Everything MOLLE BS
Discussion in 'Automotive Group Buys' started by docloco, Jan 13, 2016.
  1. Apr 19, 2016 at 10:29 AM
    #661
    UssMoGn
    UssMoGn That Vegas dude
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Home Built Front Bumper HID Headlights LED Cab lights 2013 Radio swap MOLLE DC Insert Traffic Cam F&R 6'' Procomp lift Custom Grillie
    Thanks for the reminder I forgot to get Velcro straps off Amazon.
    GHOST SHIP[QUOTED] likes this.
  2. Apr 19, 2016 at 10:42 AM
    #662
    UssMoGn
    James
    Las Vegas NV
    05&04 Tacoma SR5
    @GHOST SHIP With your fix I'd suggest moving the plate till the bottom bolts line up and make the upper 4 bolts a bigger as you need. The top latch plate acts as giant washer so won't have worries of make the hole too big. Unless moving it up too much makes your top stick out past the seats.
    GHOST SHIP likes this.
  3. Apr 19, 2016 at 10:53 AM
    #663
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Thanks! I thought of that as well. I want to make sure I can get everything lined up before I start cutting it up and ruining a perfectly good panel! I'll take a closer look at it once I get out of work. Want to be as minimally invasive as possible.
  4. Apr 19, 2016 at 10:55 AM
    #664
    docloco
    docloco [OP] Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    How did the top side tabs line up for you?
  5. Apr 19, 2016 at 10:57 AM
    #665
    GHOST SHIP
    GHOST
    They look good! But it's just sitting there and not bolted up yet. I'll have a better report for you later today.
    docloco[QUOTED][OP] likes this.
  6. Apr 19, 2016 at 5:00 PM
    #666
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Having the same issue as others maybe 2 of the holes lined up everything else was off, but whatever
  7. Apr 19, 2016 at 5:04 PM
    #667
    docloco
    Ron
    Florida
    Sorry to hear. Got pics?
  8. Apr 19, 2016 at 5:10 PM
    #668
    GHOST SHIP
    GHOST
    Bad news folks- the panel is not a direct fit for the AC. Mounting holes are different (not a big deal to drill new holes) for the seat back brackets/ headrest mounts. The big difference is the lower child safety restraints. On double cabs they are vertical and placed further outboard. On access cabs, they are closer to being centered and are angled at about 45 degrees. The support ribs for the back wall are in the same location for both body styles though so that should give @docloco a starting point if he decides to proceed with designing a panel for you AC guys. One other small difference that was noted was that the plastic trim panels for the rear corners of the cab do not have the small cutout that is present in DCs. One more thing to note is that since the AC back seat does not fold down, installing this panel would basically mean deleting the back seat completely or at least making an already uncomfortable seat even more so if you ever plan on stuffing someone back there.
    Big thanks to @james Daniel for tearing his truck apart so we could make this comparison.
    docloco[OP] likes this.
  9. Apr 19, 2016 at 5:15 PM
    #669
    docloco
    Ron
    Florida
    Thanks for the info. Sorry to hear it didn't work out for you. There have been a few people that expressed interest in buying one so hopefully you can recoup some funds.
  10. Apr 19, 2016 at 5:18 PM
    #670
    GHOST SHIP
    GHOST
    Oh no, my panel is going in my truck! :D So there's no loss for me. I just have someone with an AC that I can count on to help a brotha out. @james Daniel is good people like that. That's the good thing about this site. We help each other whenever we can. Thanks again doc!
    G.T. and docloco[QUOTED][OP] like this.
  11. Apr 19, 2016 at 6:22 PM
    #671
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Could be worse, first i bolted the driver side seat latch and noticed that the passenger side was not lining up so I adjusted and adjusted and couldn't get it to work so instead I got all the lower bolts in and marked where I needed to trim for all the upper bolts. Im guessing most will have the same issue, its real close but needs about 1/8-1/4 to fit correctly. Ran out of daylight so called it quits after marking where I need to trim, ill try to get it finished tomorrow
    UssMoGn and docloco[QUOTED][OP] like this.
  12. Apr 19, 2016 at 6:48 PM
    #672
    htgreen3
    htgreen3 Well-Known Member
    Central Virginia
    2015 TRD OR
    mine's in Richmond, VA for delivery tomorrow
  13. Apr 19, 2016 at 7:56 PM
    #673
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Another point to contend with on the AC is that the Cab pressure/check valve is located in the middle of the bulkhead. @ryanjboutin was commenting on how much road noise that let in when he removed his "useless" rear seats. Just something to think about.
  14. Apr 19, 2016 at 8:18 PM
    #674
    GHOST SHIP
    GHOST
    Got mine prepped for paint. Sanded the smooth surfaces using a long block and 80 grit and rounded off all the sharp edges. Super happy. Need to finish sound deadening install and it can go in for the last time. Turns out you were right @UssMoGn ! With a little more time and daylight I bolted the panel to the truck using the 4 lower holes and then saw where I needed to enlarge the upper holes. Used a unibit and went to 1/2". Fit like a glove now. No need to trim the lower portion anymore.
  15. Apr 20, 2016 at 12:41 AM
    #675
    UssMoGn
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Glad to hear!
  16. Apr 20, 2016 at 11:23 AM
    #676
    UssMoGn
    James
    Las Vegas NV
    05&04 Tacoma SR5
    My Fix + Paint. Now off to sound mat shop. Was able to get a small gap on bottom to for sound mat.
    20160420_091545.jpg 20160420_091551.jpg 20160420_092338.jpg20160420_111558.jpg
  17. Apr 20, 2016 at 11:32 AM
    #677
    docloco
    Ron
    Florida
    For those that expressed interest in another group buy, OP is updated. Currently taking names for another list. Comment or PM and I'll put you on the list.
    armyofsquirrels likes this.
  18. Apr 20, 2016 at 11:45 AM
    #678
    NeverClean
    NeverClean Mr. Dirty
    Indy
    2012 DCLB SR5 4x4
    I'm in. Please and thank you.
  19. Apr 20, 2016 at 11:55 AM
    #679
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    Any update from the AccessCab people?
  20. Apr 20, 2016 at 11:55 AM
    #680
    Michgnxj24
    Michgnxj24 Well-Known Member
    Virginia Beach
    2010 DCSB
    Jeraco Cap, Viair OBA
    It's actually kind of amazing how much fits back there without the plastic cubbies.
