 7:15 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
  6. Jan 24, 2011 at 7:54 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
  7. Jan 25, 2011 at 3:30 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
  8. Jan 25, 2011 at 5:34 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
  9. Jan 25, 2011 at 7:34 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    man this is a tough . i really am gettin worried
  10. Jan 25, 2011 at 7:48 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    i wna keep my same wheel just add a spacer to the hub, im sure this is very similar tho. i just need to know if i got a 1.25 if i could run that 6 inch lift n 35's. thanks for the input
  11. Jan 25, 2011 at 7:50 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    id love to not have to add the spacer but the lift says it needs a 17 inch wheel and i think its because it needs a larger backspacing
  12. Jan 26, 2011 at 8:44 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
  13. Jan 26, 2011 at 8:46 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    It will work, I've seen someone use the 16" offrooads with a spacer 1.25"
  14. Jan 26, 2011 at 8:50 PM
    kinkrider101
    santa barbara
    wheels and tires
  15. Jan 26, 2011 at 8:51 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I think it has to do with the actual diameter of the wheel, not the backspacing. The new components required with the db lift interfere with the wheel and the larger diameter (17" or more) is required to clear this.
    edit: actually my above statement seems to be incorrect. Another build used his stock wheels with the 6" db lift. This is what he said:
    "yeah.. you need to order at least a 1.25 inch wheel spacer (only on the front end) to clear the tie rods.. thats why i'm able to mount and run my stock wheels tires.. "
  16. Jan 26, 2011 at 8:53 PM
    jhodge83
    SC
    17 XLT Sport
    he is already running a 4" BS that is 1.5" less than the stock ORs you are talking about. if those dont work, the spacers will help destroy the wheel bearings quick.
    right, but if the wheel sticks out far enough from the spindle, etc, the diameter will not come into play. i think that's what he is going after.
  17. Jan 27, 2011 at 4:20 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    my 16 wheels do have a 4 inch backspacing and are 8 inches wide, the 6 inch lift says it requires a 17 inch wheel and i read it was so you could get the wheel sitting out under the wheel well a little more to clear. so i haven't had these wheels long and don't have the money to buy new ones. They do clear the calipers and fit even tho 4wp said they wouldnt. thanks for the help.
  18. Jan 27, 2011 at 4:24 PM
    kinkrider101
    santa barbara
    wheels and tires
    so they worked with the 6" lift no problems?
  19. Jan 27, 2011 at 4:34 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    no i havent installed yet. they claimed they would not clear the brake calipers, they did tho with no modification. i just wonder if that the same reason they say to upgrade with the 6" lift or is it a different problem. basically, why do i need a 17inch wheel with a 6" lift then go from there i guess lol. seems to be a question not seen with much
  20. Jan 27, 2011 at 4:44 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    With a 6" lift the tie rod is relocated and thus will get in the way of a 16" wheel.
