Exactly how risky is a lift..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jordancarfi, Aug 28, 2019.
  1. Aug 28, 2019 at 8:39 PM
    eon_blue
    Azusa, CA
    Doesn't really have much to do with offroading, it has to do with how it changes the geometry of your driveline, axles, etc. and the added stress that puts on them. 3" is pushing it for a 4wd unless you do a drop bracket lift.
  2. Aug 28, 2019 at 8:47 PM
    Prowlah
    Prowlah Well-Known Member
    SoCal
    2017 Silver DCSB TRD Sport 4x4
    That's what she said
    TimC and Desolate like this.
  3. Aug 28, 2019 at 9:52 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Less dangerous than texting and driving
  4. Aug 28, 2019 at 10:01 PM
    wessyder
    wessyder Enlightened OR Bro who don't need no skewp
    2019 Tacoma TRD OR, basically an off road race truck
    Tied several boat anchors to my truck to destroy MPG.
    Crappier mpg. If you have a warranty I’m betting that voids it. Things be out of spec/unaligned unless you do the lift the right way. It’s expensive. Then you’ll want bigger tires.
    You should totally do it.
    TimC likes this.
  5. Aug 28, 2019 at 10:04 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    stun gun likes this.
  6. Aug 29, 2019 at 9:15 AM
    Desolate
    Desolate Well-Known Member
    20000 miles on my 3" lift. No issues at all.
  7. Sep 12, 2019 at 1:39 PM
    COyotabrothers
    COyotabrothers Active Member
    I'm new to all this so I'm just soaking up the knowledge. How do they have such high clearance without a lift?
  8. Sep 12, 2019 at 1:44 PM
    eon_blue
    Azusa, CA
    Clearance is best gained with bigger tires. A lot of those crawlers have huge tires that they make fit by cutting a lot of the body and other parts off, wider axles to clear the fenders, etc. Bigger tires brings the entire vehicle higher off the ground, not even a suspension lift can do that.
    With our trucks you're pretty limited on how big of a tire you can fit unless you really don't mind taking a sawzall or angle grinder to your truck. Not to mention the limitations of the stock drivetrain versus heavy ass tires
  9. Sep 12, 2019 at 2:23 PM
    COyotabrothers
    That makes sense, for some reason I had it my head that you had to have a lift for bigger tires. As you said it's probably only so you can put bigger tires on a truck without having to heavily modify it. Thanks for the info!
  10. Sep 12, 2019 at 2:24 PM
    Fye123
    Fye123 Well-Known Member
    2022 TRD off road.
    Any lift at all will put extra strain on a vehicle.
  11. Sep 12, 2019 at 2:31 PM
    eon_blue
    Azusa, CA
    Lift can help fit bigger tires to an extent, but really the only way to fit bigger tires is to have the right wheels/backspacing and be willing to cut/trim where necessary
  12. Sep 12, 2019 at 2:31 PM
    SpeySquatch
    2016 TRD OR DCSB
    QUICK! Grab his grill that flew off
  13. Sep 12, 2019 at 2:37 PM
    COyotabrothers
    Is that why most serious crawlers are jeeps? Seem to have a lot less to cut especially with longer axles.
  14. Sep 12, 2019 at 2:38 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Long travel
  15. Sep 12, 2019 at 2:39 PM
    #35
    Sungod
    Sungod Well-Known Member
    St Augustine
    But Mall Crawlers sure do. You need to look good to look good.
    su.b.rat likes this.
  16. Sep 12, 2019 at 2:41 PM
    #36
    eon_blue
    Azusa, CA
    Jeep Wranglers are built to offroad, that's its primary purpose...ride quality and practicality in other areas comes after that. Whereas most other vehicles like Tacomas are built for everyday use first and foremost. That's why nearly everyone says Wranglers ride like crap on the street, because they still come with solid axles. Most everyone else did away with solid front axles in the 90s because there are better ways to build out suspension that rides much nicer on the street.
    Unibody construction and independent front/rear suspension is where most manufacturers are going nowadays, which is horrible for wheeling but great for pavement. We're lucky we still have Tacomas and 4runners to pick from that are body on frame with solid rears.
  17. Sep 12, 2019 at 2:44 PM
    #37
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    What all these guys are trying to say is: A lift will do more damage to your wallet than it will the vehicle itself. Just put enough effor into learning how to do the lift the right way the first time, and you will be safe. But - you will find that a lift will lead you through a rabbit-hole of expense when done correctly. Or a rabbit-hole of burden when not done correctly. Lift = bigger tires = bigger brakes = alignment accessories = drive line accessories = ect, ect, ect.
    Grossomotto likes this.
  18. Sep 12, 2019 at 2:44 PM
    #38
    COyotabrothers
    Makes sense, thanks for all the info! I'm looking to buy either a stock taco or wrangler and build it up over the next couple years.
