Evil Decal Goo Removal
Discussion in 'Detailing' started by Chimpo, May 11, 2017.
  1. May 17, 2017 at 8:45 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    :eek::bananadead: Got any touch up paint?!!?
    CusterFan likes this.
  2. May 18, 2017 at 4:02 AM
    Chimpo
    Chimpo [OP] Member
    2014 TRD Off Road, white
    Febreeze Air Freshener
    Amazon says it should be here by 8PM today!
  3. Jul 24, 2017 at 5:19 PM
    47driver
    47driver Well-Known Member
    Brandon, MS
    I used a similar method to post #19 alernating goo gone/ heat gun. Then polished with Mckee's 37 all in one. Just like it was never there.
    scottalot likes this.
  4. Aug 22, 2017 at 7:13 PM
    gsesupport1
    gsesupport1 Active Member
    18 Cement DCLB 4x4 TRD Sport
    Running Boards, Sprint Booster, Remote start, Custom vinyl decals, Valve stem caps (little green hand grenades)
    It is dirt that has gotten under the edge of the film.
    If you don't want to take it back to the dealer or they say there is nothing they can do, below is the fix!
    To remove: using a small break away razor knife, snap off so you have a new edge or just start with a new blade.
    Using a steady hand cut along the film beyond the dirt [you are not going to try to cut through the film] and score a line along the entire edge so you will have a nice crisp new line when finished.
    Gently get under an area and pull on the film, it should just tear away where you scored the line. If it doesn't tear away find the line and score a little deeper and try again.
    After you have remove the film use a mild detergent to remove the dirt, if it feels a little sticky from the film use goo gone or alcohol to clean the area.
    Finally add a new coat of paste wax to seal the paint.
    I have used this technic on my clear bra that I have installed on my Avalon. My guy that installed the film told me how to do it. Works like a charm.
    Good Luck :)
