Everything MOLLE BS
Discussion in 'Automotive Group Buys' started by docloco, Jan 13, 2016.
  1. Mar 22, 2021 at 2:10 PM
    #4401
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    I paid extra for the powdercoat then had to drill four new holes in the panel because only two were in the right place.
    My Prismatic color is listed as flat but it still had a shine to it. So consider the option of sanding/degreasing it and hitting it with Rustoleum Camouflage Flat Black. If you follow the directions lays down really evenly with no blotchy rattle can pattern in the finish, and you can touch it up later if needed.
    Of the ones you have listed, only Caveman will not be shiny. Also look at Black Jack. It will be slightly shinier than Caveman but it also looks good. I think you might find that Black Jack will look like the black plastic trim like the window switches, etc. The project galleries on their website have a lot more examples than what is shared on each product listing.
    BudFriendguy[QUOTED] likes this.
  2. Mar 22, 2021 at 3:15 PM
    #4402
    Smokes
    Smokes Well-Known Member
    @TomHGZ
    I appreciate the feedback. Any pics of the two correct holes and what did you use to mount the other 4?
  3. Mar 22, 2021 at 4:27 PM
    #4403
    JJshib
    JJshib Well-Known Member
    14 Tacoma DC Off Road
    im in for #25
  4. Mar 22, 2021 at 8:21 PM
    #4404
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I’m interested and somewhat local. Silverdale area.
    docloco[OP] likes this.
  5. Mar 23, 2021 at 6:44 AM
    #4405
    TomHGZ
    On my truck, which might be different than yours, I could choose whether I wanted the top holes or the bottom holes to line up, and then drill new holes for the other row. I chose the top, but still had to lengthen two holes on the top, along with drilling new holes for every bolt on the bottom. But that's just me, and you might not have to drill out any holes at all, depending on how your panel was made, and what the measurements of your truck are.
  6. Mar 23, 2021 at 6:45 AM
    #4406
    TomHGZ
    PM'ing you.
  7. Mar 23, 2021 at 9:47 AM
    #4407
    Smokes
    @TomHGZ
    I would think their the same since mine is also an AC. Here’s a pic of mine loosely fitted to the rear panel. Can you tell me based on this which holes on the panel lined up with the factory holes? I don’t want to put holes in the sound deadening material if I don’t have to. Much appreciated!2679CE6C-8C4B-4DAF-BFE2-A8A44624D90F.jpg
  8. Mar 23, 2021 at 10:24 AM
    #4408
    TomHGZ
    My install.
    Drill out the spot welds and pry off the baby seat eyes (or cut holes in your panel). Drill a little bigger diameter than what I did here. If you tap them off with a hammer and chisel like I did, plan on sharpening your chisels afterward.
    Most of the noise comes from the cabin vent (that black box in the middle), but sound deadener still helps some.
    You don't have to remove these tabs, but they tend to get in the way when you are testing fit.
    I decided to paint my already-powdercoated panel with Rustoleum Camouflage Black to make it less reflective. My paint booth is a popup tent. Wear a respirator and follow the can's instructions. This particular paint lays down really evenly.
    Most of my mounting holes did not line up so I had to drill new holes in the panel. Test-fit before painting.
    I installed gray vinyl leather upholstery that matches my gray leather seats. I simply used VHB tape and worked fast and rough since it will be behind the panel anyway. I did get it smoother than this in the end.
    The air vent in my 2014 access cab is off center, so I framed it in a black piece of carpet that is centered.
    I rolled another piece of carpet up and jammed it in above the vent (breathing through the roll of carpet first to make sure some air can still pass through). This vent is the source of the majority of road noise, and the carpet baffles it. There are probably more effective baffles; this is just what I did.
    End result before the floor deck is installed.
    This Rubbermaid trash can fits between both seats when they are reclined. I put a screw in the back so the fliptop only opens one way, and so the wind from the open back window (or steep or bouncy terrain) can't easily open it. I will likely replace this trrash can with a soft bin in the future, but for now, I like this.
    Lastly, I have some black stair edging (think rubber angle iron) which will wrap those gray corners on each side and make the whole thing more finished-looking. To-be-installed after I install the floor deck.
  9. Mar 23, 2021 at 10:29 AM
    #4409
    TomHGZ
    I just posted a comment with my build pictures so you can see. But I believe specs may have changed even with the access cab between your year and mine. I highly recommend test fitting the panel without sound deadener first, to see which holes you want to use or will have to re-drill.
    90% of the rear noise comes from that back cabin vent. Jam some napkins in the holes and drive down the road to see what I am talking about. You are not going to achieve much sound suppression by wrapping the top bar.
    BudFriendguy likes this.
  10. Mar 23, 2021 at 10:36 AM
    #4410
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    People have posted on here how 3rd Gen are such quiet trucks --not in my experience, so much road/wind noise!
    When this panel arrives I'm taking the opportunity to Noico that entire back wall.
    Kommander likes this.
  11. Mar 23, 2021 at 1:17 PM
    #4411
    Smokes
    @TomHGZ
    Much appreciated! Those pics are helpful and it looks good. What size bolts did you use, 10mm?
    BudFriendguy and docloco[OP] like this.
  12. Mar 23, 2021 at 9:51 PM
    #4412
    Disciplenmh
    Disciplenmh New Member
    2021 Green Tacoma TRD Offroad
    I’m in. DIY stuff isn’t working. This looks solid!
  13. Mar 24, 2021 at 6:45 AM
    #4413
    SK88
    SK88 New Member
    Sarah
    Missouri
    2014 TRDOR MT AC
    Count me in for #25 group buy please!
  14. Mar 25, 2021 at 4:33 PM
    #4414
    SmilingRealBig
    SmilingRealBig New Member
    Duke
    SoCal
    2014 Tacoma double cab
    Count me in for #25 group!
  15. Mar 25, 2021 at 4:45 PM
    #4415
    docloco
    docloco [OP] Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    Pm sent.
  16. Mar 25, 2021 at 5:10 PM
    #4416
    TomHGZ
    The bolts are the OEM bolts that were already in the holes.
    CygnusX191 likes this.
  17. Mar 25, 2021 at 7:46 PM
    #4417
    justhaag
    justhaag Well-Known Member
    Mesa, AZ
    2017 Quiksand Tacoma TRD Off-road 4x4
    Finally got around to installing mine tonight! Now I just need to buy ALL the molle accessories
  18. Mar 30, 2021 at 11:08 AM
    #4418
    pizzaviolence
    pizzaviolence Member
    Mikey
    Idaho
    2nd Gen Access Cab TRD Off-Road
    In chronological order: Firestone Ride-Rite air springs, Driver Side Conceal Pistol Mount, Cali-Raised Tailgate Antenna Mount/CB Radio, Relentless Bed Bars, CVT Tent, Cali-Raised Bed Stiffeners, Cali-Raised Hidden Lightbar brackets/Auxbeam 34" LED Bar, Cali-Raised hoodmount brackets/Auxbeam LED Pods, Auxbeam LED floods (installed rear facing on bed bars), STL 6-CSB Switch Box w/ custom Relay/Fuse box, Method 305NV Wheels (Bronze), Icon 2.0 Rear Shocks, BF Goodrich KO2 Tires, Pocket Fender Flares, 4X Innovations Weld On Sliders
    I'd like to be part of #25 group buy
  19. Mar 30, 2021 at 11:52 AM
    #4419
    docloco
    Ron
    Florida
    Pm sent
  20. Mar 31, 2021 at 5:32 PM
    #4420
    Emilionare96
    Emilionare96 New Member
    Tucson, AZ
    2011 Silver TX Pro TRD
    I’d like to be in group 25 please!
