Excess Oil Drain Hose?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stryker420, Jun 12, 2018.
  1. Jun 12, 2018 at 10:19 AM
    Stryker420
    Stryker420 [OP] Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    When I remove the oil filter, the excess oil drains down onto my skid plate and gunks everything up down there. Not really an issue, but is there something missing? Seems like a small drain hose could be added so the excess oil has a place to go,besides onto my skid plate. Anybody every notice this?
  2. Jun 12, 2018 at 10:21 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    An empty oil bottle fits nicely right under the drain nipple
  3. Jun 12, 2018 at 10:23 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes its can be messy. Put a can under the drain.
  4. Jun 12, 2018 at 10:23 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just put a hose on the nipple and run it out the bottom of the truck when you change the filter.
    Stryker420[OP] likes this.
  5. Jun 12, 2018 at 10:35 AM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    I have the fumoto drain valve, so the drain plug isnt my issue. I will probably just go with what
    crazysccrmd said.
  6. Jun 12, 2018 at 10:43 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    use a water bottle and tie a 10 foot long bright pink extra wide ribbon to it.
    Let it drape over the drivers side fender so you wont forget to take it out before starting the engine
    PS, red oil is from a transmission
    Seems a lot of people that don't know there left from right, mom from dad, cat from dog, cant tell the difference between an engine or transmission pan either
    OneFastGeek and DougSD like this.
  7. Jun 12, 2018 at 11:12 AM
    BRONSON
    BRONSON Active Member
    Canada
    2009 TRD Sport 4x4 DCLB
    885 w/ 5100's + 1/2" d.s. top plate, EL096R w/ B110's, Whiteline LCA bushings, Energy Suspension poly leaf & shackle bushings, new OEM rear shackles, custom rear brakeline mount & e-brake extensions, LR UCA's, SnugTop cap
    Tried the drain hose a few times but it's always curled and pain in the hole to fish down there. Then it drips after you're done.
    A Fumoto and any old plastic cup/bottle/jug temporarily wedged under the filter is as quick and simple as it gets. Stash it with the funnel.
  8. Jun 12, 2018 at 11:21 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    I ran a clear plastic hose from the catch lip under the oil filter(v6) tie wrapped to the radiator brackets hoses and it exits out the bottom through the front skid plate. There was a square hole through it install once use forever.
    TOMB
    stbear and desertrunner24 like this.
  9. Jun 12, 2018 at 11:23 AM
    knottyrope
    Knotty
    Bahstun
    you put something round into a square hole?
    cruxofthebisquit and Alexely999 like this.
  10. Jun 12, 2018 at 11:25 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  11. Jun 12, 2018 at 11:33 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    A quart bottle of mobil 1 fits nicely; wedged in place.
    I also use another bottle with the bottom cut off. The bottle will screw into the oil fill. Makes a quick job of pouring in the 5 qt jug...
  12. Jun 12, 2018 at 11:39 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I just cut the top off a plastic water bottle, fashion a S hook out of bailing wire, hook bottle, hook lip of aluminum edge. Position under drip spout.
  13. Jun 12, 2018 at 11:41 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Just pull the skid plate off before your oil change then reinstall once finished
    Sidney Vicious likes this.
  14. Jun 12, 2018 at 11:47 AM
    blefferd
    blefferd Well-Known Member
    Brian
    2012 Tacoma SR5 4x4
    I just wedge an empty 16oz water bottle under it. Hell anything absorbent would work and be better than letting the oil leak all over your truck lol.
    outxider, Alexely999 and honda50r like this.
  15. Jun 12, 2018 at 11:50 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Just get out your drill bits and keep drilling a hole in the top of a small coke bottle until it "snaps" on the drain. It will hold and fill with about 1/2 cup oil.
  16. Jun 12, 2018 at 12:11 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    This is the way to go. I used a piece of 3/8 fuel hose and clamped it to the nipple and ran in down through the skid plate and zip tied it in place next to the radiator. Done no more having to cut a quart or a bottle.
  17. Jun 12, 2018 at 12:15 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Welcome to TW where we pontificate over the most trivial shit. Love it. I wedge a water bottle under the nipple. Or my beer can if its empty.
    outxider, BillsSR5, blu92in99 and 4 others like this.
  18. Jun 12, 2018 at 4:07 PM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    :facepalm: Damn Jarheads with no logic. MARINES = Muscles are required intelligence not essential.
    US Marine[QUOTED] likes this.
  19. Jun 12, 2018 at 4:22 PM
    scocar
    scocar hypotenoper
    :cookiemonster:
    0wise1 and DoorDing like this.
  20. Jun 12, 2018 at 4:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Stock there is a cap on that nipple. Procedure is to remove cap place cup under nipple, spin off oil filter, clean up catch basin, replace oil filter, replace cap remove cup of oil.
    If you run a tube its gonna sit and drip for a few days all of the stuff that had to travel down the tube.
    DoorDing and Stryker420[OP] like this.
