Everything Sous Vide!
Discussion in 'Food Talk' started by BabyTaco, Jan 14, 2017.
  1. Feb 3, 2017 at 3:24 PM
    #61
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Picked up 3 packages of bacon at the grocery store, it was the last 3 of the higher end thick bacon that I wanted. Hope they restock soon! More bacon....
    Same as last time 12 hours at 127. Now that I know how good it is went and did all 3. The Rubbermaid commercial Carb-X 12 qt. was a bit small for 3 should probably of only done 2 but it worked.
    Picked up a 2 pack of the Ikea Pot lid organizers and they work great for supporting food to allow even water flow. I only put the legs on every other thread like most people said to do for SV. The top one I just used as a weight. Need to get around to drilling a hole in the Coleman stacking cooler so I can do 4 or more at a time. Drained the grease out of the bags when finished cooking, pan fried one and froze 2. That was dumb need to go pull one out of the freezer now. More bacon...
    scottalot, Kanyon71 and BabyTaco[OP] like this.
  2. Feb 4, 2017 at 1:39 PM
    #62
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    Tried bacon this morning. I used farmlands thick cut bacon found at wallyworld. Damn, that was good bacon. I set it at 145 around 1 pm yesterday and ran it till I made it to the kitchen to make breakfast around 8ish.
    The girlfriend and the roommate agreed that it was a small, but awesome change. Every bite was perfect. There wasn't exceptionally crisp or chewy pieces. Each bite packed similar flavor. I saved about 5 pieces to put on homemade pizza tonight. Stoked.
    scottalot, Kanyon71 and Cold Iron like this.
  3. Feb 4, 2017 at 3:28 PM
    #63
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Have 2 Prime cuts of Ribeye in the SV cooker right now. Ready to throw on the grill for sear in an hour. Going to give it another try and see if patting them dry first and then salting will help build a thicker crust and hopefully more grill like flavor. Plus using higher cuts instead of choice.
    Yeah the bacon difference is subtle but outstanding hard to explain but you nailed it. One thing I'm learning is not to over cook it so that it shrinks up like it normally does when I cook it. No need to, and it yields more bacon per package. Always a good thing :)
    scottalot likes this.
  4. Feb 4, 2017 at 5:23 PM
    #64
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Good find here... I'm looking at the Anova Gen 2 WIFI. And bump for lots of amazing looking food!
  5. Feb 4, 2017 at 10:09 PM
    #65
    Elite777
    Elite777 Well-Known Member
    2015 4 banger MGM Access cab
    Getting better each time
    rob1208, Synergy001, Chipskip and 6 others like this.
  6. Feb 4, 2017 at 10:25 PM
    #66
    Misplaced Nebraskan
    Zach
    Austin
  7. Feb 4, 2017 at 10:51 PM
    #67
    Cold Iron
    Mn.
    2013 AC T|X Baja
    So have to ask is that a Texas thing or what? Never seen that done before so have to ask, just aint normal in these parts.
    Hour and a half at 130 wish would have taken a before picture. Cut was prime but only a little over an inch thick and extremely well marbled as prime should be. On the other hand these turned out much better than the thicker Choice cuts I did previously. After SV cooking the marbling had pretty much disappeared. One just Salt the other Salt and ground peppercorns.
    Sear baby sear. Need charcoal to get a good sear. And to a large extent flavor.
    Finished steaks were juicy as to be expected. Think being thinner and Prime cut it helped a lot. This is likely what all the city folks were going nuts about and paying a fortune for. Missing the complex flavors of the sear and slide on charcoal. Advantage was melt in your mouth and consistency on every bite, crust was good but complexity was missing but just barely. For thinner cuts of Prime will do this again. For thicker 1.5 to 2 inch will stay with charcoal for the whole cook.
  8. Feb 5, 2017 at 6:26 PM
    #68
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    My Sunday regimen 4lbs of chicken breast for the week. 150 degrees for an hour and sear on a 700 degree grill for about 90 seconds a side. By far the best chicken breast you can do and I'm a damn good cook. You just can't get this doneness edge to edge by simply grilling without having the center under done.
  9. Feb 7, 2017 at 8:48 AM
    #69
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I dont think thats normal in any place...
  10. Feb 7, 2017 at 8:52 AM
    #70
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Oh man I am so glad I found this thread :bananadance:
    Sous vide is the go-to gadget in our house for meats. We hardly ever use the grill any more, except maybe for a quick sear. We cook mostly steaks, pork and lamb chops so far - but I am definitely going to try bacon now!
  11. Feb 7, 2017 at 9:24 AM
    #71
    JLee
    Jerry
    Grass valley CA
    Hammered Vg10 Damascus and sharp as hell!
    scottalot[QUOTED] likes this.
  12. Feb 12, 2017 at 8:17 PM
    #72
    JLee
    Jerry
    Grass valley CA
    And for Sunday dinner Steak and Lobster Sous Vied.
    For the Lobster bagged In a foodsaver vacuum bag. With Myer lemon, Garlic, fresh pepper and butter.
    Cooked for 25min and 130 degrees. After the cooking was done I hit it with the smoaking gun in a container and let it sit until everything was plated.
    Dipping sauce is salted butter, Myer lemon and garlic as well as a one inch sprig of rosemary added right at the end when the heat was turned off.
    Steak
    We did two cuts tonight filet mignon and rib cap
    Cooked at 126 for an hour and seared on a 800 degree grille for 40 seconds a side 20 second 45 degree cross hatches for looks :cool:.
    I must say that Lobster was the best I've ever had! So tender and juicy I could of had a few of them. The steaks were amazing as well but I've done those a few times ;) this was the first Lobster I've done and it definitely won't be my last.
    20170212_175044.jpg 20170212_190518.jpg 20170212_193115.jpg 20170212_193132.jpg 20170212_193140.jpg 20170212_193811.jpg 20170212_194029.jpg 20170212_194127.jpg 20170212_194138.jpg
    scottalot, wilcam47, Kanyon71 and 2 others like this.
  13. Feb 12, 2017 at 10:15 PM
    #73
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Fckng woof :drool:
  14. Feb 13, 2017 at 7:53 AM
    #74
    Misplaced Nebraskan
    Zach
    Austin
    Agreed! Looks amazing! May have to expedite my purchase and join in the fun. Forums are great for helping you spend money :stirthepot:
  15. Feb 13, 2017 at 8:15 AM
    #75
    wilcam47
    Will
    Bourbon state
    you could go on that show chopped and showcase your skills :)
  16. Jun 2, 2017 at 8:25 AM
    #76
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  17. Jun 2, 2017 at 8:29 AM
    #77
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    So do I. But's it's on sale :X
  18. Jun 2, 2017 at 8:30 AM
    #78
    IvanM8
    IvanM8 Well-Known Member
    socal
    2017 MGM sport 4x4,
    full tank of gas
    I need to get a new water circulator, mine just took a dump after 4 years :notsure:
  19. Jun 2, 2017 at 8:43 AM
    #79
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Dude you got at least 3X that in charcoal. Maybe you should do like a CL sale on that and make some serious money. :rofl:
  20. Jun 2, 2017 at 8:50 AM
    #80
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    WTF scooter.
