Everything needed for a lift
Discussion in 'Suspension' started by joesmaro, Mar 20, 2023.
  1. Mar 20, 2023 at 7:23 AM
    joesmaro
    joesmaro [OP] New Member
    Joe
    2009 Silver Tacoma TRD Off Road
    What’s up all?!
    Had my Tacoma for a couple years now. 2009 TRD OR. Finally looking to get everything for the lift, i.e. suspension, wheels, tires, etc.
    I have some newb questions. I’ve narrowed it down to the Bilstein 6112/5160 set up with an AAL. Here are my questions:
    With this set up, do I need upgrade UCA or LCA?
    I plan to only go with a 33” tire. 35 would be the largest I’d go but it’ll probably be 33’s. Is there an advantage of getting a 17” wheel or staying with the same size as stock? Or is it personal preference?
    Does the brand of AAL matter? I’ve seen some for $150 and some for $2-300.
    For the clip position on the bilsteins. I planned to do the highest for a 2.5 set up. Clip positions of 11/9. Reading the forums though, nobody ever does that. Is there a reason not to max them out? Should I do a lower position for 2” setup?
    Are there any other parts I need to make this setup work?
    Thank you!
  2. Mar 20, 2023 at 9:27 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I'd say you don't want to max them out because you'll have greatly limited you down travel or droop.
  3. Mar 23, 2023 at 5:32 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    If you want to do things right:
    If you go over 2" you will need new UCAs in order to have correct alignment. And yes you will need to get an alignment from most likely a 4x4 shops. A lot of places will only align it to factor specs.
    If you go with 33s/285, it will rub, so you will need to perform a CMC (Cab Mount Chop). 35s are fairly rare on a 3" lift, so the general consensus, is its not advisable
    AAL brand - Its up to you, so do your research. If you are spending the extra money on 6112 instead of 5100, you might as well get a new full leaf packs
    Clip position - dont max it out as someone said. Just cause you can, doesn't mean you should
    Extended brake lines in the rear - probably will need this.
    If you are on a budget - keeping it under 2" and with 265/32" tires will eliminate the need for UCA, CMC and brakes lines.
    Where ever you end up buy from ask them too. Try Headstrong Offroad or Wheelers.
    Good Luck.
  4. Mar 23, 2023 at 5:45 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Agree with all of the above. Higher clip positions ride like poop. The 6112 loves the middle positions - the closer to the middle, the more it shines. I personally have mine set so low that I only see a 1" lift up front, but it truly rides better than any setup I have ran before.
    I wouldn't go with the cheapest AAL, but most are similar. Make sure the set comes with U bolts and a new center pin. There is one brand out there (Headstrong, I believe) that you don't have to break old clips with your angle grinder. If I did it over again, well, i'd buy the RXT full pack, but if I was buying an AAL again, the Headstrong set is what I would get.
  5. Mar 23, 2023 at 6:01 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I ran 6112’s with a ~2” lift. No problem with the UCA (or LCA). I did put in a sway bar relocate, it’s cheap and easy.
    Running 255/80-17’s. Avoids the CMC
    I’m still running 5160’s with OME leafs. Added +2” rear brake lines.
