excessive brake pedal travel once a day
Discussion in '1st Gen. Tacomas (1995-2004)' started by williamwyatt1951, Apr 6, 2012.
  1. Apr 6, 2012 at 5:27 PM
    williamwyatt1951
    williamwyatt1951 [OP] New Member
    will
    florida
    03 sr5 4x4 trd
    Pedal will depress about half-way to floor at morning startup, can then be pumped with about 4 pumps to a good hard pedal, and then is no problem until the next morning. Any other startups during the day experience no such problem. Fluid level is good, rear drums were pulled, inspected, and what little slack there was was adjusted out manually, linings and drums were good. Pads on front and rotors looked good. Not losing any brake fluid. Truck stops quickly and true.
    2003 Extended Cab - 4x4 - TRD - SR5 - V6 - Auto - 89k
    I would appreciate any thoughts or suggestions you might have on this issue.
    Thank you
