Everything LEGO thread!
Discussion in 'Off-Topic Discussion' started by HomerTaco, Nov 28, 2012.
  1. Aug 10, 2022 at 9:04 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    LOL at the new avatar :thumbsup:
    And I saw they announced the birthday contest winners. All but the micro scale which was supposed to be a GWP
    Thought about entering but didn't have the time for it. Was trying to figure out a minifig version of "the evolution of Man" or something like that
    PzTank[QUOTED] likes this.
  2. Aug 10, 2022 at 9:47 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I want a black Toyota pickup to go with the delorean.
    Or I think they should upsize the gravedigger to be truly monster scale in comparison to the other auto models
    mbarbay and ETAV8R like this.
  3. Aug 10, 2022 at 11:26 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    MTgirl and Out2gtcha like this.
  4. Aug 10, 2022 at 2:22 PM
    MTgirl
    Weesa
  5. Aug 11, 2022 at 2:53 AM
    PzTank
    Above the Notches
    1957 Nash Metropolitan
  6. Aug 11, 2022 at 6:41 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I like your drink delivery droid.
  7. Aug 11, 2022 at 7:01 AM
    PzTank
    Above the Notches
    SPACESHIP!!!
    ETAV8R, odomandr, buffedout and 9 others like this.
  8. Aug 11, 2022 at 7:24 AM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
  9. Aug 11, 2022 at 7:19 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Fun little build tonight.
  10. Aug 11, 2022 at 8:06 PM
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    hopefully :fingerscrossed:
    EODTRD and PzTank like this.
  11. Aug 11, 2022 at 9:47 PM
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
  12. Aug 12, 2022 at 6:11 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    Well I broke down and ordered the parts to build the SR-71 that LEGO IDEAS didn't select.
    It wasn't nearly as bad on cost as I thought it would be...still will be my most expensive set thanks to shipping charges.
    It was ~$169 for the parts alone ( most of them overseas....if I went with strictly US it was like $337). Thanks to shipping charges it came out to $260.
    I had to create the parts list myself, so if anyone else is interested in the list, I can DM the Excel sheet to you. Hopefully I am not missing anything. I will try to update as I go.
  13. Aug 12, 2022 at 8:19 AM
    PzTank
    Above the Notches
    Good luck with the build and thanks for the offer for the Spreadsheet :thumbsup:.
    I used the technique here to create a template for efficiently entering parts that can be exported to BrickLink using BL requirements for an XML doc.
    https://blog.udemy.com/excel-to-xml/
    BrickLink XML requirements:
    https://www.bricklink.com/help.asp?helpID=22
    I use Part, Item#, Color, and Condition as elements. Sometimes when order multiple sets, I’ll add Remarks.
    Scroll down that page for the values (tags) to enter for each element.
    Anyone, feel free to reach out if you want.
    Happy Building!
    Edit - this is what one, new, metallic silver, lightsaber hilt looks like in XML
    <item>
    <itemtype>P</itemtype>
    <itemid>64567</itemid>
    <color>67</color>
    <minqty>1</minqty>
    <condition>N</condition>
    </item>
    EODTRD and mbarbay[QUOTED] like this.
  14. Aug 13, 2022 at 3:45 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    Bags 1-6 are done. Definitely need patience with this one. Only problem I had is when I was putting a side piece on, some small obscure part came loose on the inside and now I have a rattle. I refuse to even think about finding it.
  15. Aug 13, 2022 at 4:01 AM
    PzTank
    Above the Notches
    Patience grasshopper….
    JonathanH[QUOTED] likes this.
  16. Aug 13, 2022 at 4:05 AM
    JonathanH
    Jonathan
    Southern Maryland
    11' DCLB
    I have plenty of it. I'm usually building 2 bags at the most and double checking myself.
  17. Aug 13, 2022 at 4:25 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    With that attitude you'll never be a real nasa engineer
    mbarbay, ETAV8R, buffedout and 2 others like this.
  18. Aug 13, 2022 at 2:17 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Finally finished it.
    The build was fun. Both of my yellow windscreens were scratched. Not happy about that at all. The airlock door kept falling off and I had to investigate what I did wrong. I didn't have the bottom most piece engaged in the groove below. I also used a couple transparent studs to indicate "go/no go" situation. Another change I did was reduce the amount of vertical fins on the back. Eight seemed like far too many. The leftover pieces can be used to elevate a moon base structure.
    And finally of course the buggy got some improvements with leftover pieces.
  19. Aug 13, 2022 at 2:35 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Placed it in the display case...too large to fit flat. I want to buy a couple more copies of this set.
  20. Aug 13, 2022 at 2:45 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
