Excel Help!
Discussion in 'Technology' started by bulhas, Jun 7, 2012.
  1. Jun 7, 2012 at 12:16 PM
    bulhas
    bulhas [OP] the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    I have a sheet I'm making and its an odd one, im close but I am not 100% there yet
    What I am trying to do
    Sheet 1
    I have date in Row A and a tag in Row B, Sheet 2 i built a countif to count the amount each tags individually pop up
    =SUM(COUNTIF('log take 1'!C:C,A2))
    in order to that you can see i moved the individual tags in Row A ,now the next key in order to build a proper bar graph I need to know how many times each individual tag dropped on each day.....
    i was trying a countifs but i cant seem to get anything but a sum of 0
    im going try a filter but if anyone is up for a challenge have a whirl, ill upload an excel copy right away
    ummm my excel file is too large, so if you want the sheet send me a pm with your email ill send a copy
  2. Jun 7, 2012 at 4:26 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    From your formula, it looks like you're counting items in column C. So, "count if" the item in A2 is found in 'log take 1" column C. If nothing is in C (which you didn't mention), you'll get a 0.
    Also, you don't need the sum function. The Countif function will return the number of cells that match your criteria.
  3. Jun 7, 2012 at 9:01 PM
    bulhas
    Joe
    Edmonton, Alberta
    1997 Rexus
    log take 1 has data in in column C if it matches column A on sheet b it counts,
    I built a pivot table and was able to decipher my issue, my only problem is i do not like the layout of pivot tables
    I might build a filter array and than I may be able to get it to tell me which cells need to go where
  4. Jun 7, 2012 at 10:03 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    w/out seeing the spreadsheet in question, i don't know, ...but i will give some words of wisdom when scratching one's head over unexpected results in excel formulas:
    - be weary of data (especially if imported or pasted from outside source), ...on several occasions i've seen where data will show up as expected in the cells, but in reality may contain a very minute difference from rounding or from some measurement... i.e. expecting to use formulas that will "work" assuming all your data are truely integers may not work right if some data have these minute rounding errors - this is because conditionals trying to compare two numbers to see if they are "equal" is interpreted literally..
