Excel Experts out there?
Discussion in 'Technology' started by memario1214, Oct 28, 2011.
  1. Oct 28, 2011 at 1:24 PM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have a unique issue with Excel going on right now. I am trying to build a progress tracker (for a class of course) and need to calculate my current grade. Does anyone know how to tell Excel to only pull a value (X) if I have a value (Y) in another column? I then need to sum up X and divide by the Sum of Y to find my current grade... :goingcrazy: If it would help to send you the file so that you can see it, shoot me a PM and I will get it out to you. I appreciate any and all help.
  2. Oct 28, 2011 at 1:27 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Send me exactly what you want and I'll work on it when I get home... time to leave now....
  3. Oct 28, 2011 at 1:28 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I might be able to help, which excel are you running?!
  4. Oct 28, 2011 at 1:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'll take a look- sounds like an easy IF function if I'm reading it right..but you have PM with my e-mail.
  5. Oct 28, 2011 at 1:31 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    You could probably do a vlookup.
  6. Oct 28, 2011 at 1:32 PM
    dpak
    Richmond, VA
    Feel free to pm me if you need help.
  7. Oct 28, 2011 at 1:33 PM
    memario1214
    Colton
    Missoula, MT
    I could send you my assignment Susan :p, but I would need an email address lol
    Excel 2010
    Haha I have to do one of those bad boys later in the assignment... Maybe I could just printscreen what I have up here eh?
  8. Oct 28, 2011 at 1:36 PM
    memario1214
    Colton
    Missoula, MT
    And all of the structure is my own, so if you see something messed up, let me know. Later on I have to give an estimated grade for each assignment based on my current overall percentage. Then I'll have to do a lookup to return a letter grade based on my overall points received.
  9. Oct 28, 2011 at 1:37 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    You want me to bring my Excel 'bible' from work? Its got every Excel command in there....
  10. Oct 28, 2011 at 1:38 PM
    memario1214
    Colton
    Missoula, MT
    I don't think that will help me. It's not the commands I am unfamiliar with... In this case, it is their application.
  11. Oct 28, 2011 at 1:39 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Which column is X and which is Y??
  12. Oct 28, 2011 at 1:41 PM
    memario1214
    Colton
    Missoula, MT
    Well see that 33.2% number hanging out there? That is not my grade overall. I am trying to find out my percentage based upon the grades I have already received. It would also need to update as I put in new grades.
  13. Oct 28, 2011 at 1:46 PM
    MTgirl
    Weesa
    Is it a VLOOKUP function that you need?
  14. Oct 28, 2011 at 1:52 PM
    MTgirl
    Weesa
    is it registering a low % because you have so many blanks in there? what happens if you delete out the blanks rows? is the % closer to your current grade?
  15. Oct 28, 2011 at 1:56 PM
    MTgirl
    Weesa
    Or go to the DATA tab, then DATA VALIDATION, then the SETTINGS tab....uncheck the IGNORE BLANK
  16. Oct 28, 2011 at 1:58 PM
    memario1214
    Colton
    Missoula, MT
    I could ignore all of those blank values, but the program still won't know how many points to calculate my total out of... I need to know what my current % is based off of the assignments I currently have grades for. Right now its calculating my total from what points are possible at the end of the class.
  17. Oct 28, 2011 at 2:04 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You got mail man...I'm not sure it's the best answer or even right...but I think it's what you were asking for...
  18. Oct 28, 2011 at 2:07 PM
    memario1214
    Colton
    Missoula, MT
    Thanks brunes! Im in class but ill look at it later. I appreciate the help
  19. Oct 28, 2011 at 2:07 PM
    MTgirl
    Weesa
    You want conditional fomatting then - basically telling excel to ignore the POINTS AVAILABLE column unless there is a value in same row for the YOUR GRADE column
  20. Oct 28, 2011 at 2:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Conditional formatting will only change the look of the cells IIRC. IF will allow him to find non-bank cells and compute a % score for that assignment. A SUMIF will allow him to total those percentages. The COUNTIF/COUNTA/COUNTBLANK will give him an index for how many assignments are complete.
    I think the answer I sent him will require some work because of the grade weighting...but I'm not sure.
